- What loaners are featured these days?
- Stock rims
- Amplifier: IS250 (2007) 86180-53110
- Has anyone ever replaced the transmission pan gasket?
- TPMS ?'s
- Tire studs replacement IS250
- whos here still have their 2006 is250 ?
- Engine sounds weird? Help!
- Bluetooth problem
- Is the 2008 Lexus IS 250 still worth it?
- Lexus IS 250
- Stock exhaust - driver side exhaust tip hanging much lower than passenger side
- 2009 Lexus IS250 engine noise
- JoeZ intake
- Parking Lot Bumper Hit--Damaged??
- 2007 IS350 Code C1203
- IS350 video out on the standard nav
- Aftermarket exhaust question
- Just Purchased '10 IS250 AWD
- Paint coming off rim
- Radio issues (sporadically works)
- IS 250 Heater only hot when engine reved up
- New here. Shopping advice? Want IS250 w/manual, F sport?
- Best online shop for IS250
- 20's rims
- Code meanings and advice
- Need your opinions on purchasing a high mileage 2006 IS 350
- IS250 2010 - seeking advice for work needed on my car
- diagram audio / navigation for Lexus IS250 / 350 2011-13
- Relocating Stock AMP to inside Cabin or Replacing with Aftermarket AMP ?
- Performed IS250 Spark plug change.
- How much $ can I get selling my 2009 IS350
- Just got my 2011 IS350 F-Sport !!!
- New Side Sill Extensions!
- My thoughts on my IS 6MT (so far)
- No Sound from IS250
- Light Bulb under shift knob
- Aftermarket Steering wheel info??
- What wheels are these...
- pulling the trigger
- Back in another 2is
- Fuel injector replacement
- How long are you waiting for your Sticky/Cracking dash recall?
- Question 1: Who's replaced their low beams
- Intermittent vibration at idle, different to other threads
- PPE headers and PPE full dual exhaust
- Lexus IS 350 2006 Starter kit
- 07 is250 Head Unit Replacement
- New to me IS250 6MT
- Not UR Typical MAF problem
- Electric Cutout
- Lexus IS 250 pics | Old San Juan
- Finally Got My Lexus!!! <3
- Question about Throttle Body Removal
- plastic under shift knob
- Spacers needed with stock wheels??
- 2007 IS250 Rear Differential
- XM Radio Issue 2008 IS250
- Help 06 suddenly died and starting problems...
- Scratch fix
- New to Lexus/forum, searching for parts!!
- Need cheap but good spoiler and diffuser!
- Issue with Mark Levinson sound system
- Weird noise coming from Engine when high humidity 08 IS350
- Need help to id this package
- Brake Pad and Rotor Advice Needed
- Need HELP adjusting audiocontrol LC7i!
- Question about headlights
- Alibaba 2006 Headlights?
- Question about throttle body cleaning
- TPMS Check System
- Need a front bumper, but from where?
- Spare Tire replacment?
- Strange gunk/residue appearing on back seat.
- anyone purchased the VIPmotoz headlights for the IS250
- Problem with navigation
- Warranty fix
- CAFLOR Industries test
- Side-view Mirror goes Left/Right, but not Up/Down
- Rear speaker in Lexus IS350
- Best Wheels for IS???
- which is better ? [Shell gas and carbon buildup]
- Plastic film on temperature and radio dipslays
- SSR wheel F-sport BBK man cave table
- Wheels fitment
- Any aftermarket options for replacement 2008 IS 350 stereo/nav/climate unit?
- help!is my wifes car totaled?
- 2009 & Newer Sticky Dash?
- Towing jet ski/small boat
- 2010 IS 250 AWD Battery Completely Drained, Tried Jumping Alarm Sounds
- 2012 OE replacement headlight
- Left front catalytic converter replacement
- P0304 keeps coming back
- White to black navi screen function
- Replacement bulbs for fog lights, upgrade
- 06 IS 350 completely dead
- Anyone Have These Wheels on???
- Seat heater/ cooler lights not working?
- Is it Possible to install a 12 inch subwoofer in the trunk of a 2010 convertible IS?
- Infamous ERROR3 06' disk changer question
- Stolen key fob/smart key, can I remove it using techstream?
- Questions about 2011 is350 awd
- GS430 to IS350? You opinion please
- AFS Off Light Blinking 2008 IS 250
- IS250 6MT and gasoline
- IS250 tail light issue (Inner tail light blinking)
- Anyone got a bumper from ebay?
- IS350's Rare?
- Considering Changing Front Seats
- Timing Chain Oil Leak
- IS250 Mark Levinson
- I did it. Just put a deposit down on IS250 6MT
- Anyone running 245/40R18 in front?
- Carbon build up advice Lexus IS250
- Non lowered IS wheel pic thread
- 2011 & newer issues thread
- DIY: Lexus Centercap Emblem Transfer
- Rear Tow Hook... possible?
- LED DRL Strip IS350 2011 - Quick Question
- Loud squeeking after oil change
- 2nd Generation Production Numbers for USA
- iPhone 7 doesn't connect via bluetooth
- Philips Ultinon's 6200k D4s
- A few questions about my '09 IS250
- 2012 IS350 AWD system questions
- low pressure a/c port
- 2006 is250 rear wheel drive with all wheel trans
- 2010 IS250 Engine Misfire
- Nav. system update
- MPG issue
- 215/55R17's on Fast Rennan's +35mm offset??
