- Tryk's new LED work(climate and radio)
- best HID aftermarket system
- Philips H7 Blue Vision Vs. Sylvania H7CB
- Blue LED Door & Interior Lighting - Pics
- Fixed the 'Can't See the Turn Sigs' Problem - Pics
- glass headlights
- Changing Footwell lights on GS
- 30 LED Color....?
- 98-00 LS400 Euro tails
- changing clock to red?
- Philip ultinon bulbs had pigtails, or not?
- LS400 Light bulbs
- 93 Gs
- 1156 Bulb Options
- sc "bug's eye" projector
- Trying to buy Polarg M4 bulbs and PIAA ion yellow bulbs
- Will this conversion kit work?
- New Philips 3000k HID bulb
- Location of Lamp Failure Module in '99 GS?
- Rx300 HID retrofit
- How do you remove PRNDL bezel in GS?
- i need some help about interior lights please look!!
- climate control & stereo
- xenondepot.com 4300k SC300
- HIR bulbs on 92 SC400 working well
- Fog Lights
- How to Smoke headlights
- Piaa h-133
- Daytime running light bulbs ???
- Speedometer Light
- where to get cheap hids?
- Disappointed with PIAA XtremeWhite for HID Match
- redid my q45 headlights ;)
- dome light question
- What bulb type is the map light in a 2nd gen GS?
- I want to change my HID so it is bluer...
- How to reset "check tail lights" icon?
- unsatify with Xenon Depot HID
- Piaa Hid Bulbs
- PIAA Ion Yellow in Clear Side Markers
- replacement hid bulb
- Phillips Lighting Q?
- 96 es300 Climate Control Bulbs Info
- HID retrofit on RX300
- Fried Headlight socket!!
- SC healight
- replacing light bulb on RX300
- HIDs too bright?
- Interior lights for the 02 gs
- LED Bulbs, Flashing, and Bulb-Out Light
- Questions for LED experts
- 2nd Gen. GS Foglight bulb size?
- Got Light? MTEC HID-Type Wedge Bulbs!
- upgrading to hid
- Best HIDs?? Where to get them...
- PIAA Mirror Orange Bulbs or Stealth Auto silver covered amber bulbs
- Anyone here in Houston done a HID retrofit...
- No go on dome led's, where to get them online.
- Where to purchase OEM HID bulbs
- Meccatune 6000K HID Gold Kit
- Xenondepot
- What can cause a bulb to explode?
- looking for bright yellow fog light bulb
- Where can i get some mood lights?
- Factory hid gone bad?
- changing HID $ back LIGHTS!
- foglights not working
- SC300 hid retrofit upgrade
- Blue/White Halogen bulb actual color temp results
- Denso HID kit w/ H7 Rebased Philips D2R
- Replacment Daytime lamp Bulbs???
- has anyone used sc430 hid profectors in a sc400 retrofit?
- Dome light wires
- Help on fixing headlight adjustments
- Need a wiring harness
- Why do my headlights slightly dim/flicker when I touch the brakes?
- crystal white ebay hid bulbs..any good?
- help: DRL's
- Got new HIDs. DId i get scammed?
- Rewiring tailight question
- Part # for GS Fog Harness...
- Help...w/ replacement bulbs
- HID question for 99 GS
- How to determine if d2r bulbs are blown?
- my review of MTEC Yellow style bulbs
- Aftermarket Bulbs=Burnt Harnesses?
- Are non-hid to hid kits worth it?
- might be impossible but.........
- installing HID e39 projectors sc300
- help corner lights match my HIDS
- My Lights At Night. (6000k / 9-LED / HID FOGS)
- Where to get the OEM 2001+ GS taillight?
- angel lights...
- help finding the bulb size - is it wedge / 168??
- MTEC blubs on SC 9005/9006
- fogs on the SC
- 93' Hid conversion "Newbie Question"
- Headlight Diagram
- Just replaced parking and backup lights with Polarg bulbs
- Recommended bulb vendors
- LEDs for GS 01+ tails?
- best LED vendor?
- GS300 turn signal light guide wrong?!
- Just finish installing OEM HIDs
- has anyone used a different bulb for there hid?
- Change GS Fog Lights from White to Yellow
- anyone w/ an acura tsx hid retrofit??
