- F sport bumper on 08 is 250
- 06 is350, camshaft sensor issue
- Bc coilover problem
- Upgrade projector headlight question
- Lexus is 250 stereo stopps working randomly
- Anyone with a TRUE DUAL and 2nd cat delete notice better mpg?
- Need help identifying a part
- 2012 LED DRL Wire route
- NAV Radio Buttons Mirrored
- Soft LCA bushings and vehicle pulling to one side?
- Common Oil Leak
- TSW Clypse Wheels (help needed)
- DIY Coolant / Radiator Drain and Fill Questions
- Parts for Valve Cover Gasket Replacement
- After market wheels. Help
- 18" G Spider Wheel Fitment on 2IS 350 AWD?
- How I fixed my broken bumper tabs
- 2006 is250 P/S light problem
- Lexus IS250 AWD 2008 Exhaust Help
- Gas Smell near Driver's side Rear Wheelwell
- 2IS 350 F Sport Parts List?
- Need help checking service record
- Need help with vents IS2
- ML subwoofer blew out, what’s the best fix?
- Need help identifying Blower motor wiring
- 2012 is250
- (Likely Scam) Craigslist ad in Ga.
- New Battery Dying
- 2008 is350 no crank advise please !!
- Front Rotors 2011 IS350
- Question
- Aftermadket head light question....
- Crashed is350 but found a is250 shell
- How to enable intermittent wipers?
- Check completed
- code P0335, P0340
- Rear bumper lip options
- 3 Performance mods every 2nd Gen IS owner should perform
- I need my Tire People! Help!
- 3IS Diffuser Molded on 2IS?
- Transmission Fluid Change Experience
- Windows don’t roll up - failed backwards jump start
- coolant crust all over top of engine
- Door card pull wires
- New Moderators; anyone have super power? Sub forum = Electrical
- My lighter charger port isn't working
- Is250 2007 smoke issue
- IS250 2012 car wont switch off
- Wheel fitment!
- 2006 is350 kit!
- Disable seat belt chime
- Quick Question [How waterproof/sealed are the alternators on an 07 IS250]
- Using non-OEM TPMS sensors?
- Help headlight problems
- Help! Electronic Power Steering woes..Little to no power
- Screen Connector Ripped (2012 IS250)
- Not displaying / not A/C works
- US imported car in Canada and recalls
- 2012 lexus IS 350 won't start and making clicking noise
- Newbie here.....looking for a legit spoiler
- Best year for lexus is 350
- Bagged IS250 is Just What We Needed
- Wheel offset
- Is250 2007 257000 km
- How to Replace Right Bumper Bracket on 2012 IS250?
- 2009 Lexus IS250 into a 2006 IS250
- 06 NAV Radio Randomly Turns Off
- DTC Codes help
- Nissan Altima drivers
- High pitched sound while playing music and charging the device at the same time
- How many ATF qts did you drain out?
- REVIEW: RR Racing Ultimate Steering Response System (USRS)
- Need a new engine?
- IS250C radio replacement advice?
- 2008 is350
- Please help!!! WILL THESE FIT??
- Dont Know Correct Specs For Rims Plz Help!!!
- I need some advice !!
- LED light strip
- 07 is250 Driver side Headlight
- 2006 IS350 Intermittent Steering Issue
- Weird Rattle Under Car
- Aftermarket vs OEM Engine Splash Guard
- Installing a H-pipe before 2nd cat on a 2-1-2 exhaust system?
- Ac climate control
- Possible ECU Issue After Battery Replacement
- 2006 is350 Transmission issues
- Wrecked Car Swap
- need opinions as still looking to buy a lexus
- 2IS airbag recall question
- Black Paint Correction
- Any big problems with the 06 IS 350's?
- iJDMTOY DRL Decoder
- OVTUNE vs RR racing
- Transmission fluid
- 2009-2013 center air vent removal SUCCESS
- battery drain parasite testing
- Lexus IS 250: Having a hard time starting (Error Code: B2799 and P2006
- Rattling sound?? Is250
- RR Racing Cusco RS LSD Differential
- Aftermarket resonator
- tallest sidewall tires?
- Bc coilovers with Or without swift springs and what rates
- Bizarre behavior
- Need some help finding aftermarket headlights
- Vehicle Diag Interpretation Help
- Is220d 2008 air con bypass ideas
- Code P0172 ?
- Does anyone know the brand name of my aftermarket wheels?
- ANYONE KNOW IF ITS POSSIBLE TO SWAP 3is headlights and bumper on to 2is??
- HELLPPP! Oil leaked out from 06 IS250 and Engine sounds.
- Need some help with wheel fitment
- Missfiring
- LED replacement for D4S xenon lights?
- Horrible Noise
- AFe Takeda VS K&N typhoon intake?
- Coilover install help!
- Are these intake valves dirty?
- Axleback no drone
- Finally a sticky Dash fix!
- What is the loudest intake availible?
- Footwell lights
- 2IS Performance Update
- Quad Exhaust???
- Remote start
- Newer door panels in a 2006 IS350
- Will 2011 dashboard fit in my 2008?
- Will these Lexus wheels work on my IS250?