- Spark Plug Change issue
- Shiny Dash, Waiting on Dash Recall: Where to get a dash cover?
- Disconnecting the battery for '07 IS250
- Sticky dashboard recall questions?
- Need help Identifying AC vent piece part number *Pics*
- Need help with O2 sensor
- Black Sapphire Pearl, Blue Onyx Pearl, & Deep Sea Mica differences?
- What happened to the Lexus parts of Carson Toyota?
- PHOTOSHOP help IS350
- 2010 IS (7 years old) - 50k miles - change TPMS sensors during tire change?
- Philips X-tremeVision LED Fog Light
- Lexus IS350 Pulsating When Braking
- forgot to plug in MAF
- 50k miles - which new tires? Want to avoid tramlining if possible!
- AC Not Cold
- Dead navigation ????
- Audi A7 Wheels?
- Check VSC Flashes Once On Cold Startup
- Should I buy IS 250!? PLEASE HELP!
- What year rear bumpers are compatible
- IS 250 2006 Hazard lights
- Strange experience
- spark plug change 3 loose
- CD sound
- 2007 IS250 Issue
- Where can I buy the JoeZ intake?
- Need help finding part # air vent slider knob
- Rev counter needle jumps when I accelerate and then come off gas pedal
- TPMS help
- Will Tanabe exhaust fit my JDM IS350?
- HKS spark plugs.Anyone knows if they fit?
- Speed sensor stuck in hub assembly
- Considering a 2007 IS350 to buy......
- DIY walkthrough for A/F and 02 sensors
- Acura TL Type-S or IS350?
- Navigation display .... Help needed
- Looking at IS 250 high miles! Need help!!
- Is250 Facelift dates
- VSC Light On
- Carbon Buildup/Walnut blasting
- Can I swap an old auto leveling/afs motor?
- 2009 IS250 starts, shuts off and won't start back up.
- Passenger lumbar support not working....
- Continental ExtremeContact DSW06 - Vibration
- "It's an upper-end Toyota"
- '07 IS250 AWD Won't Start
- Air/Fuel ratio sensor
- LED Headlights?
- Failed smog because of F-sport Intake Carb sticker. Different kinds of stickers?
- SRS B1635 code?
- 2009 Lexus IS250 (Need Help ASAP)
- 2006 is350 (Neutral acts like ignition button )
- Smoked
- 2007 IS250 AWD Used <- Thoughts on this one
- JDM 2012 LED Headlights - Compatible?
- 2008 Lexus IS250 AWD: Heater blowing cold air, please help.
- Nav to Non Nav Conversion
- TPMS "Check System" HELP
- Converting 12V Lighter Charger to USB??
- Need Help with my 07 IS250
- Did stock 06' IS come with tint at top of windshield?
- IS250 2nd gen Clutch and Transmission
- Clear coat flaking off
- Switching from 87 to 91 Octane Gas
- 2is Red Outs/Smoke
- Oxygen sensor
- Fuel injector problem... Open circuit
- Seafoamed IS250 2007
- vertex body kit!
- I think I bought a lemon...
- Diagnostic tool
- Do all Toyota oil caps fit all models?
- Change front bearings, ABC, TRAC on now
- Transmission Failure
- Replacement Brakes - Pads and Rotors
- Selling 2009 LExus IS 250 :( Advice Carmax
- Lexus IS Series Dash Kit for replacing radio or navigation
- Swapping Navi to Non Navi
- After replace alternator, "Check Air Conditioner" on
- Aftermarket headlights
- identifying sensor?
- what bolt will fit this?
- Alarm beeps 4X on unlock
- Joining the Lexus family. Please Help!
- Will 07-08 tails, fit on 13'?
- 2008 lexus is250 blowing cold air
- Code error fix
- Iphone 6S bluetooth
- 08 IS250 - Intermittent No Sound From Radio
- TPMS compatibility
- 2009 IS250 No Power
- Is350 Dash\Interior panel replacement
- Just finished my video review of the IS350
- Trunk difficult to lift, is the hinge or assist mechanism broken?
- navigation screen and buttons have no power
- What's your next car?
- Anyone here got the quik latch installed in their bumpers?
- IS 350 - Chassis Part Help
- Hot Rotor
- IS250 Smoke and Oil Consumption Problem
- 2008 IS250 Carbon Build Up Warranty
- Is250 sitting for 2 years
- Reversed polarization of jumper cables
- Is a 2009 IS worth it?
- 2006 IS250 RWD 18" Summer Tire Recommendations?
- Need help changing OEM headlight bulb to led bulb for 2007 is250
- Aux armrest with aftermarket radio question?
- Radio problem
- New here. Need help on where to start...
- Throttle Blipping IS350
- Pedal commander...
- Engine Rattle 2009 IS250
- Oil catch can
- Rev Match Downshifting
- Newbie, Just got my first IS250!
- Scosche dash kit for 2IS questions?
- Right wiper arm failure
- C1249 Stop Light switch relacement
