- Manual Transmission Issue
- Mild lift for a 08 IS250
- P0019, p0025, p0504 after reset.
- OEM Toyota Engine Oil Filter doesn't have plastic end caps?
- 3GR and 4GR intake compatibility
- Power up cluster on bench
- Transmission drain and fill made it worse ? Need advice
- Ac power not coming up
- What is this?
- Fluid leak from underside of car
- Side Mirror Turn Signal Chrome Delete
- IS350 grinding noise when taking off
- Key fob working at certain angles intermittently
- How To Measure 0-60?!
- A/C problems in is 350
- Just hit 250,000 miles!!
- Rear door Window switch wiring Diagram
- Would a is350 head unit work in an is250
- Urgent help needed! Please help me find where to buy this bolt I snapped
- I accidentally snapped a bolt on my coolant inlet housing, am I screwed?
- Fuel Trims.
- Chasing Loose Steering
- Question about f sport intake box
- 2006 is350 starts then stalls then won't start!!!
- Midpipe suggestions in 2023
- Adding a USED to key 2008 IS250 in Australia
- 2008 Is250 screen black but AC works, Radio works, and screen beeps when touched
- RPM Arrow light
- Dead 2008 is250 manual
- No audio
- Petrol smell from the rear of car and inside the boot
- Closest alternatives to discontinued FA S5:F wheels?
- Blown back speaker
- Transmission Fluid leaking from overflow bolt
- New to Me Advice: 2011 IS250C w/ 157k
- IS350 2007 A/C problem
- Bricked
- No crank, no start, very thorough description
- CAR Cover
- Engine oil additives
- Metallic noise when turning the car. Any ideas?
- Passinger side sounds like a old movie projector
- 09 is350 Navigation "Check The System" message
- 2006 is250 code p0171
- Jacking up from the rear?
- audio
- Steering locked?
- Fix or replace headlight level sensor
- Trunk won’t open from the button
- Custom roof rack
- what OBII tool?
- Use IS 350 missing ABS fuse box
- Looking for pics of new LED headlights
- is350 hissing noise from engine w/video
- Anyone done an IS250 engine rebuild?
- P/S light no codes
- Anyone we know? :)
- noise from front passanger side
- TPMS in Spare?
- Great score or money pit?
- Code P0441 Evap Incorrect Purge Flow!!
- Fuel gauge stuck on full
- Noob Rim Question?
- What rims are these?
- Insurance trying to totaled my car
- 2008 IS250 AWD Ticking clunking sounds
- Codes P0761 and P2714
- LED Bulb Replacement
- Fuel system fault?
- 2007 Lexus IS 250 start issue
- Second key cost
- new to forum here’s my is250!
- 2008 IS250 RWD clunking noise
- Fuel return line
- Maintenance Required/Oil Change light after infotainment one was already done...
- No Communication to Scan Tool IS250
- Self done laptop tuning?
- 07 car with 2008+ dash
- No Crank After changing alternator. Good Battery!
- Rear struts
- Suspension Issue
- Used invidia exhaust gaskets
- Throttle Jumpy/Hesistation!!
- Strut or Sway bar
- JDM lexus IS350 owners what ODB2 scanner do you use?
- 2008 IS350 - Testing the Waters for Sale (LOTS of F-Sport Parts)
- Need help on where to buy wiring diagram for JDM IS350
- Check engine and trac off
- Car stalls when shifting from Reverse to Drive
- How to remove rear intake manifold bolt
- Navi system went out.
- Is250 back up light positive line?
- IS250 2010 128K miles - Considering Purchasing but Questions
- Ignition Coils/Head Gaskets Need Replacing!
- Strong smell from muffler.
- Muffler is Hanging Low
- 08 is 250 crank no start
- Issue with VLAN Tailights on is350
- 2008 Is250 won't rev past 3-4k.
- 2006 Lexus IS350 Kirby Mobile!
- So many Theads about start rattle, yet no answers.
- Replacement OEM Parts
- Interior Lights Change to LEDs
- Possible transmission/engine fault?
- tiny light in front overhead console
- Car Dies When Letting Out Clutch
- Overheating, Knocking, headgasket. IS 350 06-08
- Touchscreen frozen?
- A/C sight glass usefulness & vent temps
- Son's 2nd Car 2008 IS250 100k miles.
- 2006 Lexus is250 vsc,abs,powersteering,eml
- Fuse rad 1 and rad 2 kips blowing, radio and a/c not working
- Cold start rattle
- Heating issues
- Mark levinson amplifier
- Accidentally Reversed the Polarity on my 2007 Lexus is350's Battery
- 2012 IS250 AWD AC compressor replacement-DIY
- Help identifiying knocking, no CEL
- Help! Misfires Knocking Noises Limp mode
- Almost there…
- IS 250 C fuel tank issues
- First Time Wrapping Results
- Low pressure light won’t turn off after new wheel install
- Odometer Problems
- Maintenance on 2008 is250
- Transmission Opinion Question
- Brembo Brake Upgrade
- Prioritizing Work / 2008 IS250 (199,000)
- Transmission Drain & Fill Service Necessary?
- 2008 IS250 leaking gas between engine and trans!!