- IS350 VS 2019 Infiniti Q50 Luxe
- Illuminated LED Door Sill's
- Anyone have a true dual exhaust?
- Low idle at red light
- Rough Idle and Door Locks Malfunction
- 2007 lexus is350 headlight marks??
- Deep tone exhaust?
- Cruise Control/Steering Shifters no bueno
- Is this a slipping transmission
- IS350 exhaust question
- My 2007 Lexus IS 250
- Have you repainted the plastic interior parts?
- 2010 IS250 AWD Exhaust Options
- Different shift knobs
- P/S light
- Lower intake maifold Nuts and Bolt Torque?
- two main bolts for front bumper
- Bronze or Silver Wheels with Starfire Pearl?
- IS250 Transmission Cooler
- Do anyone know where the immobilizer ecu is located?
- Bushings Question
- replacement headlights for 06 is350
- Diamond stitched car mats
- Where does the passenger airbag come out from?
- IS250 Cooling fan questions
- Wheel/tire specs
- 2006 is250 p0705
- Engine swap
- Rim color
- Help locating AC drainage line
- Still can't get air vents out.
- Need help with wheels and tire setup
- Radio acts up when it's hot
- Radiator replacement
- Restoring black plastic trim (discoloured blueish shade)
- Any way to fix this dashboard?
- ML subwoofer blown. Can I swap it with a NON ML subwoofer
- Having trouble with my headlight and taillight install
- 2010 Lexus IS making clunking noises upfront when braking
- P0430 Catalyst Efficiency Below Threshold Bank 2
- Help, P0894 code
- Engine lossing power
- 2008 Lexus is250 Serpentine Belt
- Do I have F sport springs?
- Exhaust issues
- Vent Above AC Covered
- SOLD my '08 IS250
- Intake Carbon Cleaning - How many valves are fully closed at one time?
- Jdm style (post pictures)
- AC Smells Like Mold or Stinks
- IS 250-2009 burning engine oil. Canada, ON
- Wheel Suggestions
- Really need some help
- Steering Columb Wiring
- Dashboard wrap safe?
- IS350 Shift Selector Insert Part Number?
- Best websites to purchased aftermarket wheels from?
- 2IS still worth it? What to watch for?
- !!4th Of July!!
- How to install a Subwoofer in a lexus IS250/ IS350
- *If you know anything about wheels. . . I need your help!*
- Scary/Extremely Dangerous Acceleration Issue! Please help
- Soft Brake Pedal - New MC?
- 3is steering wheel on 2is
- Lexus diesel engine stalling after ignition+ruff idle
- IS300 09' cruise control not working
- IS300 09' ABS not working
- New wheels don’t clear front brake calipers
- IS250 unknown problem help!
- Cannot diagnose misfire. No codes.
- P1277 LEXUS - Port Injector Circuit Number 2
- Rim recommendation!! Help
- Oil Filter?
- K&N filter for 2005-2013 Lexus IS 250 $18.75
- Rear brake sound
- New Mods - Carbon Hydrodip interior, Blue Hybrid Start Button & LED Upgrade
- PX6 Tesla Radio Install - 2nd Gen Lexus IS
- New member. Anyone selling an axleback?
- How is it with conversion to F-Sport?
- Engine fan noise
- Drag Brand wheels
- Front Differential
- Rattling/Creaking noise
- bank 1 catalytic converter is gone, what should I do next..
- AWD 2is information discovery idk
- IS250 Oil Catch Can Install + PCV Valve Replacement
- Fuel trims
- Does downstream o2 sensor actually adjust air fuel ratio?
- A/C stops blowing once a week.
- P0304 and P0305
- Has anyone slapped on a muffler NOT made for Lexus IS?
- is possible to downgrade the navigation to a non-navigation system in a lexus is250
- Group Buy Speed Freaks USA group buy for OS Giken LSD
- Savagegeese review of the Lexus LC500, GSF and RCF
- 2010 Lexus IS250: How to Replace Center Console Light
- Trunk Rain Drain Gutter Cleaning & Fixing Trunk Panel Flap
- Aggressive lip+splitter for 06-08 models?
- My thoughts on installing an ISF Steering ECU
- Dash lights and stalling issue - 07 IS350
- 2008 is350 65k miles. Squeaky suspension?
- is350 squeaky cruise button
- Clutchmasters flywheel and FX100 clutch kit?
- anyone painted their stock wheels?
- What is the best phone holder for the 2nd Gen IS?
- 2007 Lexus IS250 RWD [MokinWinks]
- Anyone used non oem fuel pressure sensor?
- Anyone convert HID to HALOGENS ???
- IS350 AWD Driver Road Sound Diagnosis
- Used BC racing coilovers
- Straw Blowing Sound When Accelerating And Cruising
- Gear shifter is loose
- Help with disabling auto play in Bluetooth audio
- Dorman Key fob with programmer
- Water Temperature Sensor Adaptor size
- At my wits end- IS350 won’t start
- Rotten Egg Smell Fix on Lexus IS250 2008
- Steering wheel buttons not working
- 2006 Lexus IS 350 Head Unit - No power
- 2010 Is250c
- fuel level sender problems
- Not sure what to replace - TPMS
- IS300 09' spiral cable problems
