- Issues with 2008 IS250
- clicking noise when turning left?
- Abs light
- Electrical Nightmare - 2008 IS 250
- Newbie
- Lexus IS250 2009 Check Headlight warning
- Anyone know what part this is?
- Non-ML subwoofer subwoofer direction
- Fender Flares and Wheel Spacers!
- 2006 is250 power steering, light ,a fix
- Need opinions of potential IS350 purchase.
- Need 2008 is250 passenger headlight plug/harness wiring diagram
- Use of NOS (Nitrous) on IS50
- 2IS w mods swamped in flood, CA =(
- Problem with brightness on passenger headlight harness, anyone have schematic
- Transmission problems
- 2012 is250 no start
- MAF Problem Running Lean!
- VLand headlight night time and brights not working help
- Replace rear ABS speed sensor
- 08 IS350 doesn't shut off. Multiplex control module issue?
- Key not detected, car wont start
- 2008 is 250 no sound out of speakers
- is it possible to update the 2006 ml nav unit to the updated ml nav unit?
- 08 is250 6mt transmission leak/crunchy gears
- How i finally fixed P2757 on my Lexus IS250
- Sticky Cracking Dash IS250
- Invidia midpipe gasket
- 2018 Lexus IS 300 Grille Upgrade
- 2011 is 250 alarm has stopped working
- 2010 Lexus IS250 Shifting Problems ?
- Bumper Conversion
- Wanting Ash Trays
- IS 350 Cylinder Heads
- Dreaded P2757 but with a twist
- Need advice on 2006 is250 seats
- 2IS flocked dash
- After market head unit that doesn't affect backup cam and steering controls
- Rear Electric Window Shade
- Sorry, bad at navigating forums. Looking for an Apple CarPlay + backup cam solution
- What to do with TPMS when getting new wheels
- 2012 is350 grinding/razor sound upon acceleration in sport mode
- How to fix hard shifting in low gears for $12
- 2009 IS350 rear speakers super quiet
- Looking For Opinions On The IS250
- B1921 Code (2006 RWD Manual IS250)
- Valve cover broken by hitting the chain
- B1861 Code on 07 is350
- What kind of problems is this going to cause....
- Colour code for F Sport branded accessories
- VSC skid control location on diesel
- Just want to rant...damn rust.
- My is250 experience, my fixes, mods , current issue. 2nd key won't register
- Lexus replacement part websites
- 2013 glove box to a 2006 question
- 2008 lexus non-ML stock subwoofer direction
- 07 is250 really really bad gas mileage.
- Lexus is250 cranks gets fuel and spark no start
- 07 IS350, cannot find source of oil leak
- 2008 Lexus IS Not starting at all. Maybe immobilizer issue?
- How do I open my door?
- 2008 is250 camshaft position sensor code PO348 help
- Does new ECU need to be program?
- Driver seat back really noisy when moving!
- Was it worth fixing my car?
- Rpms drop around 2k rpm then shoot back up. Also does this after letting of the gas.
- 2009 is250 running rough idle.
- Engine noise after oil change??
- No Heat!
- 07 IS350 Headlight not working
- Recommendation for floor jack
- 2006 is350 or 2009 is250
- O2 Sensor Help
- correct procedure on replacing high pressure fuel pump on 2006 Lexus is 350?
- 2013 is350 F sport
- LCA bushing replacement help
- Which O2 sensor gives P0420 error code??
- Navigation screen connector help
- Xenon conversion kit for IS250 2006
- Audio&control upgrade
- VLAND headlight Install Issue
- Suggestions
- Need New Horn!
- android radio issues
- Steering wheel creaking/rubbing sound
- Check engine light/ Car wont start
- How can I reach this O2 sensor?
- Knocking,rattle sound when turning steering wheel at high speed
- Hose part number
- 2012 IS 350 F Sport ticking engine sound?
- '09 IS250 ex-auction no keys, new Fob/blade no steering lock actuating
- HELP - Headlight Condensation -> Headlights Broken
- Help with Air bag light
- Is250 cranks but wont start after replacing alternator. Please help
- Is the engine splash shield 100% necessary?
- Need help TRC issues IS250
- How to remove AWD diff fill plug?
- NEED black painted primed front bumper cover
- aux not appearing
- Torque wrench setting help
- IS250 2012 - weird behavior of front DRLs
- Anyone run PTR45-53082 19 x 9 Square Set Up?
- 2007 IS250 AWD AFS issue
- High Beam Headlights don't work
- Failure to start engine.
- IS250 RWD vented vs non vented rear rotars
- Car turns off itself
- Bluetooth blues
- IS350 Banjo Fitting Question
- spacers for new wheels
- Trac off cel 2012 is250
- Jacking up 2IS?
- Engine Light On
- 2007 AWD Is250 can’t find out source of vibration
- What's going on here?
- Help please :(
- P0420 code only pops up when driving in the city..
- Battery Drain - HELP
- Need Help- Numerous Codes, Car Not Starting; 07' IS250
- 06 IS250 screen not working after replacing digitizer
- Servicing electric motors/gears
- p1235 + cylinder 1 misfire code
- Eibach Pro-Spacer Help/Question
- What is this noise?
- IS250 intake manifold runner position sensore P2017 and P0300 codes
- Is250 2010 issue help please
- Front CV Axle Seal Leaking (passenger)
- F sport axle back for sale?
