- Alternative to AP2 tips?
- Heating and Cooling Seats
- Seafoam help
- How to replace lower running lights GS450h
- Pic Request : Front & Rear vip Table/Tray ?
- Upgrade from GS430 to GS460?
- Opinion on wheels..
- New 2007 GS350 Owner
- Tire Pressure Monitoring
- 2008 GS350 AWD Jerking/Hesitation at Low Speed
- Can you visually inspect water pump for leakage?
- 2006 GS300 Transmission issue (sort of resolved)
- Invidia midpipe installed- GS350
- Can you adjust the screenwash nozzle aim?
- Anyone change their transmission filter (GS350)?
- Lexus Dismantlers-East Coast-NEED GS Seats
- Active headlight auto-leveling not working
- Weird clicking sound front end
- headlight out / need advice
- Font Grille Moulding
- Shift Indicator Light
- Strange request...bear with me.
- Electric box under intake in engine bay
- Help, Bank 1 bank 2, cyl 1-6
- Upcoming maintenance
- Transmission not engaged/engine cold- speed bump
- Why I will never stray from the Conti DWS
- How I fixed the dash/windshield rattle
- US and Canadian Lexus Parts #
- GS430 In NYC Snow
- my gs430 needs sm boost up
- sounds like exhaust has a hole in it
- Swapping Navigation DVD Player Unit
- Help with headlight problem
- Issues with differiental
- GS350 has timing chain? not timing belt?
- Where to buy replacement arm rest cover?
- Is it possible to install an aftermarket hid kit on my '07 GS350?
- what model vais for android gs3
- Red battery light issue again
- Extended Warranty
- Hello, folks! New GS460 owner here...
- Screwed by Lexus
- Major help needed!
- Help me choose a GS
- Gs 460 driving experiences
- Fuel filter for gs460 how often do we need to change?
- Power Steering CPU location
- 2007 GS350 Nav location issues. (just installed Vais IVIC)
- Advice needed: 18" to 20"
- 06 GS3 rough shifting trans. Cold
- Anyone else get this? Class action settlement
- Please advise, I Need new rear rotors, and a rear caliper.
- Swap front seats?
- Classifieds
- Headlight Aim/Adjustment
- Wheels Offset Gurus.. 19" Wheel Question
- Difference between 2005 and 2006 GS430 Exhaust manifold
- MS8 ML Wiring Diagram Help
- GS300 2006 Steering Jerk
- New owner to 08 Lexus GS 350
- my seats!!!! nooo
- Rumbling noise under hard acceleration
- Galaxy S4 audio adapter (that also charges) suggestions? 2006 GS300 RWD
- Used Vehicle Review: Lexus GS, 2006-2012 (Canadian)
- 2007-2009 gs350 awd - way cheaper???
- 2007 Lexus GS350 parking light
- Getting up snow and ice
- 2006 GS430 brake actuator
- changed bearing, now "BRAKE MALFUNCTION/CHECK ABS/CHECK AWD" comes on. Lil help?
- 215/55-18 Winter Tires
- bad gas milage after spark plugs
- Traction Light
- Blown Head Gasket ?
- New Continental DWS tires / MPG ?
- ECT Power Button
- how do you change a busbar fuse
- Tpms
- 07 GS Possessed side view mirrors, solution/ maybe?
- how to repair the GS350 trunk lock
- Wekfest houson GS 3rd place..
- Not another Wheel Thread...lol
- Interior/center console lights
- New to the GS fam! (not to Lexus)
- *AUDIO INSTALLERS* Looking to replace your STOCK amplifier??? NO NEED TO CUT WIRES!
- Prussian blue kit finally on
- Vossen Wheels for 2006 GS 430
- Anyone running this exhaust?
- Spark plugs
- My story of '06 GS300 engine work, and a question-
- Help with my rims ???
- rear doors sticking
- 2006 GS430 75k mile Service
- Carbon Fiber FSport Engine Cover
- New 07 lexus gs350 owner
- What is your GS like? looking to buy GS vs TL
- headlights going out randomly
- 3GS alternator output/regulator - is it adjustable or replaceable?
- *****Exhaust Pipe Leak for 2006 GS300 :(******
- GS300 2006 Glove Box removal, Please Help
- European plates on a 3GS
- GS 350 Collision in Columbus
- Oil Drain Plug gasket
- Jerk/jolt/clunk when coming to a stop
- Q's about buying a 3rd gen GS
- Detailing done. I think results worth a picture...
- Steering tilt Stopped working while doing the Bag setup
- Will this fit. 275-30-20 9" wheel
- Tire recommendation / 2008 GS 350 / RWD
- 07 gs check engine light, vsc light and traction control light
- uas bag install question
- 2008 GS450H Buying advice
- It's FINALLY done!
- Drop in MPG since the Intake VVT Actuator Gear recall service?
- Remote Fob Programming
- What Generation
- Question on red Battery light.....
- New Shoes Fitted//Work Gnosis HS203
- 06 GS300 w/ CREE LED
- 06 is250 awd wheels fit on gs350?
- 08 GS light housing removal
- Digital Radio/DAB+ ?
