- engine light flickers - unable to diagnose issue
- 2006 IS navigation problem
- Work gnosis hs203
- 225/45R17 94Y Front and Back on 17x7 rims
- Trying to decide which to get
- blinking afs light
- underskirting attachment
- Engine won't start - Lights came on 1 by 1 and then engine shut down
- P2009 - Possible Solution
- Is Tail light replacement possible?
- 07' IS250 AWD Dilemma
- Pricing
- Aftermarket Speaker Setup
- Bank 2 cam shaft sensor
- Aftermarket headlights
- Lexus key fob is completely water proof!
- Cleaned MAF Sensor, Still Getting Codes: P1072 P1075
- Coolant issues
- 2009 Lexus is250 possible failing transmission?
- C1236 abs code Help
- Used 2007, 2008, or 2010 IS250 or a 2007 IS350?
- low beam and fog light bulb replacement
- What bad things have happened to your IS since purchase??
- Do you REV match when down shifting?
- How To Fix Door Trim Molding???
- Has anyone ever used Valvomax for oil changes?
- Driving IS350 with Nav unit removed?
- For sale posts go in classifieds forums, not here
- Upper Windshield Molding
- Mystery Part
- DIY - 2006 IS250 Transmission Removal A960E
- Is it possible to stream Pandora thru 2011 IS350 Enform?
- Tensioner Pulley Replacement
- Need 2nd opinion and advice purchasing this 2006 Lexus is350
- P300 codes
- IS 250 20" wheel offset
- Transmission not shifting past 3rd - P0761 & P0781 resolution
- Intake Manifold Valve Issue?
- vsc abs no traction and tire pressure light and red triangle... No engine light
- IS350 132,000 maintenance planning
- Green glue stains on rear bumper
- P0031 Error Code 2007 IS250
- whats SST?
- IS250 computer problems
- Any rearview camera upgrades with IR and guidelines?
- Battery died..replaced..but now car wont start....
- 2012 Lexus IS 250 AWD Tunnel Noise
- 2010-2012 Navigation console swap
- Will these fit?
- No Rear CV Boot Kit Replacement on 09 IS250
- Bell Lexus VS Mylparts
- Jeff can you find a PN: A760E 180°f Fill Level tube
- DIY: How to Deal With Carbon Buildup
- TPMS warning after new tires and wheels.
- '08 IS350 w/o ML rear subwoofer blew. Replace with stock or upgrade?
- 2-009 lexus is250
- Replaced spark plugs now idle is 1600rpm
- Speedo gauge off by ~4mph
- 06 ML NAV no Bluetooth after screen swap
- How to remove trim on top of glove box door
- Transmission swap
- Bass Knob RJ45 to RJ11 coupler/adaptor
- Annoying clip part #
- Noise from front left side
- Electrical Issue, not alternator or battery?
- Can you paint OEM wheels
- HELP! Hit huge pothole...
- changed plugs on 07 is250. wont stay at idle
- Brake popping/clicking
- P0025 CEL code
- ML volume issue
- Radio upgrade on 2008 IS250?
- Rear wheel bearing replacement
- Help on newer model 2is Headlights on 06!!
- Trunk question
- Water Pump Replacement - What other parts should get replaced at same time?
- Hi Question About 3is Conversion
- scuffs on dash knee bolster (NOT sticky dash)
- sweet Lexus IS i shot last week!
- Passenger side dust shield question
- Value of Chrome Rims from 2010 IS350C?
- Interior dye for black beading on seat
- Odd Electrical Behavior in 2007 IS250 AWD
- check engine light after recharging ac
- Coolant Question
- 07 is350 wont start smells like rotten eggs
- Anyone know a shop that do custom splitters??
- ABC,4x4 ,VCS,Triangle light On Help
- Temp sensor location IS 250 2008
- tire recommendation
- Headlight problems (2008 is250)
- HID projector loose
- hard clunk/jolt/downshift when stopping
- lexus IS 250 won't start
- Rarity of Mark Levinson System on 2011-2013 models
- What to look for? High milage 2011 350
- tent melting?
- what was that seatbelt alar trick again?
- Where's the rear defrost timer circuit? No bubbles in Tint
- misfire code
- what’s the stock audio system ,speakers [rms] and what’s the amps wattage
- Wheel spacers question
- OBD-II Error P0430 - O2 Sensor
- 2012 is250 infant car seat in the back...
- Invidia Midpipes on 09 IS250
- IS 250 Head Unit
- IS 350 EVAP TRAP Air Box Filter
- The worlds first 3GRFSE with LMS sc kit swap
- Lexus IS250 All passenger door lock problem.
- Yellowed headlight covers. Upgrading all other lights
- New member
- Exhaust and Oxygen sensor replacement
- safe to shave/cut this part ?
- 2009 IS250 Timing Chain
- Passenger side door will sometimes not unlock but locks fine.
- how to tell if it has Dynamic Radar Cruise Control system
- no start
- 2011 is250 headlight light lens is starting to get dull
- 2008 is250 climate control not working
- Headlights interfere with Garage door?
- Best IS350 Oil Filter?
- IS350 Alternator rebuild DIY...?
- head lights
- Upgrading to 19in Wheels!
- JUST another lost new guy
- New recall alert [fuel delivery pipe] from my insurance company for my IS350?
- What is this for?
- Buying a high mileage IS250 - Smart or Stupid? My First Lexus?
