- RPM Drops on IS250
- factory Ipod adapter question
- Opinion on IS F tail lights with stock inners
- IS350 revs high
- how many of you are waiting for the '16 IS200T?
- 07 IS350 being recalled by dealer over Potentially botched Valve Spring Job
- 2007 IS250 rear ended and idles rough now
- rattles, squeaks and chirping on '09 IS350
- Navigation problem
- 2006 IS250 strange jerk/judder
- cd player problem
- I want to know wiring circiut audio for lexus is250 2006
- Another LED puddle light review
- F-Sport Shift Knob Stuck
- New IS owner, Magical power steering.....
- iPod Integration - Bluetooh Adapter
- WTB: 2006 IS250 wheel
- Uh.. High Idle when turning on A/C with warm engine?
- After purchasing a certify pre-own lexus
- Headlight Mod
- Need help with wheels ASAP
- Shaved Fenders
- who has third brake light flasher, is it legal?
- Hear low pop sound
- Help - rear diffuser
- Timken or Sewell Lexus wheel bearing
- Does anyone run a catch can? - GDI Carbon Fix?
- Vin number info.
- Cloth Lexus Poster?
- Xenon bulbs
- Scratched my car, need help
- Anyone tried running 18" front and 19" in the rear???
- How do you replace the roof molding?
- rear camber install??DIY??need help.
- Slow pulsating humming sound with slight vibration
- do i have to roll fenders ???
- How to Program Radio Stations!?
- Lowering 2010 IS250 AWD
- Considering a trade: 2011 IS250 F Sport for a 2015 NX 200t F Sport AWD
- Bolt-In Style roll cage?
- If you squeeze the TPMS it registers pressure pretty easily. Anyone use this method?
- Question about 2008 IS 350 w/Sport Package
- Refreshing my 2007 IS250
- LEDs inside flicker when dimming on and off?
- Side mirrors/basic warranty questions
- In need of wiring color diagram for drivers mirror.
- Temp gauge drops!
- Aftermarket Japanese Steering Wheels | Vendor Product Interest |
- Arizona Buyer beware of Arrowhead Lexus/Bell Lexus Dealerships
- Accident. Airbags did not deploy
- Navigation Problem, need input or advice
- Replacement Headlight Question
- door panels
- Duplicolor Touch-up paint for 2008 IS
- redline
- Any companys out there make custom 2 piece rotors??
- Need to replace the fuel line
- IS 250 Front Bumper Replacement Starfire Pearl
- Aftermarket Audio
- Need help ordering parts
- OEM ISF grill on ebay isf style bumper
- rear camber kit VS toe arm ???please advice
- IS350 engine whine (VIDEO)
- IS350/ F-sport owners help me out
- Techstream doesn't seem to save new tpms sensor id codes, wonder if doing something
- Revert back to park messege?
- Is 30K package Air Cabin Filter REgular or Carbon?
- IS350 Condensation in headlight
- oil filter recommendations
- Installed Techstream and getting error message "Unable to Connect to VIM"
- aux jack wire
- Did this ...
- Vibration when stopped?
- Does the is350 come in AWD?
- 07 IS250 - RWD - Power Steering ECU - Part #89650-53020
- i need help asap installing fsport intake
- Engine Bay Paint Code
- Wicked CES subbox
- 2009 front bumper spliter
- IS racing seatbelts with stock seats
- Do I need alignment on all four tires?
- IS250 AWD Preventative Maintenance @ 100k
- What do people mean with "real" traction control disable on 06 vs newer IS's?
- LED headlights replacement
- Need Help deciding between two IS350's; Opinions please!
- New member
- What to get from a pick n pull yard?
- P\S Light
- IS 350 Fsport Brakes..options
- Recommendations for where to go to get ballast replaced/fixed?
- Auto Level HID help
- 2012 is250 awd weard sound
- Is this worth the upgrade?
- Code P0023 help!
- Quickly turning into an uphill drive causes weirdness
- Big Fuse question...
- 07 is250 base
- Staggered square!?!?!??
- Replacement HID headlight bulbs
- Is it "normal" to have uneven gaps on the hood edges?
- Siren Speaker Space
- 2007 IS 350 Ground Loop Isolator or separate Aux and 12V power?
- '07 IS250 Won't Start - Dealer Can't Solve
- I'm back
- Opinion on used 2007 IS350 purchase?
- System too lean after new spark plugs
- Faulty front oil pump
- Torque Specs For F Sport Rear Sway Bar?
- Used Lexus is350 buying help
- RPM drop after letting off gas
- Clutch Failure
- Silver IS with chrome OEM wheels - photos?
- Trading SC430 on IS350C
- Does everyone's car get stuck like this?
- f Sport exhaust loud
- Front strut tower bar
- My HID headlight and LED DRL conversion (with pics)
- Lexus NX Motor
- 2009 AWD wheels rotation sound at high speeds?
- how do you do this to your engine bay?
- Bought an IS350! OH... and got rear ended.
- IS250 AWD + Varrstoen ES2 question
- IS 350 Alternator Replacement Advice PLEASE
- Winter Vehicle
- I know this has been discussed, but tall drivers in a 2IS?
