PDA
View Full Version : IS - 2nd Gen (2006-2013)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
  1. quick question on fender rolling
  2. IS350 Fogs light using 9006 CREE Plasma LED Projector bulb Fog Light HeadLight 11W
  3. HID Xenon Lights
  4. Lexus IS250 AWD wheels?
  5. Busted a mirror. Heated or Non Heated
  6. Is250 manual or is350
  7. Custom ISF mufflers on IS250
  8. Condensation! Now HID wont turn on...
  9. Power Windows not working after battery replacement
  10. IS350 Wheel change
  11. Where to buy TE37's
  12. Is it a good idea to go to the dealership for regular maintenance with lowered car?
  13. Next Generation IS
  14. Bad day for two ISX50 in Toronto
  15. Anyone seen this yet
  16. Need help immediately
  17. Low Tire Pressure Light On. OK to top up with air?
  18. Unstaggerring for longer tire life
  19. lexus isf Wheels won! now for setup advice plz!!
  20. My Rear reflector fell off, where can i buy a new one (other than lexus dealer)
  21. Bad Day :-(
  22. 2011-2012 Front Lip for Is250
  23. check headlight system
  24. p/s light HELP!! power steering
  25. heaviest wheels on an 2is
  26. Some new parts for the IS...
  27. best reverse led?
  28. HKS350 through the years: A pictorial timeline.
  29. HID Ballast Purchasing Advice
  30. Buying an Is 250 need advice
  31. Center Caps - G-Spider Rims
  32. 2012 retro kit HELP..Wiring Guru check in pls
  33. Center Console Lights NOT Working!
  34. F-Sport Shift Knob for Automatic Transmission - Loose?
  35. Is it true that the IS is based on Camry's
  36. Fixing curb rash
  37. hid bulb
  38. What's the Best Police Radar Detector?
  39. gf is250 started shaking check engine light blinking
  40. 2011 Led Headlights
  41. Revving is350 from under hood
  42. Help: Weird Blemish on Wheel
  43. poor ISF! :(
  44. Offset Question
  45. Bad day
  46. 06 Lexus IS250 plastic engine cover rivets removing
  47. Finally a true owner =)
  48. Approx how long will battery last if headlights are off and the radio is on?
  49. Cruise Control Not Turning "On"
  50. Hit and Run :(
  51. Post-it Wrap
  52. North/Central NJ ISx50 Mechanics
  53. IS250 won't start
  54. Install Mesh Grill
  55. New Vendor Saying Hi and Showing Off Some of Our Stuff!!! PICS....
  56. What size dog crate fits in the trunk?
  57. brake bleeding
  58. Head Unit Issues
  59. 2007 IS250 staggered stock wheels
  60. Oil Leak Question
  61. 07 Grille surround the same as 2012?
  62. Water Pump, Driving Belt & DIY
  63. IS 250 2jz swap information
  64. Most Miles Put On ISX50 With Up Keep Done
  65. Having a withdraw
  66. Girls of cl!! Where you at?!
  67. is250 tire pressure light
  68. how to reset oil service light???
  69. HID Information for a 2006 is250
  70. 2009 is250 puddle not working?
  71. Many Questions??
  72. Problem - Cruise Control doesn't work when TPMS light on?
  73. Noob Question: Will Five axis lip for the 350 will fit on to the 250 ?
  74. Help Foglights !!!
  75. Twin Turbo IS250
  76. Looking for DIY Gen 6 Navigation update turtorial
  77. Help with wheel finish.
  78. gs f sport rims on is350
  79. My last set up Custom Work Vs-xx with step lip
  80. Video files through USB?
  81. Dashboard Rattle – Under Centre Speaker Panel
  82. 2009 IS350 ML + Luxury
  83. NSFW ..... USB F-Sport on Concavo wheels ..... NSFW
  84. White IS350 on Work Emotion CR and Tanabe Sustec coil overs
  85. coolant leak 09 is250 with 30k miles. anybody with same issue?
  86. sewell black friday anyone?
  87. Heavy condensation
  88. Has anyone changed out the stock non-ML sub?
  89. Anyone have an Aftermarket Head Unit?
  90. firmware for DVD navigation
  91. My IS350... rear ended...
  92. Adding HID Bulbs to a 2006 Lexus IS 350 (2IS) so simple?
  93. fresh air making grinding noise
  94. My aftermarket subwoofer setup
  95. Rear Doors not Unlocking
  96. Low Idle
  97. Check this out blue led shift knob
  98. Clicking sound from front wheel / suspension / stering when going in R
  99. x-mas gift for your lexus is250/350
  100. Need help 09 is 250
  101. Mark Levinson System Question
  102. Light bulb change out
  103. Need suggestions on tires
  104. remote start advice/tech help/wiring info FREE
  105. Nav unit
  106. Got into an accident, Looking for opinions
  107. Black Friday Deals
  108. 2009 IS250 sensitive clutch/smell
  109. If you have thread that requires a pic with your post
  110. Aftermarket GPS Navigation DVD system question
  111. Anyone got pictures of front lips on 2011+?
  112. speedometer not working properly
  113. Navigation questions
  114. Aluminum Sport Pedals, how much of a difference?
  115. HID question
  116. team lexus is250/350 f-sport roll call
  117. Cf dash trim precut or diy ???
  118. How often do you floor it?
  119. So I test drove a 08 ISF today and...
  120. OC/LA:Lexus IS250 Parking Sensors Aftermarket?
  121. 4 years old with 13k miles - what work needs to be done?
  122. What are our front bumpers made out of?
  123. OEM rear spoiler,
  124. go to dealer for 30k service?
