- Check VSC, ABS light on, AFS flashing
- 2008 IS Bluetooth Strategy
- Fsport 19x9 squared fitment
- Will These Lights Work on my IS?
- Anyone else got this rear diffuser? Looking for pics
- Anyone with just an F-sport exhaust with no rear lip?
- 2010 IS250 Spec Verification
- Axle Issue, no idea if this is normal... [Video]
- 08 is 350 spark plugs changed
- Rattle From Engine @ Startup
- New Member in North Austin
- Flyaudio screen not working
- Which Nav disc for 2006 IS350?
- What engine oil should I use in hot temperatures (between 40-50 celsuis)
- Vossen wheel on a 2010 is250
- So Cal Car Meetups?
- Low Pressure A/C Cap Location
- What's the latest on aftermarket navs?
- Ventilated Seats Seem to not be Working :(
- Interior front and rear door panel replacement
- Steering wheel restoration/replacement
- Daytime running lights/High Beam issue
- Rear struts - aftermarket suggestions?
- BCR Coilovers Max Ride Height
- Need to replace wiper blades
- Techstream help ATL Area
- What connects here?
- need help on removing factory rear spoiler please
- 2007 is250 radio replacement
- New Lexus owner - Need help to find a part
- Car 1 Year Anniversary
- Does a flush stops An engine from burning oil?
- Manual Transmission Issue
- Need help with getting new front bumper for 08 is 250
- loosing acceleration while in a curve
- Help asap need answers [A/C problem]
- Check VSC After Replacing Headlights
- New Garax HID bulb flickers and turns off
- Good price?
- Need help sourcing this part
- Brake pedal clunk / step down -NEED HELP!
- Anybody running trans/oil cooler on n/a or nonturbo engine?
- Engine cover emblem?
- Megan Engine Mounts
- IS250 manual trans tunnel
- Smoking Rear Brake Rotor
- Panel came loose(Ran over curb)
- Mark Levinson amp
- LED headlight bulbs
- 250 owners...do you look for low NOACK oils?
- IS350 Gasoline and Coolant smell in cabin
- Fixing bad hood touch-up job before doing a clear-bra?
- Help identifying this Lexus IS250.
- Engine Issues
- Left turn signal inop, right turn signal good...bulbs are all Good.
- Left turn signal not working, right turn is ok...bulbs are ok
- Curt Hitch
- Window Malfunctioning
- Aftermarket NAV unit
- spots on the "chrome" of the front grill
- Cabin Air Filter - Doh!
- AC Question
- Diagnostic Coupons
- Radio Changing Volume & Channels on its Own
- Help pricing my car for sale
- trouble shooting tis for these codes: P0037,P0038,P0057,P0058,P0141,P0161; Oxyge
- New to all of this-IS350
- Question about 2011 model year
- Dash needles out, have question about replacement
- Megan midpipe
- Big touch screen android control panel, is any one interesting?
- Can anyone ID this spring I found on the floorboard??
- Should I buy a power train warranty?
- NAV wiring for NON-Navigation IS
- battery dead, tried to jump...wouldn't work
- Windshield Cracked! Where To Get A Used One?
- GFX Front Lip for 2006 Lexus IS350
- Headlight problem!!
- IS250 door error
- Help: New Part Numbers for Dashboard and Door Trims
- EBC front rotors don't fit?
- Is this what a broken front axle looks like?
- Hi guys, can someone tell me what lips these are?
- Considering purchasing high mileage 07 IS350, assistance requested
- LED bulbs and CANBUS
- 2008 isx50 steering wheel upgrade
- Techstream connected, many systems not supported or not available
- Lexus Is 250 2009 smart key problem
- NATO Smart Mount Cell Phone Mount
- Tire option
- Important! IS Dash/door panel replacement recall
- DRL/Highbeam Upgrade Question
- Transmission flush
- code P0348
- High Mileage Oil
- Transmission Wire IS250 Replacement? P2714 Solenoid Stuck Off
- Headlights and DRL's suddenly uneven
- Plastic clips missing on JDM visor
- where to buy replica AIT rear splitters DL.?
- Ikon Motorsport?
- Can Techstream program VDO REDI TPMS sensors?
- 08 IS250 AWD Fitment on stock suspension
- Need Help For Project For School
- GPS DVD stuck inside the drive
- 2006 IS250 Question [headlight upgrade options for factory HID]
- For sale ads go in classifieds, not here
- Wheel bearing Replament - Check VSC 4wd
- Air Suspension Dampening Settings
- Hand operated e-brake in IS350?
- Nav
- tire pressure monitoring system (module)
- Aux/Cigarette lighter power alway on
- Paddle shifter while in drive
- 2010 IS350 - Paint fading and clear coat peeling on plastic parts
- Need to set parking brake to start engine??
- K&N engine air filter vs stock
- 07 IS250 Won't Start HELP PLEASE!
- Make parking lights to DRLs?
- IS250 need a little help with a part
- Lighting help on my 2007 IS250. I need guidelines, information (etc.)