- Radio dash kit recommendations
- Lexus is 220d wont accelerate and black smoke
- Quickly switch between HOT and COLD climate on Climate Control models?
- EVAP smoke test without vent solenoid control?
- Stereo Problems
- Hks dual exhaust
- Where to start with the fixes and upgrades to my IS350+ Melty Dash and Panels?
- Drag Racing Tips?
- 09 is250 Air Conditioner
- How to Install Side Mirror Glass
- HI, I'm a new. Just wanted to share pics of my 2008 IS350 and replace the grille
- Anyone Have the RR Racing ECU Tune?
- 2IS trunk lip
- HELP!!!! Cylinder 6 Spark plug covered with oil
- rebuilding a 6sp tranny
- IS 250 US Imported Missing Vehicle Setting
- What is this connector for ??
- Leaking reddish colored fluid
- 2IS eBay Carbon Fiber Roof Spoiler DIY Video
- 2IS Hardwired Dash Camera and Radar-Mirror Glass Replacement DIY Video
- Headlamp washers
- What OILS for my 2006 Lexus is350 (from Caribbean)
- Sidemarker Bulb
- Blown head gasket? 2006 IS250 179,980 miles.
- Memory Seats vs Regular
- Can someone tell me what part this is?
- Alternator replacement recommedation
- steering wheel is locked
- Chirping Noise From Belt Area
- 2IS a, b and c door pillars
- 2010 IS 250 Oil Filter Socket Wrench (Removal Tool)
- Sunroof HELP 2006 IS250 Stuck Open Rare Symptoms
- Final verdict? Purchasing in 48 hours. IS250 w 84K
- IS250 Parking sensor problem
- 2007 is250 LCD went blank
- A pillar cover gap, how to remove clip....
- Radiator Cap SPRING
- LED style DRL’s for 2006-2009 IS350
- Annoying Clicking Noise coming from passenger dash - Help! (Video)
- Interior vinyl wrap?
- excess fuel
- Hood sensor
- IS220d Engine Noise, need help
- HKS VS RR-Racing Supercharger
- could someone tell me what this is...
- Fill’er Up
- 2010 IS250 suspension noise
- Check VSC light and Check Engine light both on
- Sunshade
- Supply multiplex network location?
- Where can I find the front bumper lip????
- Lexus F keychain
- Vibrations at speed
- Can't find F-Sport bumper lip / Fog light cover
- Navigation Screen faded slowly and went black after changing battery
- Replacing Side Mirror Panel on 2013 IS250
- tpms gauge
- trying to find low side port to charge ac
- Part Numbers Needed | Bumper Assembly
- Sunroof doing some funky stuff 2010 IS350
- Coolant issue
- Check engine vsc light after changing alternator
- Michelin Pilot A/S 3+ on 19" F sport G spyders???
- Need some ideas for my '08 IS
- Erasing Lost Key Fobs
- Headlamp glass cover
- Car won’t start - issue is not battery or fob
- Headlight lens turning yellow
- Ecu
- Transmission pan slightly leaking fluid... need advice
- Does the F Sport version, really affect the ride Quality?
- AWD sub frame removal
- IS350 Temp Gauge was 3/4s high and then went back to normal after driving for 2hrs
- Brake discs + pads, which ones?
- Error when accessing the Registration for TPMS sensors
- Looking for a New Set of Rims!
- Headlight OEM HID swap to non OEM, non HID housing
- 2006 IS 350 NAV DVD location
- 2010 Lexus IS350c 135k for 17k out the door, is that ok?
- 2012 IS 250 Problem
- Key replacement need help
- How to removed center console arm rest pad ?
- 2006 is350 shifting problem
- Where do I buy this unichip to make my 2007 Lexus is250 go faster?? Also who can do t
- Noise / Clunk when shifting to Drive or Reverse from Neutual
- 07 is250 Airbag light on, horn not working
- Catalouge of trim options by year
- Doors would only unlock sometimes?
- Someone keyed my car.
- VDIM/VSC feature
- Power steering/Electrical failure
- Best Aftermarket Dash/Door Kit (Not Factory Recall/Replacement)?
- Fitment and wheels help on 2011 is250 f sport
- radiator foam ?
- ECU Diagram
- Random Shaking
- IS220d Central Locking System Problem
- Climate Control & Radio Not Working
- so, did the 2011 and up headlight issue get resolved?
- Heated seats controls backlight
- recharging AC after condenser replacement
- Flapping Noise during only during acceleration
- 06 IS250 Guage Cluster LED’s
- Lexus IS-F Cluster Swap On IS250 Check it Out!
- Is350 engine in is250 body ?
- Continental contisport contact 5 or other
- Car wont start
- What are these bolts all over the under garage for?? photos inside
- 2008 Lexus IS250 Low oil light
- Hood release cable
- Is it worth the headlight difference to buy a 2011 and up IS over a 2010?
- General G-Max AS-05 great tires at a good price!
- Shop put 255 tires up front and 225 in the back...
- How To Remove Audio Control Steering Covers?
- Help my belt wont turn
- LED DRL question
- Center console shifter boot
- My problematic day that ended up being a simple fix.
- Fuel in oil. New symptoms louder ticking sound, ash on spark plugs
- 2006 IS250 alternator replacement
- Is250 headlights
- Depressing Brake is not being Recognize to start car
