- Need a new Mod to do to IS !!!!!!
- Upgrading my 115k OE suspension build
- style 95/7 series wheels on you 2IS
- Wheel size question
- A/C, Check VSC
- Paint diffuser or keep black?
- Lexus IS250 ECU Pinout???
- HID bulb replacement options?
- Black sport microfiber leather seat
- Lost the wrapped rain gutter/side roof rail while driving
- Putting OEM 18x8.5 on front
- f-sport air compressor and tire repair kit
- 2IS "jdm" power folding mirrors
- H11 Xenon HID Conversion - Relay Harness?
- custom steering wheels
- HID Kit Suggestions for Front and Fog Lights
- How to clean headlight fog?
- 2006 lexus is 350 vvt recall problem
- Ways to prevent sticky dash. Dash cover, sun shade or both?!
- Trouble getting XM satellite radio working
- Is250 Security locking issues.
- anyone bought from tunerdepot.com
- 18" wheels on AWD with stock height
- Would the isF front bumper for on a 08 is250
- Uneven Exhaust
- Front lip without drop
- 2006 IS 350 turning off when pushing the start button
- 2006 Manual IS 250 loose gear shifter! Help PLZ!
- Seat Covers
- Vaistech SL2i question
- Megan UCA bolts
- 2012 LED Fog Lamps
- Engine cover pins
- Couple of snaps
- VSC vs TRAC
- battery terminal cover missing, how important is it?
- projector lights update to look like 2014?
- 2007 lexus is 350 burning oil.new oil weight?
- Midas for brake pads and calipers?
- USB drive not recognized
- Center Console LED in 2012 IS 250
- 19x10.5 +22 fitment help!
- Questions on offsets/sizes for new wheels!
- Almost stalled
- driving past the range meter
- Are There Aftermarket Side Mirrors Out There?
- 2007 IS250 high milage concern
- Got my calipers done today - Red :)
- 08 IS250 with 67k miles
- Difference Between Swaybar and sport package swaybar
- 2007 is250 with check VSC, P/S, ABS, + NO AC HELP!!
- 2011-is250 fsport autostart kits Best recommendations
- replacement screws
- Where to buy GFX LIP for cheap
- front wheel fitment
- 2006 IS350 60K Service
- Before & after
- DRL question??
- Bodykit help !!!!
- 2012 IS250 Headlights
- Do I need to replace these front tires??
- Water pump replacement
- Front Wheel Bearing?
- ►►►► █ Im buying These Wheels - Need Tire Size Help??? █ ◄◄◄◄◄
- Install My Ride Rear Diffuser?
- Car phone mount left a big circle dent on dash!
- 2011 is 350
- looking to buy a is350 need some input
- Quick questions about the 3M tape for the Spoiler Install
- What the hell is this?
- 2010 Tail Light Upgrades
- Rough idle, from using accessories???
- Is 3M tape waterproof?
- Redouts
- CF Roof Spoiler
- Electric Power Steering is Cumbersome
- Thud, knock coming from rear of IS 250
- Auto tilt-down side mirrors
- DIY VIDEO: How to Install illuminated Door Sills on 2006 Lexus IS250
- Anyone know anything about SSR wheels?
- for my is
- 2011 IS Oil Change - Oil Pan Bolt Leaking
- Help with fitting x11 in the back
- Rear view mirror to end all threads
- Installed DRL but moisture cap is off. Help!
- Part confirmation please
- Will I rub?
- Rardar detector install?
- a question about side mirror LED...
- Ok to buy 2006 IS250 awd 117k mi?
- how bad is this?
- Broken Wheel Stud need some advice
- possible new owner. Quick advice please =)
- Non-Responsive Lexus Navigation System Fix
- Help with these wheels. please!
- TPMS question.... 2006 IS250
- extended warranties
- AWD (VDIM/TRAC off)
- MyRide Diffuser
- Connection of Rear Tweeter?
- OemCarGps.com
- Vibrations
- New Front End Poll
- AC Blower Motor Problem?
- How to remove lower grille?
- Need some help with error codes? on my lexus is350
- Is250 will not start
- red out tails... got bored
- Door locking mystery
- IS250 RWD to CT200H
- myride diffuser can't fit into garage
- Roof Spoiler.... Anyone near Daly City?
- Goodbye Noisy Boy
- Front lip for 07 IS no drilling req'd
- Drivers Side HID turns on then off
- Will 2011 IS-F cluster work in ISx50?
- Brighter reverse bulbs
- My first mod
- Things to know about 2nd hand F sport Exhaust?
- Safelite auto glass
- 2011 IS250 RWD w/Leather and Moonroof - LED DRL?
- 08 is250 repair manual
- 08 is250 front wheel bearing
- Fuel Cap
- Myride diffuser fitment problem
- How much did you guys spend painting and molding?
- Warranty Options - Do I have any?
