- 2IS with 14+ F Sport Wheels Tire Question
- A/C Button not working?
- Exhaust systems?
- Ac pressure switch locations
- What is this panel?
- Boslla Bullet 4-Color Bulbs Question
- 2is to 3is bumper conversion help
- Home link button will not light up
- F-Sport Suspension PN listing
- Help! Buying an is350
- 2007 IS250 Engine noise. Squeak /Scribble
- CONTROL ARM BUSHING torn questions
- IS250 Cam Gear Rattle Inquiry
- Bad U joint! Help!
- Instrument cluster question
- 2007 is350 spark plug change help
- 2007 Lexus is250 AWD Engine Swap
- Can't lock/unlock or disarm alarm but key is working
- Installing aftermarket radio on a factory nav 2is
- iJDMTOY License plate relocator not fitting
- Tire Pressure Alarm lexus Is250 2007
- Porting/polishing lower intake manifold is350
- 2008 IS250 Power Steering Issues. No P/S Light!
- Vland headlights help
- NAV screen no longer dimming at night. Driving me crazy
- No Sound IS250 (2007)??
- 18x9.5 +35 Fitment Question
- Do replacement headlamps from dealer come with HID bulb and computer module?
- 2008 IS250 turns over but wont start HELP!
- Full Length Third Brake Light / Rear Window Spoiler
- Is250 2007 awd tire sizes issue
- Question about 2011 IS350 resonator
- IS 250 Intake port dimensions?
- IS250/350 Side Windows
- Burnt rubber/Break smell on Hwy
- Is a 2006 Lexus is350 still worth it?
- Dreaded CEL on code P0430!
- Brake Bleeding Procedure.
- My IS250 AWD Story (keep updated)
- Turning Radius like a Bus
- isf 2014 Reverse gear not engaging sometimes
- Testing catalytic converter
- Repairing Perforated Leather Seats
- 2006 IS350 Automatic transmission pan gasket
- TransGo shift kit for A760E (IS350) and transmission fluid cooler Installed!
- Stalling and lower gas mileage
- 08 IS250 HID issue NEED HELP!!!
- New Member to the forum!
- AWD transmission in aRWD car
- P/S light on dashborad
- Comtrol Arm Replacement
- Wanting to buy a 2is 350
- Need O2 sensor numbers
- Brighter headlights?
- IS250 Spark Plug Change Help
- Installing a Scorsche ITCLS01B 2.0 dash kit, what am I missing?
- What are the Coil Specs?
- P0430/c1201/c1241/b1400
- Looking to buy IS250 manual - talk me out of it or into it!
- Stumped ABS, VSC, P/S, Shifter locked, Climate - Check the connection to the air cond
- Bypass immobilizer
- Dropping transmission for the second time changing torque converter
- 2016 GS Fsport Oem springs fit?
- CRC intake cleaner
- Catalytic Converter
- Still goshdarn lovely
- Check vsc
- What to look for used 2010 IS350...
- CD changer problem
- 07 IS250 Sunroof issue
- Plug melted.. nearly caught fire.
- Melting Dash and Door Panels
- Re-installed radio, now no illumination
- CT200 steering eheel swap
- Remote start options for 2IS but retain OEM key fob?
- Transmission seal on side of trans by fill plug
- IS350 Driver window switch does not work.
- Remote Keyless entry issue
- A Special SItuation
- Lexus is250
- Tesla style Android radio help
- Total Transmission Capacity ?
- F aport cold air intake
- Poor fuel mileage, poor response, sluggish and “spitting”
- Shoping for a 2IS 350 - advantage to buying later model?
- Navigation screen frozen white
- Coming Back to Lexus
- Ac compressor
- Intermittant Door Lock Issue
- Android nav box
- 2007 lexus is250 with nav radio no sound at all
- What Lug Nuts to use on Infiniti G37 Rims on an ISx50
- Identifying voltage of the tiny dome light on acc
- Transmission leak
- Limp mode
- p0304 cylinder 4 misfire
- Lexus IS350 2006 Transmission Service
- Wizzing at start wont crank
- Lexus is250 won't start
- Need help with Transmission solenoid
- Melted Dashboard
- advise on is250!
- Just sold my IS250 - my honest thoughts
- New IS owner here
- Broke the recirculating door for the ac 😂
- 2012 IS350c Seat Rub Noise on Passenger Side
- Driver window control doesn't operate the rear windows anymore
- IS350 A760E Transmission Value body upgrade (Shift kit)
- New home for my new toy
- 2010 IS250 RWD Differential Fluid Change
- CANADA region IS250 AWD Lowering springs H&R
- AC problem...
- Help with add a fuse please (vipmotoz drl headlights)
- Brake master cylinder
- Does the RWD 2008 IS250 with sport package have LSD
- Air conditionner harness , someone ever change that?
- Confirmation needed on a noisy wheel bearing
- F-sport quick shifter, Finally got my hands on one. RAREST PART?
- [EU spec] How do we customize the personalization and comfort settings ourselves?
- New Rims?
- Transmission oil report high mileage
- Is250 tempature gauge above halfway is it normal?
- Steering issues after Rack Replacement
- Camshaft Upgrade
- IS350 seat swap questions?
- Paint Code for rims !!!!
- Do any of the later model 2nd gen homelink compass mirrors have backlit buttons?
