- Using smaller than stock wheels?
- 06 IS250 AWD rattles/n stuff
- Clinched widebody kit
- Knocking sound while turning on wet
- IS350 Muffler delete + resonator delete // fuel economy
- Interesting tire wear... bad fitment? *pics*
- Replacing Front Lights
- paying to maintain '09 IS350
- 2nd Gen IS250 Model Year Recommendations?
- 2006 Lexus Is350 Injen SRi
- Intermittent brake issue
- Fs goes only in the classifieds.
- JDM Parts
- Install 6th gen nav in 2009?
- Techstream Recommendation
- Help with P0328: Knock Sensor 1 Circuit High
- Ac turns off.
- 07 IS250 Front Pass Wheel Hub Assembly Help
- New shift knob idea
- 2006 IS250 awd hood - engine bay seal
- Quick headlight halogen question
- Anyone members have this spoiler? IK type, looks like a wald rep?
- Freshly washed & waxed
- Where to purchase oil filter etc from?
- Anyone use the OPT7 LED as a DRL?
- Am I becoming an "old guy" despite just crossing 40?
- Is snow mode bad to use all the time?
- Possible to modify shift timings? ECU chip?
- Replaced Camshaft position sensor car wont start
- '08 IS250 HID problems...
- Hopefully useful tips and tricks
- Digitizer Flex Cable Clip!?
- For-sale and Want-to-buy posts go in classifieds forums, not here
- Can somebody show/tell me how to properly put back the panel under the glovebox?
- How To Take Off Rear Spoiler?
- Headlights '08 IS250
- Front & Rear LED Turn Signal Swap
- 17x9 ET45 RPF1 fitment on IS350
- No Power on OBD 2 port?
- LED cluster needle repair
- No signal to ECU/dead - Lexus dealer 380 miles away
- Possible to fix windshield chips?
- Subwoofer help!
- Square Setup Lexus IS250 AWD 18X8.5 245/40r18
- Sport mode in IS350
- Stock 18inch wheels with aftermarket 19inch wheels
- 06 IS350 Low Oil Level comes on after car warms up
- Crank Position Sensor
- Puddle lights
- Buying winter tires and rims fitment question
- windforce catchpower tires
- Door Handle Problem
- IS250 ownership questions?
- New Lexus owner HELP!!!. 2012 Lexus IS350 AWD
- Trade in for a similar price car?
- Crap! Oil filter plastic cover missing!
- Straight pipe
- Time for new tires ....
- Broken Navigation Screen
- Can you upgrade a Base IS350 with Nav and Cam
- IS350 owners in Pennsylvania
- O2 Bank 1 Sensor 2 part number?
- P0137 error code?
- Control unit - smart key
- Straight pipe or something else?
- Bad battery or starter
- What size socket or wrench do I need, oil change
- Steering Tensioner Adjustment?
- Navigation Issue
- Cracked Mirror
- Fresh-air button causes loud buzz
- Carbon Fiber Engine Cover
- Hid question
- Is my transmission going out?
- Lighter power outlet near ashtray not working ?
- Part number 09135-53010
- Will these wheels fit my is250 AWD?
- Non repairable wheel?
- Coolant problem HELP
- Dash Cam Wiring location
- Newbie! First Mod: Grille and Taillights
- PS light on and no power steering any help
- So what do you guys do about Transmission Fluid?
- Do you think it's possible.... [true manual mode]
- F-sport springs and AFS
- 2011 IS350 No door automatic Lock and Unlock ??
- Aesthetic Mod Route?
- Question [headlight problem]
- Bulb versus ballast issues
- Square Setup on IS350 245/40/18
- Just wow..really ?
- My '07 IS350
- cam position sensor bank 2 wiring 2006 is350
- 2011 IS350 Transfer case drain plug seized ??
- Performance mods or Appearance mods?
- accidentally drove with bags airred out
- High beam/DRL Fuse location
- Help? No Start, No crank, Rough Idle...
- thinking of getting this rims....whatcha think?
- 2008 IS250 Engine Noise: Normal or Problem?
- is250 2008 engine noise or its a regular noise ?
- New need some help with transmision
- IS 250 problems, please help
- Possible master cylinder replacement?
- Don't buy Ebay valve stem caps
- A little advice
- 2nd gen Lexus IS250 Manual to Auto?
- SGM with black roof?
- What do you call these ?
- Is my alignment good with picture? Please advise
- New member
- Anyone use ramps for oil change
- How many miles is too many?
- Salvaged Title Lexus IS350
- F-Sport Intake vs. Short Ram Choices?
- New member intro
- Need help with camshaft position bank 1
- Show us your stormtrooper colour scheme (white with black rims/roof etc)
- Need help with Mark Levinson Audio System
- New Member...First Post
- F-Sport Grille for 2010 IS350
- 2nd Gen IS 3D MAXpider trunk liner review
- Brake kits
- Transmission issue, ECU question
- No backlight on cruise control switch stalk?
