- IS250 spark plug replacement
- IS250 AWD transmission
- 2006 IS 350 - trunk latch actuator makes sound, but doesn't open trunk.
- 18x9.5s all around - 275/35 rears; needs suggestions for fronts
- Adding amplifier, what’s needed
- 2007 IS250 Passenger lowbeam not working after car washes
- Fog Light Aim
- 2IS NHTSA Recall # 16V-340, 17V-006, 18V-024: Pass Zone A
- Please help, radio/navigation issue
- start/stop switch problem (or not?)
- In Car Digital TV like JDM?
- Compressor issue on my is350
- Camshaft positioning sensor
- Vinyl wrap chrome window trim
- State Referee Ticket - Need help
- 2008 IS 250 RWD Oil Filter
- What's your favorite IS feature?
- Tire size
- Rear door / quarter panel gap
- Tire size fitment (235/45 and 245/45 and 255/45)
- Rear Roof Installation mounting question
- So boys..new too forum..Not too lexus..im bodyguy..but mechanical..advice from techs
- Relay part number
- IS 350 Transmission Fluid Change
- My is Lexus simple and clean
- Timing Chain Issue 2006 is350
- 3mm Spacers - spacer uses help me out!
- Overfilled oil IS350
- Bough this a few weeks ago...
- Can't open the window for Lexusis250
- Wheel fitment question
- Will a 2011 IS F Sport front bumper fit on a 2007 regular IS250
- Injector Driver Pin Out
- LCD screen and buttons have no power
- YA Brake Thread (Specs, brands and vendors)
- Help [seeking performance and exhaust advice for '08 IS250]
- 2012 LED headlight conversion
- no start
- AC acting up
- philips ultinon d4s legit?
- No check engine light, engine won’t turn over...
- 2006 Lexus IS 250
- 2012 headlight parts number
- Mark Levinson problem
- Looking into buying an IS
- Help with part number
- Car Alarm Ajar goes off when turning left ??HELP!!
- This IS 350 Underwent a Tremendous Weight Loss
- 2012 IS 350 What to look for?
- 06-07 IS 250 Worth Buying Now in 2018?
- Need help identify 2nd IS250 (2011) NAV connections
- Passenger and rear window don't work.
- Rx300
- recommendation on water pump 09 250
- Buying used 2007 IS350, lots of questions
- Rear spoiler tape
- Anyone here change their own oil?
- Whats this car's worth?
- Lost mileage range and loud muffler noise on 07 is250 awd
- After market Tesla android NAV system
- P0175 - System Too Rich Bank 2 Oxygen Sensor Replacement
- how do i switch navigation system on or off
- Exhaust delete cats for 2006 IS 250 AWD
- 2008 IS250 AWD eBay Replacement Midpipe?
- Anything I should be aware before I look at this 2012 IS250??
- replace shift shaft seal on a 2006 lexus is 350
- HID bulb on then goes out!!!
- Lexus IS250 Ecu fault or what?
- Aux jack loose.
- RWD Staggered Fitment
- USRC from ISF?
- What is normal compression for is350?
- How high does IS 350 trunk pop up when using remote?
- Passenger power windows not working
- 2006 is250 park, drive, neutral all lit
- Fault code
- Clicking noise at low speeds
- 2006 is250
- Faded Lexus Radar Logo
- Aftermarket fender
- Looking for IS 250 exhaust
- Sticky Steering
- Determining my trim package
- Oil Looks Uneven On Dipstick
- Rubbing sound when going downhill
- Lexus is 250 headlights
- Lexus IS 220d egr valve change or blank plate
- is250 manual owners... Launching issue , clutch clunking?
- Questions about used IS250
- 11-13 headlights
- Check engine light on p1276
- Rear brake light and indicator light don’t work
- Headlights
- Turning off TC's beep sound, possible or not?
- IS 350 Automatic Transmission Concerns
- 11-13 headlight "computer"
- DIY coolant flush
- Location of OCV filter?
- Question about fog lights
- Tire wear out uneven
- EVAP Componenet Question
- fillerneck install question
- MyLparts OEM Wheel Question
- Help needed! VVT Solenoid?
- where do you get your OEM Lexus parts?
- Front LCA Bushings. What is my best option for my daily driver
- Where is reverse light fuse?
- rear strake clips
- Seatbelt height adjuster stuck
- AFS Light+ randomly working headlight
- Change navigation system language from Japanese to English
- Tire wheel protection plan for aftermarket wheels?
- Alignment done
- Need help replacing VVT solenoid
- Camshaft connector and a broken bolt
- 2007 IS250 137k miles - High Idle on Startup and other things
- Broken bolt + camshaft position sensor connector
- 2GR-FSE expert comment wanted! Knocking??!
- IS350 - 2008 - Intermittent Blower Fan
- Check Engine Light and VSC flashing
- Looking for a salvage project
- 3M Wrap engine bay covers?
- Car won't start
- 2007 Lexus IS250 awd/ differential or trans?
- is 250 convertible smart key module
- Rough Idle and Reduced Power?