- Tire fitment questions ISX50 on 18x8.5
- Best Camber Correction Components, Bushings etc. for moderate lowering on coilovers?
- SARD Body Kit
- Navigation question.
- Finally!!!
- New Member to the IS family. quick questions
- Anyone ever order from Race Consulting Agency?
- Transmission engaging problem when cold start
- Want to reach novel japan
- Help Transmission problem
- the PCM/ECM processor fault
- 06 Lexus IS250 Awd shuts off while driving and doesn't start?
- Removing center console for Aux jack access
- Longolexus on eBay Rocks!
- Rear parking sensor no beeping sound
- 2is with 3is base rims?
- How to know if my ride is equipped with Mark Lexington audio?
- who has VR TUNED OBDII PORT TUNE AUTO FLASH LEXUS IS350 | IS250
- Warranty enhancement Notification
- First impressions driving in snow
- How to turn off "traction off" text when traction control is off
- Should I Replace One Rim?
- Too good to be true? IS 350 Price
- Does axle back exhaust really add any HP?
- Differential issues
- lexus sewell parts
- wheel spacers
- coilovers or springs/shocks in a snowy city
- Will this double din unit "Parrot RNB6" work with our IS?
- Bike rack?
- Body damage for 06 IS250 - Help
- *ClubLexus Guam Shoot*
- DRL on with HIDs?
- What do you guys think?
- Lexus Boot Logo / LogoTool.exe for FlyAudio / RoadRover Aftermark GPS Units
- anyone replace the front signal bulbs 2011-2013 IS?
- Anyone running BC Coils with 16k/12k Swift Spring or similar
- Non-staggered tire replacement?
- Front door rubber grommet/plug
- Road Trip/Moving from NYC to Houston
- Cylinder 2 misfire issue please help!
- Warranty expiring - anything I should check out?
- Cold Brakes Squealing
- what to start on first?
- About to make a move on an IS350, couple of options questions
- DIY Paint Chip Repair - Starfire Pearl (PICS)
- is this right or what?
- 07 IS250 temperature fluctuation - thermostat
- It's 2015.. Do you guys still use your NAV systems or your phones?
- Any good JDM parts to buy while in Japan?
- Is there aftermarket external tpms sensors that are compatible with lexus?
- Chin spoiler question
- Hi! Random Questions
- 06 IS350 excessive oil consumption
- 2010 is250 is not starting
- No A\C nor Radio - 07 IS250 RWD
- Aftermarket door courtesy lights, show me what you've got!
- What is the lowest pressure we can reset tpms with?
- Hre wheels
- Best and most useful modifications
- Possible to upgrade/modify IS350 seats?
- SlammedEnuff x Heyarms Feature !
- Steering knuckle rubbing rim after lug nut replacement. '07 350
- 2009 IS250 rear ended, any advice during repair?
- 09 is250 grill surround BSP on SGM?
- Must-have accessories/customizations for stock IS250
- Lifting a 2is... Jack issues?
- Check VSC, check engine light, & traction control
- Does an 07 IS350 have more headroom than an 06 IS250?
- Thoughts on this intake??
- Headlight Opinion/Help/Suggestions
- GEN5 Nav OEM Screen Specifications?
- Front passenger side of moonroof sits low
- Can anyone link me to some rotors that wont rust?
- Temperature Problem
- P2017 code after spark plugs replaced
- 07 IS350... No way to tilt or adjust steering wheel??
- Battery recommendations and install
- Tires question
- Used 07 IS350 purchase - is this service history a red flag?
- No love for Deep Sea Mica?
- What is this wire?
- Is there something wrong with this IS? (Carfax)
- Who here uses their ISX50 as a beater? What is your garage queen?
- Whats a good price on an 06-08 IS350 with 70k-80k miles?
- Help me! My car won't start...
- Think I have a universal joint on its way out
- which path should i choose?
- Bad alternator?
- Odd smell coming from transmission? Help!!
- Another LED Headlight Question
- Suggestions for 2011 IS350 AWD?
- 2008 IS350, 75k, at a dealer w/ small cosmetic issues
- Car will not start....HELP!!
- Replacing headlight bulbs?
- Steering wheel remove and replace
- Moisture in the DR Side headlamp and the light is out
- No More Trunk Slam [Wald Spoiler Owners]
- TPMS Nag lights 2008 IS250
- car issue
- stereo power button not working!!
- Magna flow resonator?
- Wow check this out!
- Tail Lights
- My P0430 story
- Oh btw
- Fumoto Drain on IS 350?
- Hibdon tires messed upmy rims!
- Guys and gals
- Better pictures with the new wheels
- Hello all.
- quick question about tire sizes
- 2012 Head Lamps on a 2010
- That tape job though...
- What do 2IS owners think of the 3IS?
- Bought my first Lexus — boy, am I happy!
- LED headlights
- looking to join the Lexus family... What am I getting into?
- Bagged Riding Height? Bagged members, come through!
- Christmas Sales
- Picked up 2011 IS350 F-Sport
- sewell flush roofrack
- My newest OEM mod - 2013 GS F-sport seats in ISX50
- Seats killing my back
- Whats the difference between these Megan Arms?