- Need some help and advice!
- What exactly are Demon Eyes on Headlights?
- Code P0420?
- where to buy lexus L logo for engine cover?
- Freshening up my '06 IS350
- Air ducts
- New to me Car Adventure
- Bit of a rant
- Strange Electrical Issue
- Winter tire size question
- Lighted door sills question
- Do i need to program key?
- Anyone have hic roof spoiler
- Where to buy AVS visors?
- Japan custom IS250 tail light
- Winter wheel fitment question
- 2008 IS250 Front Bumper
- My 2006 IS350 F-Sport
- 2006 IS350 - Hasn't had VVT Bolts done
- DIY Armrest Console Removal (Pics)
- 07 IS350 sound system problem
- 2008 IS250 idle rattle with unstable rpm(Misfire?)
- Exhaust Question: X or H pipe?
- Help needed shifting issues
- '06 IS350 Maintenance
- DIY Lighter Multimedia Inputs (Pics)
- Are the neck pads junction produce comfortable?
- Lexus IS250 Fitting a 2006 Bumper 2009
- Help: Steering Wheel Control w/ BeatSonic
- Update on airbag recall
- Problem with gas fill up
- Cause for fluctuating highway vibration?
- Help: Canadian Air Suspension
- Mark Levinson Audio DVD system ????
- IS350 Subwoofer
- Passenger side axle replacement. Need help
- IS350 Audio Install
- Directional tires noise
- CD player issue
- GPS Issues
- Help, need a roof rack that can mount snowboards!
- Lighted door sills!
- Help Driver seat backrest squeak
- Lexus IS250 Nitrous Question
- 1/4 mile time
- Is this what i Need to get a good ride.
- Power steering problem at startup.
- Will a 2008 transmission fit a 2006 lexus is350? Reply quick please
- K&N air filter
- Startup Rattle Sound.
- Dash Warning Lights Worrying Me
- Belt tensioner replacement
- CNA warranty?
- IS250 Boost?
- Scratched up center console amd want to fix it. Help!!!
- Best Suspension Setup to Make my 350 Feel Like an F
- 2011-2013 Front Tow Hook Cover
- New Body Kit!!
- Widebody Question!
- Side skirt extension question...
- Edfc install?
- 07 IS350 AUX not working unless iPhone connected to charger
- Where is the starter on 2012 IS250?
- Door Sill non light up to light up
- What air suspension should i buy
- Is250 2013 front lip Help
- Clear door Lense part number
- IS250 AWD Driving way too low!
- Need help identifying coolant leak!!
- Gun mounts?
- Engine Start Button Swap
- Proper way for Staggered setup. Please help!!
- What mistakes have you wasted money on your IS?
- Opinion on strange sound
- Radio changing channels and modes
- Best Coilovers to get for IS350?
- Fuel button panel fallen in - can't open fuel cover!
- Whats the name of this part and where does it go connected?
- Be careful when ordering HID kits from innovited on Amazon
- I want to switch my headlights HELP
- 2006 Lexus Is250 Life Span? Life Expectancy? Highest Mileage ?
- Brakes, ABS, and P/S Lights turned on while I was driving my IS250 2007
- Rear Trunk Emblem
- mirror tilting acting weird
- Lexus IS250 2007 - Codes help
- Headlights Need Help
- please helllpppppppppp~~~!!!!! [with question about broken tie rods]
- Anyone here with an X pipe?
- New member, old car
- Lexus IS250 Knock Sensors (55 Plate) - Any info appreciated
- Swap for newer (3IS) front end?
- A/C / heater fan stopped working
- What Is Quietest Most Affordable Exhaust?
- Is there a way to install Hella Horns easily?
- MY RIDE! A Modified 2010 Lexus IS 250
- IS350 Thoughts
- VSC, check engine and traction control light went off
- Swapping Rims '16 to '07
- Oil change/Transmission fluid
- Suspension bushings replacement?
- New member. 2008 IS350
- IS250 high flow fuel injectors?
- Would this subwoofer system work?
- What do i need to know when buying this '09 IS250?
- Taped down connector in front driver/passenger door?
- New wide body kit from Clinched for 2IS
- 2011 + Grill Emblem Question.
- Purchasing high mileage IS350!!!
- No Sound after Rainy day
- Help!? IS250 Down, Need a picture of Camshaft Sensor Wiring
- What's the best setup?
- 2006 rear brake rotor replacment question. *pics*
- Request Info On Trunk Emblem Spacing
- Best oil for 90,000 miles on is350?
- Custom Bumper
- Pic Request: OEM f sport grill + hella horns
- Goodbye Club Lexus
- Lexus IS 220d - Eberspächer, right timer for it
- Smell and see fumes from fuel door
- Squeaky rattle near center air vents
- Stinky smell after turning off AC
- 2006 IS 350 - potential new buyer
- hot temps = auto crack open window?
- Wrong Lift Point Bent Rail?
- 2010 climate/radio compatability question
