- Rx400 tail light on Rx350?
- Question on LED panel lights
- need help with size of bulb.
- trunk light help
- ~ PLEASE HELP ~ HID Questions 35w OR 55w
- Lexus IS250 - Installing Park LED Lights
- Looking for Headlight housings for GX470
- Unsure about if I can replace this bulb with an LED.
- Yellow DRL Anyone..
- No brand HID
- Question on Cree LED
- Have a quick question about my Yellow fog lights
- 5000k 9006 hid kit. Very different results
- Taillights... Different versions?
- Need help install OEM DRL to Philips D4S DRL
- please help me find the right 9005 65w bulb
- D2R for IS350?
- Replacing Stock HID Bulb with Xtreme Depot 6500k
- Here is a TOYOTA part number for the instrument cluster lights
- 2003 gs300 map light bulb
- Spec D-Tuning Headlights?
- rear tails 50% out
- Philips Ultinon Bulbs
- hid question ???
- picked up halos from salvage yard why did i do it?
- gs300 replacement headlight assembly
- can i run 12v 65w bulbs in DRL?
- please delete.
- which of these LED bulbs to get?
- HID help?
- Day time running light stop working help please?
- need suggestions for DRL and fog light upgrade on my IS350
- Looking for a bulb replacement for my DRL for Gs400
- Reverse light LED replacement
- Day time runnings
- What is the largest LED dome light bulb I can use?
- HID RX 350 Quick Question
- full led swap one light not working
- Just installed Volt HID...now what?
- LED kit?
- HID Bulb Driver vs. Passenger side Brightness
- LED Replacement Bulbs
- IS300 9006 to H3
- HID conversion kit installation procedure.
- Garax 6000k D4S or XenonDepot Xtreme Line D4S 6000k?
- Is this how 8000k is suppose to project (doubt it)...?
- I need help with my fog lamp
- RX 330 Illuminated grille from junack usa
- HID ballasts that won't interfere with radio reception?
- Best website to buy HID conversion kit?
- HID problems 92' sc300
- 07 460LS garage issue
- IS250 Passenger HL Out after Bulb Swap.
- Passenger HID headlight ?
- is300 hid problem
- RECOMMENDATION FOR DDMTUning (HID Fog Lights)
- LED LIGHTING: Discount Code for V-LEDS.COM
- 1996 GS300 electrical shortage problem
- Newbie Questions
- Confused on LED for Fog and DRL for 2012 RX350
- Headlamp Conversion
- DDM Tuning Question
- drivers side hid
- Black houseing on gs Headlight
- Front Rurn Signal Bulb
- Wattage: 35 into a 55?
- Lexus Is350 HID low beam passenger side not turning on :[
- Capsule?! Going crazy
- HID Gurus
- question about steel spring clip inside the headlight assembly
- just a quick question
- Going HID in a SC300
- my turn signals dont work on the outside of car
- Rx300 Parking Lights don't work
- Headlight change...
- Does anyone know where to find this for is300
- Retro fitting 2004-2006 LS430 Projector to 2001-2003 LS430 housing....
- '95 SC 300 Taillight assembly - ?
- HID kits...
- what brand h3 3000k light output do you have? mine came out green so i returned them
- socal people...
- 2010 turn signals
- 2011 is350 LED Driver Lights
- Question re. HID for IS250
- has anyone put cree led in your city lights?
- Anyone have L-Tuned (55watt) Fog Lights for the IS300?
- Those who want to buy LED Fog light bulbs
- Mixing Different Brands Bulbs and Ballast
- Lexus IS 250 projector fog light retrofit help.
- Can 06' ISX250 use 07+ ISX50 Headlight?
- Why do people think this is appropriate? Stupid Lights!
- Just put in my phillips 85122+
- Best match for Garax 6K HID??? - DRLs and fog lights
- debating on new lights
- Installed! TSPNY 6k lows / 3k fogs and V-LEDS 6k 194 LED City Lights
- Looking for 3000k bulbs that don't glow neon green! =/
- Factory Fog light issues after using luminics bulbs
- H11 bulb in 9006 plug?
- only have one head light working!!!!!
- DDM HID Kit 55W
- IJDMToy Fog Lights
- 2011 GS350 Aftermarket HID oveheating?
- Hid install Houston
- Anyone tried those Luminis G4 mini HID kits?
- how often should I replace HID bulbs? they're getting less white now...
- 9005 similar to 9006??
- Ebay D4S HID Bulbs
- Ballast Question
- HID Kit needed for my car
- My tailights cracked, buying these ebay tailights?
- Yellowing HID Light (one side only)
- Brightest 194 Halogen
- i need hid balast only..
- Question about 2007 IS250 light
- HELP! Did aftermarket HID bulbs mess up my GS430 OEM HID AUTOLEVELING???
- has anyone used Dash Z headlight?
- Question about my hids
- Those who have done a dual retrofit please come in
- LED exterior mods/builds?