- help 08 ML audio system
- Raising piping for f sport exhaust?
- Weight of OEM 17" wheel
- Walmart Photo Shoot IS250 ISF Bumper Conversion
- Is350 or Evo X ??
- IS250 left me stranded with no electrical power at all
- Need more clearance up front after roll & relocated bumper tabs
- Carbon buildup info please.
- Ventilated seats question
- Question about the Ebay tail lights...
- Godspeed Upper Control Arms
- '07 IS350 AC Problem
- Leather seats
- Thinking of upgrading to IS-F
- Installing Roof spoiler and JoeZ Intake
- Tire pressure - Z-rated tires
- ISF front seat to IS 350
- Trade my Volk GT-Cs for 08-09 ISF wheels?
- Are These Lug Nuts Safe???
- Is the Joez Intake worth it?
- No more fog light mod?
- 06 is250 electrical issues.
- Need to shave front caliper- 19x9.5 +22
- My first lexus is 250!
- Megan rear camber kit- Use nylon locking nut or OEM?
- 08' IS250 using oil?
- My Is250 is now acting like its boggind down
- drls question ca 714 oc
- New to Club Lexus* Need Advice for coilovers!!!!!
- Question about hella horns
- Aftermarket Bluetooth
- TSW Wheels on IS
- A New Lexus Owner - From M3 to IS350 - Saying Hello :)...
- LED for IS350
- Headlight fogged solutions?
- Picture DIY : Lexus IS350 Alternator Replacement or Removal
- Winter Wheel repair
- 2012 Nav Audio problems
- CEL, Traction light, DTC P0101, P0172, P0175 2010 IS 250 AWD
- Just changed plugs and got a question.
- First mod....first post....first pics =)
- Burping Cooling System with Funnel
- Buying an IS350 tomorrow... What do I need to do?
- Custom Grille
- AC compressor pulley
- lexus is220d
- 2011 IS350 Drivers Side Vent Rattle
- Has anyone purchased a myride diffuser from these dealers?
- Urgent Waterpump O Rings
- Brake Booster Gone Bad
- Ings side skirt question
- HID conversion help
- In car mileage vs actual calculated mileage
- Windshield de-icer install
- 2IS dash removal process
- 2012 LED\HID Headlights in 06 Help?!
- 2010' Lexus IS350 B Pillar replacement
- Spark Plug Change At 42k Miles But Its An 2006?
- Very stiff brake pedal on IS250
- 06 is350 trunk and gas lid backlight?
- Inspiration
- Re-using hose clips
- What parts of the 60k service do you really need?
- Swapping DRL's to LED's - 2IS (5-10 min. job)
- Whats the longest you guys went before replacing spark plugs?
- Help! LED headlight not working, IS 250
- Any Way To Fix This Door Panel?
- Hello. New IS350C owner
- Help please!!
- bmw 95 style rims
- MyRide Diffuser
- Urgent please help me asap
- Anyone buy their tires at Costco?
- Buying IS250...2006-2010..differences?
- Tire Pressure Sensors - PLEASE HELP!!!
- [HELP] Condensation in headlamp
- varrstoen es 2.2.2
- USB port questions
- '14 F-Sport Springs on 2IS
- front bumper help.
- 09 Blue Onyx Pearl (chameleon) New Ride !!
- Plasti-dipping your badges/emblems/letters
- Random Start Up Issue
- FS and WTB threads go in the classifieds
- Bset place to get a lip spoiler and roof spoiler?
- Another New member!
- ISF exhaust on IS350
- NEED HELP: Need inner barrel
- please help - (Stereo has no sound)
- New member saying "Hello" to all
- Anyone static tucking 19's in the rear w/ f-sport exhaust?
- Where to buy a Replica Wald Spoiler?
- Cold air intake sucking in hot air.
- New member to CL
- 06 IS350 alternator labor time?
- Tune/File Knob Does Not Work
- Need part number please help!
- What size bulbs do I need ?
- Driveline Vibration. Help...
- IS250 AWD Electric Power Steering noise
- side skirts splitters extention help
- 2IS Hacks and Secrets Thread
- 08 IS250 Rattling Sound, ~120k miles
- How to connect Andriod phone to '09 w/ipod integration?
- Spark plugs or coil
- The gangster party hotline....non lexus related
- Lexus is350 mpg
- Which IS350 should I buy and why?
- Noise coming from rear passenger wheel
- DIY cardboard front splitter
- Cyl 5 & 6 running lean?
- installing a hitch for bike racks
- Faulty Stereo?
- Woom Woom Woom sound
- Anyone have this Rear window spoiler installed?
- What do I request for maintenance in excess of 150,000 miles?
- Magnetic phone mount - thought it some folks might want this info
- center console chip fix
- My first Autocross
- brake conversion
- A/C Central vents
- HID bulb replacement question
