- DRL's stay on
- IS250 Lighting Problem
- Rear Turn Signal Color
- 3k, 6k or 8k HID Fogs?
- Brake lights on GS300
- anyone ever ordered from Auto-Electronic Supply?
- Another Q45 retrofit into 2GS w/ New Projector Brackets!
- 2006 GS 430 Front Headlamp Replacement (Dealer Holdup?)
- HELP: OEM HID for IS250 Flicker....
- Wedge Bulbs?
- Beware of off brands
- Where Can I Buy 6" or 160mm Pure White Cold Cathode Tubes
- How to connect Denso Ballast to battery on non-HID 2GS headlight ??
- IS250 conversion to Bi-Xenon
- 05-06 ES 330 Projector Lenses
- how to make bi-xenon feature work on a 2gs?
- I need help
- Load resistors. which ones?
- Does anyone know?
- RX330 Brake light
- HELP: Changing the Wedge on the 3GS
- 2 GS issue - headlight levelling no longer working. How to fix this?
- Reverse Lights Come On When Braking
- HID Headlight flickering
- Putting OEM GS HIDs into a OEM non-HID GS
- best hid/retrofit for SC300/400
- SuperbrightLEDs.com
- High Powered LED's
- HID Retrofit for RX350
- 08 IS250 projector lens swap?
- How to replace reverse light in RX 330?
- whats up need help trying to wire my fogs!
- whats up need help trying wire my fogs!
- Change 1157 bulbs to H3 set up for fogs
- Help!!!! Water in HID head light
- Halogen headlight cuts off while driving but works when turned off and on
- left fog light out on my 95 sc3 - need help troubleshooting
- 1998-2005 GS fog light disassembly
- Climate control bulb part # (gs300)
- Rebased d2r bulbs to 9006?
- HID, Fog light result! take a look guys
- Clear side marker lights
- 2Gs Stock HID bulb replacement
- Console light goes away in cold or when i turn the headlights.
- 6000K vs. 8000K HID
- SC300 no dash lights?
- Speedometer not working any idea??
- Puddle Lights
- will h11 bulbs work with '07 2is w/ oem hid
- Steve @ XenonDepot
- Xenon Depot.....A++ on Customer Service
- High beam headlight problem
- GX Halo Headlights
- Daytime Running Lights Install
- 194 CCFL bulbs
- I do not recommend using 272-1092 bulbs from radio shack for replacing climate bulbs
- What else do I need to install HID kit on non-HID headlight ?
- FUSE keeps going out
- please help
- Question about d4s bulb failing
- Newb LED question
- 2006 Lexus GS DRL
- cheapest HID online?
- 95 es300 output difference
- changing light behind radio console?
- HID relay
- Closed out
- Anyone install an HID kit on a GX yet?
- HID/fog upgrade on 09 ISX50?
- SC400 Headlight bulb size + Q's
- HID's flickering....after a month??
- 92 SC300 Cornering lights to Fog lights
- D4s to d2s swap including ballasts - possible?
- 2GS help!
- IS350 check VSC light on
- 92 SC400 opening headlights opinions please
- Stock HID projector mods on ISx50?
- HID fogs blowing fuse using stock wires
- reverse light change to LED help IS250awd
- Odd gauge needle problem
- Replacement HID bulbs?
- IS350 halogen to hid question
- How to change headlight for GS 350???
- Philips 42402
- DRL Pics PIAA Intense White?
- LED Update (V-LEDs)
- 1999 ES300 Backup Light
- HID lighting for LX-570
- mobile hid
- dash lighting
- ES LED Conversion
- IS 250 HID for High Beam?
- LED help
- Hid kit for fog light
- lexus gs hid bowls for retrofit ?
- HID Glare on ES300
- Which Headlights?
- HID Help!!!
- Are these really philips kits ???
- help
- HELP needed ASAP! HID fog install trouble.
- Anyone done trailer wiring on their sc or other lexus car.
- Lexus should make better...
- Xtreme vs. volt hid kit???
- Color of 3000K HIDs?
- How to install a relay - HIDEXTRA.com
- 97 SC400 Tail light bulbs
- turn signal bulb number???
- LED Foglights
- D2S, D4S, D2R, are they all the same???
- where to buy repalcement parts for my hid kit??
- Retrofit LED Turn Signals
- Help with sc300 foglight clean (opinions needed)
- 05 lx470 hid
- HELP! HID BULB fitment issue
- noob type question part two
- Upgrading lights for "Project Cheapskate"
- help hid bulb blew in headlight
- MTEC HID install - 2010 RX350
- found these sc300 headlights on cincity.com
- Headlight fuse blows when lights are in auto mode.
- cluster lights
- LS 430 tail light lens
- Bad ballast?
- Gas Needle
- Fog Light Fuse?
- Help Broken HID bulb (Fog)
- Brightest light w/ stock headlights?
- LS430 retrofit on OEM HID equipped GS?