- Radio Turns Off By Itself
- Fuel Pressure Sensor issue after getting car serviced
- Aftermarket resonator question
- Super sweet IS at Tuner Evo Miami!!
- how many mA during parasitic drain test on 2009 is250
- '12 IS350 body parts
- DRL not running in tandem with low beams, help?
- Replacing Factory Navigation Infotainment with Non-Nav
- touch screen is250 frozen
- Need help, broken navigation tab
- Engine ticking after some fast driving, any ideas what it could be?
- how have you set up your electronics in the cab?
- Those that have changed trans fluid
- Is it possible to swap the drivers seat itself with the passenger seat?
- What is the best transmission fluid for 2is 06?
- Does the 2011 - 2013 IS250 front bumber fit the 2006 - 2010
- CV Axle
- Mrs. Fire
- Side Window Sunshades
- Should I get a midpipe? - IS250 AWD Exhaust Upgrade.
- Is350 / Is250 dash removal with video
- Do any of the 2IS with ML have Bluetooth audio playback?
- HID kit not working if plug-in MAF sensor!?
- Any options on where to get Lifetime transmission fluid/filter changed?
- 2011 IS250 Headlight compatibility?
- 08 is350
- Widebody Kits besides Clinched?
- 07 is350 rpm
- 09-10 Lexus IS GFX Front Lip - Retailer?
- Head or valve cover gasket?
- 2012 is350 burning oil
- Do you notice an increase in performance at night?
- Headlight lense compatibility
- 2006 IS350 Muffler
- Car wont start!
- Map udate
- Loose Radio connection
- Tow Hook Cover Removal? (Front Bumper)
- Engine Knocking Noise at Idle
- Mark Levinson system DVD wiring diagram
- Looking for some advice on wheel and tire fitment
- Any experience with this Digitizer? $8
- Help with wiring on alternator
- 07 IS350 Stalled Restarted won’t crank
- Should 235/35/19 rub on stock suspension?
- Front Wheels rubbing on fender liner
- Help me decide what to buy! IS250 vs IS350
- Sweet IS at Tuner Evo Miami Last week!
- Techstream?
- F-Sport intake tube fittings
- Rim/tire size on lowered Lexus
- New IS350 Owner
- Reverse camera quality
- Transmission Neutral acts like 1gear reverse is like park
- Rca Video input on Mark Levinson system
- What are good sizes and specs for a Lexus is350 2006
- IS 250 FM/AM Aerial Location?
- 2012 led strip flicker
- Wheel fitment help
- Why are there different OEM hood struts for left and right sides?
- Overheating, Coolant spray, No heat - Please Help!!!!
- IS350 Mid-pipe size?
- 2011 IS350 AC issues.
- Just Bought a 2012 IS350 - Service Questions
- Squeak/Rattling coming from behind the glove box
- Blown head gasket? maybe Thermostat?
- Roof spoilers question
- What bodykit is this? IS350 2006
- How do you remove the battery
- Signal lights are not flashing.
- Should i buy a is350 RWD or AWD?
- Passenger door not unlocking(occasionally) when weather is warm. Actuator Replaced.
- Power loss?
- Driver's Front Weatherstripping Won't Stay On
- stayfast cloth top
- Help what resonator is this???
- OEM Wheels
- Will 09 side mirrors fit 07 is250
- Anybody ever have a major coolant leak?
- Help! Front Vibration Worse!
- Building custom subwoofer box. Port direction?
- Do Oil Catch Cans Actually Work? - Engineering Explained
- Lexus OEM battery or Bosch
- Lexus replaced breaks 10k miles ago. Horrible squeeking.
- ppe header instructions?
- Best way to wire speakers?
- Those of you with OBD scanners
- Need help with my trunk switch please
- 2012 IS250 f Sport
- 19x 8.5 35+ offset 19x9.5 35+ offset with HR springs for 2nd gen Lexus IS 350 rwd PIC
- OEM radio supplier?
- Lexus is250 2010 No Audio!!! Please help!!
- Is our cars Prewired?
- 2011 IS350 from private seller - what to know?
- Can anyone tell me what part this is?
- Carbon Fiber Trunk
- Windshield Washer pump
- RPM Drop
- Bizarre Issue occurred when it never should have happened.
- i want more loud!! is350
- HID conversion for my 2006
- help? Car wont start
- Farewell for now
- Anyone have kby struts for IS250 2007 please advise!Asap
- where can i find european/australian/rest of world parts?
- Help. Not your average my car won't start
- Big 3 IS250 Write-up?
- Run wire from passenger to driver side
- AC compressor
- Why should I buy this 08 IS 250?
- looking for a new battery
- Worth contacting Lexus regarding sticky dash?
- Limited slip differential lsd 2006 mt6
- Yeah or nay
- Powerwash Under Engine Cover?
- Hello.Im a new member and first time Lexus owner.
- P0420 Help!
- IS350 5 to 6 up-shift after braking downshift issue? Or not?
- 2006 IS350 Passenger High beam light dimly lit when headlights on.
- '08 IS350: I'm upgrading my door speakers, 2 subs, and 2 amps. Will this set up work?
- Headlights keep dying / light not strong enough
- Need part number for bellhousing ground strap
- Need help sourcing IS projectors