- Advice Needed on Headlight Upgrade
- 2011-13 350 issues?
- differential fluid
- Japan Racing Wheels 19 inch
- IS250 mirror color damage
- Paint the rear diffuser? Or matte black
- 2012 headlights repin
- Will a is250 seat fit a is300?
- Thoughts on cars from auctions?
- Check Engine Light and others
- I need some help !
- 2012 headlights
- Engine cover
- Replaced alternator and car wont crank!
- H11B or H11
- Used IS Counseling
- Question about headlight lens
- Lease buyout
- Intake Air Box question
- Halogen Fog Bulbs
- Advice Needed: Purchasing an IS250
- Need a new keyfob for newly purchased 2011 IS
- 2010 IS350 passenger seat belt occupant sensor help!
- 07 IS350 Battery or Electrical/Alternator Issue?
- Lexus IS350 power?
- 2008 is350 driver side hid dropped
- Prolonging the life of my 182K is250
- Did anyone here upgrade their lense on their 2011+ oem led headlights?
- Sub/amp install on non ML 2is
- Replaced 2008 IS250 HeadLights with 2011 IS250 Headlights
- Issue with A/C and Radio Display flickering on and off
- anybody installed the scosche LS2151B ??
- Question about VIPMoto Headlights
- Clicking noise help?
- Exterior Side Panel/Moulding Damage
- Check VSC, NO CEL
- Is250 Transmission Diagnostics Partial Guide
- Can someone check this 350 for me please?
- Radiator cooling fans both work on low speed
- DIY Sketchy Muffler Delete
- Driver's Side Rear Wheel Clicking
- What color temp are these headlights?
- Clean your exhaust tips!
- Custom Rear Diffuser Fins
- Need advice on my 2006 IS350 with 132K
- 06' 130k miles... When to sell?
- A/C cleaning (where the drain tube located)
- Can't Adjust Coilovers, Help!
- Door panel clip question.
- IS250 - short block replacement $11,000???
- Plasti Dip - IS350 Chrome Delete
- Can an 08 use a 10/11 Nav/Radio?
- Just got a 07 IS350 and got a dent!
- Looking for 3is conversion bumper
- alternator
- how do i access the best information about my lexus
- Check engine & VSC light on????
- Bluetooth pairing on non nav models?
- IS200D questions
- 2009 IS250 rear view mirror and rain sensor
- Is this HID conversion or oem HID
- Grom Vline Install and Review. To the Point
- LED/HID Recommendations
- Traction control button missing
- Time for new brakes
- IS250 Tire GaMe
- Bluetooth Pairing Fails 2006 IS 250 + more
- AC compressor not turning on
- Engine noise on start up
- The beep sound my car makes when I lock
- What size tires are you running?
- PPE+Invidia catback
- Windows 1/2 open but NOT a keyfob issue!
- Door locking/unlocking
- Water Inlet piece fell out!
- Advice on CV boot repair
- Seized Rear Calipers
- Is 250 Sport mode not working
- Lexus IS 250 2006 help
- Car engine shuts off out of nowhere but lights and radio still on
- Front spoiler is damaged. Any ideas?
- F-sport exhaust Question
- My oil is already dirty at 2K on new oil.
- Line out converter loc
- New wheels set up Cars and Coffee Bethlehem, Pa
- Trying to play music from iPhone
- VSC and check 4wd light
- Aftermarket sub question
- please help with part number
- Is this suppose to be like this?
- help need to install rear camera install - wire color
- IS 220d engine twitching
- Grinding When Turning Left After Hub Assembly Replacement
- Air Inlet Door Servo Linkage
- Loud car
- Check System Light
- 2014 IS250 Fsport engine into 2007 IS250
- Reputable online JDM part source?
- Roof rattle noise near the sunroof
- Rubber strip on Chrome window trim repair
- Exhaust leak?
- Flyaudio users... how you managed to resolve airbag issue??
- 2008 is350 aftermarket wheels
- IS250 Vibration at Highway Speeds
- Will these fit my RWD is250?
- Need new axle? Need advice on Dealer quoted repairs
- Aftermarket seat options
- Installing oem trunk spoiler
- My 2006 Lexus IS350 on Airlift Suspension
- hard & pulsating brake pedal
- 2008 Lexus IS250 AWD [swap steering wheel with ES350]
- Interested in 2007 IS250 AWD
- IS350 traction control computer?
- Need Help R4 Decoder LED DRLs
- Headlights
- Vossen eBay ?
- LED Upgrade on Ebay Headlights
- Which Staggered Stock Lexus Wheels Fit IS350?
- Aftermarket boot axles?
- 250 Owner Who Have NEVER Had Carbon Build up Issues
- Starter
- Harness bar and seat install instructions?
- Emissions Trouble in Northern VA
- Need contact for ebay guy that fixes Nav screens
- Oem HID to LED conversion
- A warranty question
- When I try to open the car door with key, alarm starts
- Can Is250 2006 A960E use BRZ FRS Transmission 2013+