- Trunk support mount bracket defective?
- 07 IS350 - Check VSC + power loss/strange shifts
- Looking at buying an IS250 but after some honest opinions
- is250 EPS ecu compatibility
- 2008 is250 P0351-P0356
- 2006 Lexus IS350 Won’t Crank Has Power-HELP
- Is350 rattling/ knocking on startup and low RPM
- What to do about slipping 1-2nd gear
- Speed limiter not existing?
- 2006 is350 brake hardware kit
- toyota mark x parts
- AC blows cold then hot 2012 AWD
- Lug nuts for 1st gen F sport wheels
- 2008 IS250 AFS headlamps
- Speedometer making sound
- 06 is350 startup rattle but worse
- 2013 Lexus IS 250 Jerking on highway/acceleration
- Car Due For Smog Soon! Has RR Tune
- Made it to Half Million!!
- STL file for 3d printing
- 2009 Lexus IS350 misfire and under power issues
- 2009 IS250 won't start and has code P050B
- Posición del. Cigueñal. De lexus is250
- 2006-2013 Lexus IS350 Burning Oil
- Power steering not working at higher speeds
- 2012 Lexus IS250 AWD headlamp ballast
- Partnumber for damper Dust cover FA
- manual transmission is
- 2012 Lexus IS250 AWD head lights issue
- Lexus IS F Drag Races a Kia Stinger, BMW M340i
- What did Toyota screw up?
- Grounding noise from engine
- New Lightbar Tail Light Release For 06-12 IS250/350/IS-F
- lexus is350 lsd diff
- Electrical Issues
- Do all IS250 models come with heated seats?
- 06 is350 Transmission issues
- IS250 Random electric issue
- No sound for Bluetooth or aux, but radio and CD work
- Leak @ Timing Cover Gasket: TIMING COVER LEAKING OIL, RECOMMEND RE-SEAL TIMING COVER
- How can I change A/C receiver drier
- Radio not working. Help. Tried everything and still unsure
- Navi touch function not working
- What're your IS250 gas mileages?
- 2012 IS250 AWD transmission question?
- Airbag cover swap
- Bought IS250 with Nav- Almost! Advice needed
- New to me 06 is250
- Sourcing is250 6speed ra62
- LEXUS IS 200/220D/250 Manuals And Wiring Diagrams
- No tool made for removing crank bolt on any 2GR engines?
- OEM Parts
- Windows wont roll down and speakers have no sound(2009 IS250)
- 06 upper intake manifold
- Bad cats. What would you do?
- Keyless Entry Works - But No Green LED on Start Button
- Lexus Port Moody not honoring warranty! Help!
- Advics - lost part
- “Key is not detected” issue even with a new key fob battery
- How to Fix is250 start then shut off right away
- Custom Fog Light Trim
- 2011 IS250 with NAV - android options?
- Won’t Start after replacing Alternator
- ISF G2 Brake Paint
- 2013 IS250 4sale
- Broken 2nd chain - See if I can fix it.
- 2006 is250 sat for 5 months cranks but no start.
- Codes p0202,p2197 and p2241
- 3GR-FSE manual conversion help/advice
- 2009 IS 250 Alternator issues
- On going issue code P2009
- Replacing Interior Door Panels
- Need help time sensitive trying to buy 18x8.5 +45 with 225/40/18
- Front Wheel Fitment Help
- Picked up a 06 IS350 off CL as mechanic special.
- Need help finding a few wiring harnesses
- Where is ECT sensor located??
- 08 IS250 radiator cover fasteners
- Bumper Holes - EU Model
- 2014 IS350 F Sport Cold Air Intake on a 2013 IS250 Base?
- car stolen
- ask Is250 headlight and ballast
- Acceleration Issue
- Recommendation for Lexus headlight retrofit vendor?
- Lowered IS350 and 250 both rubbing on front driver side only???
- Will those wheels fit my car.
- Headlight DOT/SAE Approved? DRL?
- Tyres
- is350 recall
- Intermittent issue with ABS, Traction control, and AC
- Plastic peeling away from the belt molding
- Help: Lexus IS250 (2006) engine noise
- stiff steering wheel
- Loud screeching noise coming when heat is on
- Depo headlights US-spec in Europe
- Is250 tuning
- Headlight ballast issues
- Rear trunk lid lifts/struts
- Bulb or Ballast
- My car just died all of a sudden - need help to figure it out
- 2006 lexus is350 transmission problem
- Purchasing a IS250 07' tomorrow.
- Best Aftermarket Battery for 2IS 250
- 2008 is250 hard brake no start help advise
- New Fahren "Termitor" LED's
- Cooling fans engage with Defrost mode (NO A/C)
- Teyes CC3 Android Head Unit
- 2011 Drivers side Low Beam not working
- A pillar trim removal
- Please can i have help diagnosing codes 06 lexus is350
- Help my car hates me
- Help PLEASE
- Anyone Remove Spare Tire + Jack??
- Valve Cover Oil cooler connector/line Leaking
- I250 F Sport Wheel
- What is this!?
- Rear Differential Service Intervals by Miles or Years ?
- What is this sound coming from my A/C
- Oil Pressure Sensor Question
- Issues with 2008 IS250