  125. Navigation - "External System Not Connected"
  126. if you want to see what an is looks like after a 70 mph rear ending
  127. Need input on these headlights
  128. Before and After pics of F-style grill, Too Light?
  129. Sewell Black Friday Sale!
  130. tpms sensor
  131. inner tie rod end replace
  132. what will i need for a full beam/fog light conversion?
  133. dash is deteriorating, help!!
  134. Measuring Brake Rotor Wear
  135. Do YOU have FRONT parking sensors & are extremely lowered?
  136. heater smell ?? 06 is250
  137. Stuck on dashboard removal-srs airbag/steering wheel
  138. Audio Issue (2007 IS250)
  139. Part number help
  140. Power outlets problem
  141. Check VSC, Check Engine, Traction Off lights
  142. Anyone with plastidip OEM spoiler?
  143. Battery brands?
  144. brembo brake caliper cover y/n ????
  145. Is250 off the line
  146. LED Fogs. Should I?
  147. depo headlights
  148. Check out this limited edition IS250!
  149. Rear Ended (w/ Pics) - Aftermarket & Valuation Questions?
  150. Is this a good deal for winter tires?
  151. Before and After
  152. Soo new wheels came in....
  153. TPMS programming?
  154. extended wheel studs?
  155. Nitrogen for tires...Can I ever go back to regular air?
  156. drivers seat belt wont lock in
  157. Looking for pictures of SGM with carbon fiber trunk spoiler
  158. HD backup camera replacement
  159. eBay isf front and rear bumper
  160. Problem with ML Subwoofer IS 250
  161. Quick thought about PWR and rolling starts
  162. HELP: IS randomly goes dark
  163. Sad day for me...
  164. Maintenance advice
  165. Drilling backup camera
  166. OK, it's my turn....
  167. Canadian IS250 Rotors replacement
  168. new member wondering about nitrous on is250
  169. would this fit our cars? 255/35/19f & 275/35/19r?
  170. IS low beam issue...please help
  171. Rohana RC10 Limited Edition Silvers on!!!
  172. Looking at buying 2007 AWD IS 250 w/ 70k miles
  173. Clunking Noise After Lowering ('08 IS250 AWD)
  174. How to disassemble cigarette tray?
  175. I said I was done modding for the year.....
  176. Bumper Tab Broken
  177. Are my puddle lights out or disabled by personalized settings?
  178. Vinyl wrapped my key fob
  179. 2008 IS250 waterpump DIY
  180. CS letter from Lexus: Engine misfire.
  181. Key FOB issues
  182. Drl led
  183. weird tire wear
  184. Extended warranty pricing..
  185. Dropped Transmission?
  186. Drivers side window switches not working
  187. HID set up...
  188. Need new drl/high beams???
  189. How much to paint car matte black?
  190. IS350 Carbon Build Up Issues
  191. Looking for 07-08' 350 Black/Gray Int
  192. LED parking lights
  193. Generation 6 Navigation USB update on MINI VCI for Toyota with Techstream
  194. 2006 Lexus IS350 PCS
  195. finally coming together
  196. Need Help finding black on black 11-12 IS350 F sport
  197. First damage to the IS... Everyone is okay.
  198. Genesis Coupe Track Wheels
  199. Changing filter on a K&N intake
  200. Homelink buttons always hot? even if the
  201. Motor Bzzzzzzz
  202. thrilled with my IS250 AWD 2009
  203. RMI scoop development interest.
  204. Dropped screw in gearbox! Please help!
  205. Looking for a vouch in the Atlanta GA area
  206. Chains for IS350 18s
  207. Locking Lug Nuts Or Not
  208. Recommend me a body kit (front+rear bumper)
  209. 2006 Lexus IS350 dealer problem.
  210. DIY airconditioning filter
  211. What is this Wire in the engine bay?
  212. Louder engine ticking after battery installation
  213. Humming noise around rear/fuel area
  214. 38K Rear Differential and Driveshafts Leak!???
  215. antifreeze
  216. Radio/USB "Error 1" and "Error 6" Message
  217. Hardwiring iPhone 5 Lightning Cable For Power
  218. Help, weird noise
  219. IS F-Sport Body Kit
  220. Oem Lug nut locking key
  221. Weekend = ruined.
  222. Need Wheel Advice!!!!!
  223. Gfx front lip + blacked out oem grille installed
  224. What kind of rims are these?
  225. 2008 is250 STAINS ON CONSOLE! HELP!!
  226. Satellite Switches/Buttons stopped working(TPMS Reset, Speed-limit set etc)
  227. NE1 bought this? Price is right.
  228. New Rims...Again! Change of plans
  229. Sound Issues
  230. Calling all cashmere interior owners....
  231. Anybody know where to buy this lip?
  232. F-sport exhaust question
  233. So many people like the M2 exhaust...
  234. Random chirping
  235. smartkey/ replacing the battery question??
  236. DIY: Convert 06 gas trunk release buttons to 07+ style
  237. HOW IN THE H**L? Passenger window....
  238. wheels dont fit over calipers. can i shave the wheel?
  239. Tryin be a good guy,lol
  240. what front grille is this
  241. New 6MT Starfire Pearl Owner Here!
  242. Considering changing dealerships
  243. TYC fogs anyone????
  244. Help! How do I remove these scratches?!
  245. Hid installation Help
  246. IS250 F-Sport feat. Seibon Carbon Hood
  247. Major Curb Rash :(
  248. Regular bulb to LEDS
  249. clear courtesy lights on the bottom of the door
  250. IS350 fuel effeciency down
