- Need Help On Tires !!!!
- Auto down shift?
- Changed air filter, now car shuts off at start
- New to the community, looking for reputable shops in Houston to get some work done
- Lots of bad news from the stealership today!
- need oem ix50 exhaust
- Need your opinions on these wheels!
- Site Plan
- Skirt Weather Rubber thingy
- TL lens projector swap from stock
- LED DRL and HID turn on together…
- 2008 IS350 navigation screen is completely black
- Upgrading a IS350 premium to ML system
- Deal or no deal?
- Drive Side Pillar Trim Install
- Squash air freshener?
- Is my radio/nav updating?
- Strange noise while in automatic car wash?
- Are 7 Spoke/8 spoke rims very common??
- Best offset for 20" wheels?
- Roadtrip time
- Hi.
- Oil Maintenance Req Issue?
- New VLeds HID Headlight
- Rear dome light housing remove
- Removing dash - any advice?
- wheel fitment
- Is this a good deal?
- IS350 Timing Cover Leak, but no visible oil?
- How to remove side molding in the front?
- G FORCE Performance Chip
- Took a few shots of the IS by the Bay...
- Lexus GX460 Exhaust Tip on an IS?
- Grille Surround Opinions ? with F sport grille
- 2014 IS 250 Buyers Beware Potenial Steering Rack Issues
- lexus is220d navigation
- AFS issues
- Got rearended!!!!
- Purchase Opinion - 2007 IS350 vs 2011 IS350 F Sport
- IS350 CD Changer Issues
- My IS350 pictures from the weekend
- Any 2011-2012 Replica Front Bumpers?
- 2012 OEM ballast problem?
- Diffrence between sport and luxury variants, IS350
- '06 IS 350 Nav Screen not responding to touch
- IS350 availability
- Has this F Sport rim been refinished?
- Engine Oil Level Low Warning
- Might be a little out there...
- Dome light under the scuff plate?
- Floor Jacks
- Ghost in the glove box?
- Map info display remains the same after update
- Pull codes P0172/P0175, need help diagnoising
- Anyone use royal purple oil?
- TPM : LOW TIRE , But they aren't !
- factory HID low beam question.
- Official Fully Vinyl Wrapped ISx50 Thread
- Vossen VVS 083 Repair
- Another New Member!
- Car Roof Rack for IS 250
- D4S XeonoDepot 6000k from kbcarstuff.com
- Side Skirt material
- 06 IS 350 Last minute pre-purchase advice - Help please
- Hi newbie
- is220D check VSC-HELP
- Abnormal Wear on Tires-2009 IS 250
- Standar 350 vs. F Sport Steering
- Fuel Pressure Sensor Replacement $800?
- New 2IS Member
- New Member
- Where are you guys buying Vertex or even Repro's for 09-10's??
- Interesting antenna...
- 19" spare...please help
- Help: Jack and Jack Stand Points
- What color should i do ???
- hub centric for the genesis wheels?
- Fresh/Recirc Inoperable. Can I "Force" The System To Stay In "recirc"?
- Does any one have these headers ?
- Bluetooth question
- Leds
- carbon fiber rear spoiler
- is 250 radio reception
- Info on buying
- AFS off light is flashing on the dashboard! help!!
- Sunroof rattle
- Transmission Oil
- finally a member!
- looking for stock exhaust/questions on exhaust.
- DRL Headlights 5 Pin Relay
- junction produce fusa silver???
- Anyone purchased the FlyAudio GPS unit from China??
- Help: Front right wheel makes screeching noise
- AC Gas check?
- Help adjusting LED headlights
- help!! [Will an 09 WALD lip kit fit an 08?]
- decision on new rims
- [HELP] DRL from iJDM not working
- Where to find...
- Help!!! Check AWD
- Wald replica spoiler. Where to find?
- Reasonable Asking Price
- 2006 IS350 Sticky Dashboard -- Help please
- 2008 Lexus is250 rear tail light/brake light question
- 2006 Lexus IS350 Paddle Shifter not working!
- Tire Pressure Monitor?
- Forgestar F14's incoming! Tire Suggestions please??
- Lower engine knock while in Drive or Reverse
- Nav upgrade from 9.1
- DIY Air Conditioning Service
- AC low but no leak according to dealer charging fee even though certified
- is250 isf front conversion
- Daylight lights
- Engine help... what is this pink stuff crusting all over?
- Help with interior size..need to fit something large!! urgent
- rear windshield deflector name?
- My 2010 is250 jacked from house last night
- Bolt on super charger or turbo kits for is250?
- Light help!!!
- Wheeloutletsd.com Is a scam
- Best rear view radar mount?
- To those who have wrapped your roof.
- 1pcs GFX front lip for 09-10
- What is this part of the IS250 called?
