- GS430 Intake tube setups? From air box to throttle body
- DIY : 2006 GS Front Door Panel Removal.
- 2006 GS300 Engine after rebuild experience
- Need Help Car wont Start
- '10 GS460, 11K miles in Newport Beach CA for $32K
- 2006 gs 450h BHP
- Car audio custom install - your opinion
- Chris Forsberg Rips Up the Track With Haggard Garage's TT Lexus
- 2007 GS350 best iphone kit
- Dose 4GS Intake Pipe w/ Generator fit of 3GS 350?
- New battery - now Windows won't operate
- Anyone install VaisTech ULM-051 ?
- How to identify 3GS options, with pictures
- Sway Bar
- 3gs 430 (2005) problem techstream not read engine and ect (powertrain)
- need to buy oem body parts
- Rear Wheel Drive Transmission
- 2007 GS 350 90k Service
- Tire trouble...adjustable rear camber for lowered '07 AWD?
- 3GS 350 AWD broken air filter door missing piece?
- 2010 GS low predicted reliability (2 out of 5) on JD Power?
- Sticky problem, got some redbull in the shifter...
- Lexus GS 350 or Buick Lacrosse
- Windows sound harsh rolling up and down
- Gs350 taillight help!!!!
- What kind of nut on underneath the car
- Replaced GS430 - Sell or Keep as a build car?
- Mark Lev Nav aftermkt stereo install SOLVED!!
- Where do you buy your parts?
- Anyone have the SoundLinQ3 (Model SL3B) in a 2006 Lexus GS300 with NAV and ML Audio?
- 2013 gs350 f-sport wheels will get my 3rd gs350?
- Electrical Failure
- Got re-ended for the 2nd time in 3 years
- 2006 lexus gs audio issues
- GS430 Vs LS430
- 2007 GS430 63k
- OEM spring identification front/rear
- 2006 GS300 floor well lights
- Looking for an air intake for a 2008 GS350
- Is this the best way to repair broken paint?
- replaced strut, AFS off light blink, thanks MyLparts
- Vossen CV2
- Does anyone know where I can find this front lip?
- BT issue with my GS450h (2008)
- 2006 GS300, fog lights
- What to look for during CPO warranty
- what size wheel and offset?!
- Contemplating First Lexus
- DIY Headlight Plastic Restoration and Seal with Minwax/Spar
- Replaced battery. AC stopped working
- Gs460 2008 o2 sensor B2S1 placement
- aRE gARAX STILL THE BEST REPLACEMENT BULBS ?
- 2006 GS350 AWD - Good price?
- Wtb rear camber arms 09 gs 350
- Lost a 3gs in Socal today
- Looking for pinouts for non ML factory amp
- Check ABS, Check VSC,
- 2006 lexus gs300 ''drl bypassed " with high beams working
- speed sensors location?
- GS430 with 120k miles - advice please
- Does 2008 Lexus ES350 spare fit GS?
- Anyone else get a wheel well grind in reverse?
- Gs300 06 Drive shaft is leaking
- 2008 GS 350 AWD bad alternator?
- nav problems
- HELP!! 07 gs 350 awd
- Should I sell 08 GS 460
- Parking sensor replacement?
- lexus gs460 hesitation
- Loose AFS
- 2006 GS300 Fuel Injector Driver
- Good Quality Aux/Ipod Install Kit?
- 2006 GS 300 -AFS Flashes, Headlights too low
- Do I have DRL at all on my 450h 2007?
- 3GS damaged engine plastic under panel
- Check Headlight, Battery Light
- 06 GS300 Headlights keep moving up/down while I'm stopped !!
- Anyone know what this part in the trunk connects to?
- P0333 Knock Sensor code
- 06-07 & 08+ Interior
- Iacv 2006 gs300?
- HELP! Diag Code PO756 Shift Solenoid "B" Performance or Stuck OFF
- Check vsc on dash traction control light on check engine light
- ECU reader - ELM327
- So you Lexus starts then dies after a few seconds and no one can figure it out!!!!!!
- Leaking Tranny Fluid from pan gasket and seal
- Chinese aftermarket headlight housing...?
- 2007 gs350 awd - brake pedal feeling stiff at startup
- GS 460 burning oil smell
- GS 350 Weird Tranny Behavior During Hard Braking (With Video)
- Opinions on 2006 gs300 with 100k??
- Key less entry Frequency
- Buying used Lexus 08 LS460/87k/1owner/24k O.T.D - need some feedbacks
- How do I disengage the safety crap keeping me from drifting?
- Anyone tried buffing the center console wood?
- speedo needle wont pass 40mph
- Plastidipped my whole car white - video
- looking for stoptech brakes
- Oil Maintenance Reminder Reset Procedure - Video
- Parking Brakes
- Rx shift knob to Gs???
- Do yours rattle this badly?!?!
- 07 Gs350 check engine light blinking..
- Plastidipped my 2006 gs3 chrome trim
- New to Forum
- Lexus GS300 lighting question, driving light bulb question
- Lexus GS460 22 inch wheels
- 22 inch wheels
- I cant start my GS 350
- Need new front struts
- Wheels with stock suspension question
- Trunk Carpet doesn't fit?
- Repeated check engine light after installing k&n intake
- Inspecting and cleaning speed sensor rotor
- Which Tire; 235/35/20 or 245/30/20
- Former Avalon owner to possibly a 3GS AWD owner, need your advice please.(Researched)
- Lexus dealership cannot figure out what's wrong!!!
- Mark Levinson tweeter question
- Need Help with Ignition Switch removal
- Tire size helppppp!!!!!!