- My tire story/review -- A/S Plus to Serenity Plus to A/S 3 back to A/S Plus
- Improving the performance and look
- GS430 ABS , Brake Lamp on after replace brake pad by myself
- Looking into GSs. 450h most, but have questions. Help Appreciated :)
- Just got her detailed - gs300 still looks good
- Break Noise Issue
- New '06 GS300 Owner - Heater Question (new twist)
- Fuel smell on start up and at idle
- buying fenders..
- 08 gs350 Steering Wheel removal question.
- sell or not to sell is the question..
- Looking to buy a GS350 or GS460 / GS450h- Your recommendation is requested
- Ricercato Exhaust
- trim around roof
- Shaking wheel when brakes applied
- My 2006 Lexus GS 300 falling a part?
- 2008 GS460 Vs 2011 GS350
- anyone no what fuse is the drl 9005 bulb is
- 5w-30 vs 5w-20
- Water / Condensation in headlight
- 2nd Post, 1st Lexus. Transmission problems at 66k?
- 07' GS350 won't start-key not recognized
- How big is safe, aftermarket wheels
- VSC Brake Light Reset
- Stock or Not
- The best tip/trick/diy/diagnostic tool ever
- All season tires and Replica Wheel question
- After Recall - Issues
- New tires for GS350 AWD
- Offset is off, and now i have an extra set of wheels
- GS 350 Engine Block Heater
- Blinking Parking and Fog Lamp
- Cigarette Lighters not working - Can't charge my phone
- Front rubbing..some questions for you lowered guys
- Gas Mileage plunge, surprise
- Broke Side mirror glass :(
- dealer wants 1k to replace alternator.
- Thinking of Trading for an e46 M3
- Rear shade is stuck at half
- Center console Tray
- Recall for cam gear noise and now this???
- Removing rear seat, sunshade problem
- Seized Caliper
- hawaii gs
- Intermitate starting
- Spilled oil on engine - now power steering dead
- What I think the perfect offset is
- Refinishing my rims -- any concerns?
- New GS430 owner
- GSh misfire issues?!?
- need some quick help. VSC
- Experience in Selling Lexus 2008 GS 450h
- Coin Cubby hole below the pull down control
- RPM Question...
- AWD Owners… does your car pull slightly to the right at lower speeds ?
- Illuminated Door Sill for 2008-2011 GS350
- Took my 2007 GS450h to the 1/4 mile track
- Thinking of moving from 2GS to 3GS
- which unit has the best aux audio quality
- 3GS DVD error message
- Ugh, wheel lock and nut shattered to pieces.
- awd & staggered wheel setup ??
- cord on dash board
- DIY: 3GS Water Pump Replacement (***with pics***)
- trap door at the bottom of the armrest
- 2006 GS300 AWD brakes vibrate
- 06 Gs430 Owners
- Is anyone running V speed rated tires on their 3GS with 18s?
- A problem has become a solution for me
- What year did they change exhaust to rectangles?
- GS350 Performance Chip
- Driver side window noise
- What are all the beeps?
- dvd movies while moving
- Intake VVT Actuator gear - Codes PP019 & PP017?
- VSC error after changing headlight bulbs
- Audio question
- GS 350 headlamps with DRL from 2014 on a 2008
- Headlight Question
- 2013 IS Navi VS 2011 GS Navi
- 2007 gs350 awd
- Buying used 2011 GS350
- Turbo?
- Spark Plugs at 60k for GS350?
- Brake Grinding Noise Help
- Tire bind -- A/S Plus, Serenity Plus, A/S 3, DWS?
- Attention Wheel Guru's, in need of advice
- Help! New brakes time!
- GS 430 front brake calipers to GS300 AWD.
- 06 GS AWD Exhaust
- Problem with Nav Hack and now cruise control doesn't work
- Headlight Auto Off Failed?
- Possible? Use 06 screen with 07-09 Lower radio part
- 60k service. Suggestion on fluids
- 2008-2010 gs350 rwd
- GS350 Coolant flush drains
- GS460 Owners, You wanna know how rare your GS is?
- Dealership brake flush
- ISF Engine Swap
- 2006 GS300 Steering Wheel
- Rear Mounted Turbo's
- Considering buying a used 07 GS 350
- Bumper Holes
- On the back of my car, The "A" from my 'AWD GS30' of my car fell off
- For the next 100k miles...
- Got skunked -- any advice???
- Problems with Bluetooth and Android 4.3
- Does condensation in headlamp cover under CPO Warranty?
- GS350 no navi convert to navi
- 08 GS450h no sound out of AUX port
- 2009 Lexus GS350 AWD
- GS 430 year 2006
- Hit a milestone of sorts today....
- Left channel doesnt work in satellite radio
- An accident and a goodies package all in one DAY! :)
- Rear canard
- Brake Dust
- Modellista JDM front lip
- Sat radio
- GS 430 on Niche Concave
- speaker replacement
- '06 GS300 AWD - Cert. Expiration
- Chromed vs Polished wheels??
- 08 gs 460 only left channel on satellite radio
- Replacement Brakes for GS460
- No AUX port. Are there any other options? 06 Lexus GS
- Refurbed Break Calipers Hybrid Blue
- CPO GS new buyer questions