- 07 Lexus IS250 Help Needed :(
- 2006 IS350 - Metal Grinding Noise (Car Owned and Driven by Woman)
- How do you remove broken bolts? (pics)
- Towing with my IS250 (2011)
- Is250 problems. Two
- Riding on 19's in the Big Apple. Bad idea?? Input Please
- HELP! problems after DIY brake fluid flush
- grounding kit
- Would you swap 17" OEM wheels for 18" OEM wheels?
- Front splitter
- Has Anyone else had this problem with their AC?
- got used weathertech window deflectors
- Possible Alternator Problem?
- New 07 IS250 owner :)
- Painted grill surround?
- Air intake control and air con system
- Quiet/Smooth Tires
- help with grill fitment
- IS250 slow / difficult to start engine
- New OEM spec rotors too small, is that an issue?
- Picking out wheels, any suggestions?
- Just picked up an '06 IS350. New member!
- Sound right?
- most aggressive wheels i can fit
- mr250 mrm is250 awd photoshoot
- Attention California ISx Owners!! Need your help!
- Max tire stretch on 17 inch stock wheels
- Did I Just See A 3IS.... RVCAIS250's Custom Bumper Conversion (3IS-F)
- Best way to clean and polish these wheels
- looking a good place to buy eyelids and a roof spoiler for my.SGM IS250
- Extended Warranty for '09 IS350
- Seized caliper
- How to value my car
- Dreaded Carbon Build-up
- Power Sunshade Techstream options
- 120k mile service recommendation?
- Accident, diminished value claim
- For Sale and Want-to-buy threads go in classifieds forums, not here
- strange noise coming from engine bay
- Illuminated Door sills Blue Sale on Sewell
- Looking to buy a 08 is250 - help with service codes please?
- car photoshoots....
- sport pedals
- Will 07is250 Megan ez coils fit 2001 is300
- Sewell LED Headlamp Retro-Kit Sale
- Help on wheel selection - 06 IS250 AWD
- Power/snow fuse location/ traction control
- front camber kit help
- Please help
- Introducing myself
- Blacked / Tinted tails , what you think ..
- 3D Carbon+Ings
- XM Fit Kit available...
- Stock Bridgestone All Seasons = POS
- WALD Replica Kit fitment
- Help Bank 2 Sensor 1 & Bank 2 Sensor 2
- help valentine 1
- Changing my front and back bumpers
- ECT Button Power/Snow + Traction Control Not working
- Cross-country Road Trip - Which Mod??
- Seat memory broken & solution
- f sport rims dipped high gloss black
- TSW 19" Tire Size
- White IS with gloss black mirrors and door handles
- Rattle noise after installing M2 Axle back exhaust
- Left front Shock failure within a year.
- Need 4 Speed Motorsports | Lexus IS250 with Vossen CV3's | Professional Photoshoot
- DRL LED (getting sick of this topic, experts needed)
- 2nd Gen IS reliability
- Will WALD kit sides/rear 09+ fit 06-08?
- RDIS250AWD'S 1st legit photoshoot
- Wheel fitment questions
- is250 Power Steering Module Installation
- Rear sway bar interest?
- OEM Rotor part number
- valentine one
- Turn signal issue
- What spoiler is this?
- Need help for is-f front calipers upgrade on isX50
- Carbon Fiber OEM Spoiler...
- IS350 Retrofit Projectors- has anyone else done it this way?
- USB memory stick for music playback
- Need help/advice after the dealer damaged my steering system and refuses to pay all
- Square set up Wheel options.
- Sport Pedals sale at Sewell on June 19 $88
- 2IS: Officially officially over...
- Rx65 detector
- iJDMToy Decoders - DRL
- 2009 IS 250 aux port only playing mono
- DRL lights?
- Birmingham, AL or other Southeast dealer
- Returning Lease - Few questions
- transmission feels different after solenoid change
- shocks problem
- Trade-In 2011 IS250 for Potenital 2013 IS250
- Paint shops able to match SGM?
- Octane Motorsports/2011+ ISx50 Front Lips
- Noise when turning. HELLLLP
- How do I turn off Oil Service Light on 2010 IS250?
- new member...
- How many o2 sensors in car?
- IS F Sport Front Bumper/Cover Pieces, tacky or classy?
- Help sub amp question?
- Brake Pad Sugguestion
- Just bought 06 IS350 please advise service history
- Help with sticker found inside hood
- Strange nav touchscreen issue
- IS-C after the warranty?
- Possible alternator issue. Need help
- 2IS Rear Bumper Applique... Help!
- D4S XenonDepot HID Bulb (Did I get rip off?)
- confused need opinions
- LED DRL post again!! (suggestion needed)
- Brake Pad / Roter Replace (after inspection)
- is250awd turbo?
- New 07 IS350 owner. Have questions.
- lowered 2013 is350 fsport
- Cam gear startup noise gone
- Good buy or not?
- Help: Anyone has this Side skirt.?
- eBay / Eagle Eye / red/clear LED tail light review
- If you ever wonder why you get sick...Video
- headers
- 1st attempt on photographing my IS
- eBay F Sport Grills
- Anyone near South Carolina?