- GS 350 Passenger HID turning off after few mins (new Owner)
- Goodbye dear '07 3GS
- Range Approximate is very low.
- Looking for this exact day time bulb
- Does anyone know how to do the NAV/DVD over-ride (cut wires) on the 2011 GS 350?
- 2006 GS300 Spark Plugs are Easy!
- Winter Wheel Options
- Spare Tire for 2007 Lexus GS 450H
- Squeak / Squealing noise from Air Conditioner when heat/air con ON
- Where to buy timing belt & water pump kit for 06 GS430?
- My 2006 GS430 experience
- installed alt. and now won't crank or start
- could use better brakes... (near miss accident)
- I can't find the right size rims for my car!
- Recommended scanner to read wheel speed
- 2011 GS350 - weathertec all weather mats issue
- Share your exhaust setup here
- Megan midpipe vs Invidia midpipe
- HPS intake vs k&n typhoon
- Caster & Camber out of Spec During Alignment
- First post - coolant problems
- 2006 lexus gs300 check engine light trouble
- memory seat problems
- Total noob needs help with exhaust mods
- Thinking about switching from ES350 to GS350 AWD
- Has anyone here had their car repainted?
- Codes Po172 & P0175
- 2GR-FSE Timing Cover Oil Leak?
- Mis-Post
- How do I check for codes for with an OBDII?
- 2011 Lexus GS350 non mml how to add a signal processor
- Rear Seat Torso Airbag
- Got T boned
- Difference between 2008 GS460 and 2009-2011
- What do YOU use to clean your 3GS leather?
- 2007 3GS aftermarket rear bumper search. Help me!
- Can't unlock trunk
- Can this board tolerate another transmission discussion?
- Front suspension wear
- simple iPhone integration kit?
- 06 GS300 inner headlight issue
- Old Lexus member but new 3GS owner!
- VSC/engine light & headlight
- School me on GS 350 paint
- 2007 gs350 wont start need help!!!!!!!!
- RPM's drop normal in S mode?
- Aftermarket Headlights
- Body Lean
- Drove over a curb...Help
- How can I reset tcm memory for my GS350?
- How to protect your floor mats (A Revolutionary Solution)
- Advice Please! 2006 GS300 Purchase after Recall Service
- Factory speaker
- Question: Can I put 245/50R18 Pirelli Cinturatos on my 2006 GS 300 awd?
- looking for aftermarket grill for 2009!!!!
- DIY Water Pump Replacement Video
- Are the oem "f sport" parts worth buying?
- 2006 gs430 superchargerd
- Permanently disabling seat belt buzzer in 2007 & 2011
- New to Lexus... Exhaust diameter?
- engine stutter coming to a stop...
- aftermarket "JDM/VIP" signals
- The cut key
- 4gs rear on 3GS?
- Those with aftermarket front speakers..what are you running?
- Brighter Headlight Suggestions?
- Brakes making loud squeaking noise!!!!
- MPG seems pretty low...
- More Repairs on GS350
- Need plastic bracket for license plate
- Anyone used Leatherique on their 3GS?
- Satellite Radio Install In GS350
- Comprehensive DIY Videos
- hood strut? DIY? anyone tackle this yet?
- Does anyone know how to adjust the highbeam lower?
- Brake malfunction' Vsc, awd, abs light all on!
- Headlight Chrome
- 2010 GS350 - issues?
- Water on the floor in the rear seat carpet
- 2009 ISF Wheels opinions!
- No Idea What to Call This Thread Problem
- Rear muffler delete on 2006 GS430?
- question about transmission fluid change, please help
- 07' gs 350 awd engine vibration.
- Looking for Lexus Mechanic that does side work in San Diego
- Question about light bulbs and interior lights
- New to the Club, back in a Lexus
- New guy with a new to me GS 300 AWD
- New to GS350
- No Crank, Check VSC, cooling fan runs.
- 2007 GS350 AWD Rear Bearing Replacement - notes
- Had a friend powder coat my wheels, opinions..?
- Horrible Fuel Economy - '07 GS 350 AWD - 13L/100KM (18MPG)
- Part numbers for fuel pumps/injectors
- Happy to join the forum!
- gs350 AWD slip indicator, power loss at 55+ mph
- This isn't the classifieds.
- Replacing Windshield Washer Fluid
- Farewell...sort of
- 2009 IS F or 2014 IS350 F sport
- New to the forum, transmission question.
- My first GS350
- Vaistech SL3B Simple/Settings Mode Question
- Door speakers 6.5" comp set
- What could be wrong with my 06gs300
- Very LOW Mileage 2008 460 - This is NOT a Classified AD
- Malfunction Indicator Light On?
- i250 caliper vs gs350 caliper
- Invidia Mid Pipe on AWD
- Gs460 with 140k?
- What is this cog for?
- 2010 gs Lexus 350
- Lost my car, looking at a GS350
- Purchasing a 06 GS430 with questions!
- 06 GS300 changing temp from C to F
- Starter issue?
- ML radio won't read the VAIS IVIC or the IPOD hookup
- adjusting headlamps help needed
- Safety Recall ELF time for repair?
- thread closed
- Broken TPMS Valve stem
- Leather and plastic paint
- Deciding between 2 vehicles
- Recommendations
- Anyone got pics of Weathertech window deflectors installed?
- Long shot - Anyone have old drip rail moldings?
- HELP! - 2007 GS450H won't start even with jump
- Advice RX vs GS
- New Water Issue
- Remove driver side door trim