- A quick question about HID bulbs
- Will new HID bulbs help improve brightness?
- HID kit , whats good out there?
- How do you wire LED turn signal bulbs so they dont hyper blink?
- City Light DRL's Not Functioning After LED Swap?
- HIDEXTRA.com HID Review
- Violet color HIDs on LS430 for Show??
- High Beam projector retrofit Q's?
- Lighting Wiring Advice Needed!!!
- SC300/SC400 LED lighting (Interior)
- Fog Light help
- help on my DRL 99 sc300
- What color HIDs should I get?
- Stuck on what to get ..
- New Interior LED's by Xenon Depot for the 2IS dome lights!!
- 2is back headlight cover question
- HID bulb failure
- Dome LED replacement fade blink question.
- Help Please. Which one should I get?
- ne1 know...what is a european H11 bulb?
- does lexus make hid/afs for all their cars?
- Where to buy Garax HID Bulbs?
- LED Yellow Fogs
- 4300k SC300 PNP vs. TSX with Philips 85122
- Relay Diagram?
- Using Volt Kit with or without Relays?
- $1,500 a piece for headlight assemblys???
- Just Another LS430 retrofit into 2GS
- MTEC Bulbs?
- Converting cornering lights to Daytime running lights problem...help
- I'm baffled and I ca't figure it out
- one of my hid blew out.
- what is the lightbulb size for shifter 98 gs4
- H3 Bulbs Compare to 9006 bulbs (HID)
- Garax bulbs or....
- Need help: Replacing a lowbeam headlight bulb on a '96 ES300
- GS 400 Dash light "icon" lit up?
- Is it normal.......?
- Guess what i got for $129 =]
- LED Brake Light Replacment
- hid headlights kits (w/pictures)
- 96 es300 Coach edition headlight Kit
- Need help broke HID bulb base
- HID's on Stock Cars w/o Housings
- 99 GS HIDs dim compared to newer cars HALOGENS
- Help with installing resistors
- Wanna convert to HID
- Help! One of my low beams (hid)went out on my F
- GS Projector Headlights
- What does Caddy DTS use for its back-up lights?
- What is the lumen output of Polarg M4's?
- Aftermarket HID issues - advice needed
- 2GS Puddle Light Install - DIY - Helpful tips.
- Puddle lights...help!!!!!
- 2GS leveling motors, left and right interchangeable???
- Wanting to convert to HIDs
- I need some Crazy help from you guys!!!!!!
- Headlight turn signal issue
- F/s hid front light lense
- 97+ Tails Sc
- Anyone use Xenonworx?
- Looking for bulb match for HID 6500
- Best H3 yellow foglight bulb for 4ES?
- changing signal light in headlight assembly
- Helppp
- '06+ SC430 JDM HID fogs
- HID fog light install **HELP**
- Color bulb on Color lens question
- Hid fogs on 1993 es300???
- HID FOGS...on IS, what do I need to do?!
- 05 rx 6k low beam problem (please help!)
- HID not working on '06 GS300
- Those with TSX Retrofits, please read
- HELP: Glovebox light and trunk light are out (99 SC400)
- Has anyone changed the lighting on a 2nd gen GS gauge cluster?
- Should I change to 3000K Hids in Fogs..6000K Already installed
- New to lights - 08' RX350 help
- H11 Bulbs to HID 6000K Diamond White
- any aftermarket fog lights??
- 07 GS350 with 6k's, Drivers side bulb going off!?!
- headlights & taillights
- Anyone know the intensity of OEM HIDs for IS350?
- HID Ballast
- Whats better for a retrofit??
- LED Interior Lights for ES330. Any advice appreciated!
- looking for a stock xenon look
- DRL LED installed in 2nd gen gs!!
- Exterior Lights and Condensation...
- HID foglights?
- IS350 LED, HID FOG Installed. Products from NIGEL
- Lexus Bulb sizing
- 2G GS430 - fog light question
- Do these fit 2g GS430's with OEM HID's?
- Interior to LED'S
- 98-00 LS400 HID question
- help in the CT area
- Location of flasher in a 92 sc400
- HID turns on, flickers, then goes off.
- Bad Bulbs? Or something else?
- Drl
- Bulb issue or Ballast issue?
- will chaning reverse light bulb to 7-watt LED cause bulb failure light to come on?
- 2001 ES300 XenonDepot H3 4300K Foglight Kit and randoms
- want to disable 2006 ls430 DRLs
- Foot well and door release lights
- SC300 volume/ temp knob LED DIY
- hid foglights in sc400
- Condensation damage headlights?
- who makes the brightest LED bulbs? (7440/7443 type)
- Fog light Install on 2 gen GS 300
- 2009 Murrano Hid?
- fog light selection
- 1st gen LS retro fit?
- Xeon Depot - Steve
- matching inner lights w/ headlights
- Stock Headliht bulb replacements
- 2nd Gen Gs tail lights
- HID cut off not straight
- retrofit help
- HID fogs cause sound on radio to turn off