- heavily rusted fuel pump
- Anyone running 20x9 wheels?
- IS250 AWD Coilover Owners: What are your spring rates?
- Thinking of Getting Midpipe--CA Legal?
- 2009 Lexus IS250 Tail Lights
- is250 v6
- Looking to get an 06+ is350...
- For those of you that manually calculate MPG...
- 2006 IS250 Auto to Manual Swap (Any input appreciated)
- 2IS LED DRL Headlight to '06 IS350 With Factory HIDs
- AWD IS250 Exhaust Q
- Switching oil brand and weight/
- Quick latch question
- Can I use multi spark plugs in my is250?
- 2007 Lexus is250
- Yes its a repeat but dammit I need answers! [ISF conversion]
- techstream
- diamond pattern floor mats
- Spark Plug Replacement DIY
- Looking to buy first IS - 2008 IS350 High Miles/Mileage
- Do You Need To Replace All 4 Tires On Your AWD Vehicle?
- Too many lights on dash
- TE37SL: Real or fake?
- Best place to buy Exhaust?
- Spec-D Headlight question
- keyless entry driver side not working
- What is my car worth
- Is the Mark Levinson system rare in the IS250/350?
- My IS250 disabled by security/immobilizer system.
- Wheel/Tire question
- Courtesy Door Light Won't Work
- Thoughts on this Lexus IS250!
- Please suggestion on head lights. Thank you!
- OEM sub
- Excellent condition 2007 IS350
- Car Rattles Like an '87 Dodge Omni
- Offset help
- Squeaking front center vent in the heat
- P/s servo steering problem
- Replaced my Steering wheel chrome badge - worried!
- Light Bulb/LED replacement Guide
- need help with AFS won't level properly...
- 3rd gen f sport wheels on my 2007 2nd gen is350
- Should I buy this 2011 IS350?
- Car won't start
- Spare tire question
- HID Headlight Upgrade questions
- stalled while driving
- Official Break Water Blue IS Thread
- re-drill tire valve hole
- Help with Wheel specs and Spacers
- Amplifier!!!!
- OEM Rear Bumpers - Are they the same?
- Best Cruising Speeds?
- Biggest Wheels
- Should I change my Auto Trans Fluid again?
- 20" wheel question
- Shattered Sunroof Glass
- some advice on my 2006 IS250 EVAP gas leak
- Fuel Pressure Sensor on 2006 Lexus IS250
- LED recommendations for Mirror/Puddle Light replacement?
- Wow Want the is350 but different tire sizes is disturbing...
- Where is my power steering reservoir? 2012 is250
- 2006 is250 after lexus engine r&r
- Led headlights
- Remote Low Battery Warning * After Installing New Battery! *
- 2006 is250 growl
- my IS 250 couldn't start 4 hour prior to parking
- My dashboard is part of the recall program.
- Restitch Shifter knob to match New Wheel?
- Non nav to navigation....
- Modification-2008 is350
- IS350 Blank Screen
- Where to get OEM headlights?
- 2007 IS350 - Reverse and Auto-Title Side Mirrors
- 19x9.5 wheels need help!!!
- Lexus IS250 display, ac, audio not working
- check system light went on
- Heated/cooled passenger seat airbag light...
- not so new IS owner from Hawaii
- Headlight Washers Staying up after Use
- Air bag recall and heated seats not working
- Check VSC and limp mode after Seafoam
- Headlight glass
- Oil Filter Housing
- Cruise control dead. Lexus has told me the ECU for the car must be replaced.
- New lexus owner
- 2006 IS250 AWD transmission replacement woes
- Catalytic Converter/Exhaust Needed ASAP
- 2007 radio and nav works no audio volume
- Recommend me an oil catch can
- Need help on air bag indicator light on?
- Rear 255/40/18 or 265/35/18?
- Aimgain 2008 IS250
- Rattle at startup, is it worth fixing myself
- F-Sport Intake Tube compatibility question
- Exhaust tailpipes and back bumper
- Aftermarket amplifier
- Why does the 2007 IS 250 AWD get better mpg than a 2010 IS 250 AWD?
- Tires
- Passenger Headlight - light goes off and on
- Noise coming from engine when the humidity is high
- Check VCS, PCS, Brake, ABS light. No check engine light.
- 2006 Lexus IS250 VSC, PCS, Brake/ABS light?
- 2Gen Headlight Glass Repair
- OEM nav headunit into non-nav factory?
- Rod knock???
- Should I return this car?
- 08 IS350 won’t start
- 2006 is250 navi black out help ?
- Engine swap
- GSF Wheels on IS350
- Did anyone else have issues with their recalls?
- 2007 IS350 won’t start can’t figure it out
- to buy or not to buy....
- Fog Light HID
- Bluetooth feature
- Bank 1 sensor 2 help!
- 2008 IS350 cruise control malfunction
- aimgain bumper upper grille
- Passenger High-Beam and Turn Signal Stop Working Properly
- power steering not working on 2006 is250
- Alternator fuse
- 2nd hand is350