- 2006 IS 350 / 2GR FSE Rough low RPM when on load
- Interior Cleaner for "Oxidized" Door Panels - 2006 IS350?
- Market still hasn't adjusted
- Driver Side Firewall Access
- IS250 6-Speed Concern
- Water soaked floor mats after AC grommet has been removed
- Best sounding muffler for catless is350?
- What could this be?
- Unlock wheel without starting car?
- Air conditioning compressor pulley query
- Change Timing Chain??
- Will a 2isC dash fit in a 2is sedan?
- No Interior power when car is off
- Urgent Help Please with Photos!
- 2011 IS250 110K Maintenance Question
- No Low Beam Headlights
- What is this scary noise?!?!
- Where is Cam sensor connector on 2011 is350 ?
- Interior trim clips
- door locks
- F Sport Chassis Brace worth it?
- Car turns off randomly
- 2006 IS250 Won't start
- Professional Powder Coating & FIX for Corroded Lexus Rims
- NOT STARTING!!! need help!!!!!
- Another P0420 post
- Front driver actuator
- HCmotion rear lights - Code C1249
- H&R wheel spacer
- Amp/Speaker installation
- Help What's wrong with this Bumper?
- IS 250 Strange Rattle When Accelerating over 5000 rpm (with video)
- Lexus IS 350 Help!
- upgrade 06 no lit gas/trunk button to lit version?
- Unlocking Steering Wheel with Dead Battery
- IS350 Burning Oil Question
- IS350 Engine swap question
- Question about documents in Tech Manuals
- Help! Cold Start Engine Dies!
- IS350 Dodged A Bullet
- Octane Booster Damage Engine/White Grey Exhaust
- Hesitation & Poor Fuel Economy
- 2006 is350 engine operating temperature
- Front Fender Bumper Retainer Clip Orientation
- Check headlight system warning message after replacing headlights
- Rattling under car (2006 IS250)
- Charge Speed Rear Spats
- Lever on the bottom of headlights
- Side mirror problem after bulb replacement
- Owner's Age Poll
- Does anyone know the Current rating of 2006 Lexus is350 fuse link?
- USB Music Port not working
- Signal don't flash when unlock or lock
- Auto-levelling motor question
- Is250 2012
- Buy OEM Headlights? 2007 IS350
- Where to buy altezza style grill?
- Optima Red Top Battery Suitable for IS?
- HELP - I'm Desperate... broke off 10mm bolt that holds in ignition coil
- 2006 is350 rear sub popping/knocking sound
- 2012 250awd idle problem
- Is it A tire Noise or Something else? Help
- Navigation System Backlight Broken?
- IS250 OBD2 errors and engined doesn’t start
- Another P0456 Thread
- IS250 2008 gasket
- 2011 lexus is 250
- My lexus is 250 stopped on motion with smoke
- What could be wrong - going to be a shot in the dark
- Do the OEM brakes still squeal?
- Low engine oil warning--dipstick shows full
- RH front speed sensor - aftermarket OK?
- Replacing TPMS Sensors
- 2009 IS250 current draw when sitting
- Gas Leak - Rear Passenger Side
- Starter Intermittent then no crank - SOLVED
- 2009 Lexus Is250 AWD front and rear differential fluid
- Ecm location
- how to disable tpms system?
- Very high pitched noise coming from front right tweeter and burnt electronic smell
- TPMS light came 3month later after clearing the code
- Electrical Issue
- Transmission service at dealership or local mech?
- Bumper Stop
- 2007 IS350 chirping noise
- Check engine and check VSC: P0116 and C1201
- Interior lights fuse blows as soon as door opens
- Lexus IS250 & IS350 | The Best Used Luxury Car! 360,000KM Ownership Review
- LC500 Push Start/Stop Button Swap
- Driver's door pocket not closing fully
- 0w20 on 2008 IS250 AWD
- HELP - IS250 NO START after sitting for 2.5 years
- 3 Broken Front Axles in 1 month - HELP!!
- Roadtop 8.8 inch carplay system installation
- Transmission Replacement - A960E
- Battery dead, Car started smoking when I tried to turn it over.
- 2010 IS 250 Transmission fluid filter questions
- Help! I have an unusual noise in my engine!
- IS350 Engine Shuts Off and Won’t Start
- wil these lowbeams work on my is350
- I bought the most controversial sterring wheel ever
- Carbon build up or something else?
- Door Open Warning Light
- Electric Cooling Fan on Driver Side will not Spin on High Speed.
- Front Right Headlight Not Working
- Install auto dim rear view mirror
- Weird transmission problem after replacing !
- Reverse camera Wiring help
- 08 IS350-HARSH INTERMITTENT Vibration @50-Tires/wheels OK- Not RPM based-Low Mile car
- CEL,VSC, TRAC off, lights on
- Window off Track
- 2007 -MAF sensor fault code PO102
- Overheating
- Bumper cover sticks out past the fender
- Nav screen blacked out
- Just bought an IS. Audio advice?
- Does the navigation screen fade with age? (Can't see screen w/ convertible Top down)
- Vantrue N4 Dashcam Installation on 2008 IS250
- IS Aftermarket Headlights Adpative - Auto Leveling?
- 2006 IS250 P0756 and P0335 codes