- 2008 Lexus IS-F Blue Precision LED Kit
- Lexus 2GS DEAD Glove Box Light
- Differences between Garax D4S/Xtreme D4S/NigelJDM D4S?
- HID retrofit drivers light won't come on
- 9005 bulb in fogs for rx330
- GX 460 HID fog light advice needed.
- where to get 6k d4s @ a good price?
- HID high beam in RX 330 and HID for fog lights
- Completed 2011 RX hid and led swap
- Bad News
- Non-AFS RX330 Projectors Modded With E30 Lens and Custom Shield
- HID Kit with Lexus GS300 question
- DRL,Puddle,Reverse,Parking
- 1993 LS400 lighting issue
- PIAA Night Tech H11 Halogen
- newbie/gs350 drl question
- Lights
- Daylight headlight HID retrofit questions.
- Hid bulb replacement rx 330 steps
- flickering HID
- Fog Lights
- your ballast wattage?
- Need help with my fogsgs430
- Halogen vs. HIDs
- Putco Bulbs
- Best bang for the buck PNP HID kit?
- Questions on HIDs and DRL cover
- Something smells like it's burning. Is it ballasts?
- The Talented Sean From *********** Converting My 2nd Gen GS Gauge Cluster To LED
- sc300 spoiler light
- To go yellow on DRL's/Hi beams or not?
- 1st Gen SC retrofit bracket
- Putco NOVA LED bulbs
- yellow fog lights
- Does anyone know how to change the Interior Accent Lights?
- ModExpress HID bulb replacement
- Ls 400 1999: How do I re-aim my new HID fog lights?
- help w/broken hid leveler
- 98 Ls400 city light bulbs
- Does my Lexus LS400 1999 need a conversion kit to install 3000K HID's as my fogs?
- Changing fogs to driving on GS
- tail light went out?
- PY21W and WY21W
- Questions about halo lights
- Led calculation help???
- LED Trunk Lighting Upgrade
- HID foglight issue
- bulbs that aren't hid bulbs?
- question about hid ballast
- How to make LED foglights?
- HID Problem
- HIR lights.
- Sc400 side marker diode
- LED DRL Parts List
- LED DRL's & More!
- Swapping HID guts to NON-HID housing?
- looking for custom led shop..
- Where to buy Philips Diamond Vision?
- HID help please!
- Thinking of going with projectors from Theretrofitsource.com
- hidextra coupon code?
- Quad Projector with Flat LED as DRL
- Nokya Hyper Yellow Fogs
- Looking to Swap out full interior lighting
- DRL Retrofits
- Best Replacement Fog light 99GS4
- New garax bulbs but one side is brighter
- Viper won't shut off my auto light?
- LED DRL unit power source
- Change my lighting
- Modded RX330 Projector With Custom Shield
- best yellow fog light bulbs?
- 3rd Gen GS HID Fog light install issues???
- Automatic Headlight Leveling System Problem
- brightest 9005 halogen light
- So i won a free set of projectors from theretrofitsource
- 2002 SC430 map lights
- IS250 Dash/Footwell/Radio Lights
- Polarg J01
- Hid fog light wiring help
- lighting expert, just curious.
- Review of new XenonDepot Xtreme 5000K HID bulbs on 2IS and CL-only discount code
- Mod-Express.com Review
- low beam out when fog lights off
- ???How to bypass the LMF??? 92 ES300
- ES350 interior lighting
- ES330 Center Brake Light Out
- HID Bulb or ballast?
- Question about led bulbs
- GS3 Fog Lights
- Storm HID kit, anyone have any reviews of this?
- liscense plate bulb replacement
- Quick question
- Whitish H11 bulbs for 2011 IS ?
- 2GS LED FOG's...any one tryed those?
- HID kit power
- 3000K, 4300K or 6000k for fog HID conversion?
- Low beam headlamp HID-D2S
- Brake light problem after repair work
- LS 460 interior lighting
- Where to get 5000k low beam bulbs (not kit) for 2IS for reasonable price?
- 94 es300 headlights
- Help please!!! Has anyone open their headlight unit 02 ls430
- hid on high beam instead of low
- Lights wont shut off
- aftermarket hid longevity factors
- 2002 LS430 LED mirror cover upgrade
- D4S bulb to match HIDExtra 5000k kit?
- reviews for HID nation
- DDM Tuning disappointment
- Heeeeelp hids issue
- @@@ Help tail light issues @@@
- Low beam HID 8000k on GS 350
- Heads up!! Lighting sale!!
- CREE Q5 Backup Bulb
- HID headlights burning yellowish White
- LS/GS 460/430 etc.. Headlamp Retro-fitters beware..
- LED Puddle Lights
- Does AFS work for right turns?
- Ballast under warranty?
- HID install for 2000 LX470 help needed
- Burn smell from HID bulb
- Cut-off line
- LED Lighting - Courtesy of LuxuryMods.com
- Used IS350 with hid kit
- Headlight advice needed
- Best HID replacement bulb?
- Whats the Best HIDS kit?
- Putco Bulb
- hello question
- H7 Bulb powered by Car Battery