- My SC LED Retrofits
- projector / hids?
- HID not working
- My Problem With Philip HID Kit Continues...
- Color question for Hella 6000k HID kit.
- Probably the dumbest question you've ever heard...
- 9008? Where to find
- Razo White Zero vs. Piaa Xtreme Series
- HID thourough FAQ
- Legitimate Option To HID/XENON...!
- White LEDs for clear bumper markers, where to get?
- HID Headlight Housing
- ls 400
- color difference between 4300k and 6000k
- Non-HID to OEM HID Conversion, need some help
- Tail light oem
- How does 8K HID look like?
- Lexus HID question(oem)
- Wanting to Find/Install HID's in my LS400.....need advice
- ES 300 Headlamps
- dash light question
- Has anyone heard from kwimports lately?
- changing GS hvac/radio/clock to amber?
- Replacing bulbs with LED's?
- clear side markers on GS?
- Ballast Temp Endurance?
- best HID kits for the SC?
- RX300 Fog Lights Only?
- aftermarket hid's..
- Map light on GS question
- X5 Retro In Progress *56k warning*
- Wiring daytime running lights
- 1998-2004 (GS Headlight Housing compatibility)
- HID Volts
- HID Question!!
- Changing Interior Lights to Blue
- D2S or D2R for GS HID Bulb Replacement?
- Fitting HID bulb into H3 socket
- HID retrofit/conversion kits bad ideas?
- Retrofitting HID to GS question
- McCulloch vs. Hella HID kit
- Spiderlites, expanding led's...
- Recently Installed HID Kit In My Fogs And...
- Need help with dash warning light
- Is it possible to replace your own cluster lights?
- A6 Projectors **56K Death**
- ES300 Dash gauge needles flicker
- Lighting FAQ sticky- RAZO
- Mounting the ballasts
- can someone (olt) help me with LED rears
- Solution to remove condensation!
- reverse light help
- Recommend a HID conversion-er?
- Polarg
- Lexus yellow projectors
- HID questions
- GE Gold Bulbs
- Bellof Wide Angle Leds
- Daytime Running Lights are Never on
- 5300k vs. 6000k HID Bulbs
- Changing 9006 foglight bulbs to 9005
- more yellow
- GS headlights - any difference btwn the years?
- Phillip 6K D2S ?
- SC300 heated seats switches lighting
- Led?
- Light bulb out code when converting to HID?
- Dashboard display fading to dark
- ES300 OEM Head Light on ebay
- What HID Light Kit are you using?
- Yellow Fog Bulb Wattage
- ES250/LS400 Yellow Foglights (GEN I)
- Questions about replacing stock halogens with xenons! '90 LS - all help appreciated
- any upgrade/replacement for reading lights
- Stock Hid Lights On My Gs 400 Where .....
- matching stock hids
- OEM Lexus Housing
- 06 GS300 Projectors
- HID conversion
- low beams for lx470
- blacked-out lights
- headlight beam pattern
- Learning to work with LED's?
- Wtb:2-d2r Bulbs
- Fog Light Problem
- Help installing Lower rear Brake Light Bulb
- GS400 HID vs. Non-HID pictures!
- LED headlights
- Color Matching
- Sylvania SilverStars in size H11 (GX) not available for year
- Audi TT Bi Xenon lights
- Yellow Capsule Retro
- Philips Brand 4600k vs. 6500k Xtreme HID Conversion Kit
- SC4 Headlight Cleaning
- Sylvania Silverstar lights
- QUESTION: 1999 gs300 wants an HID kit
- Dying HID bulb
- a question about street legal aftermarket lights
- replacing ls400 headlight bulbs
- help! fuse for wedge bulbs?
- one side of hid does not ignite...
- HID replacement kit....personal preferences?
- hid shield
- High wattage ballast!!
- Fog light bulb recommendation
- Q: xenondepot.com install in SC
- Yellow Cap Foglights
- light indicator flashing...please help.
- banning hid? what do you think?
- Is this GB too good to be true????
- Is there such thing as a xenon-charged halogen bulb?
- whats needed for hid conversion on 98 ls400
- did i get rip off?
- Help finding yellow fogs for my '99 GS300
- When bulbs go bad
- Could someone post a picture of Philips 6000K replacement bulb packaging?
- Kudos to Steve @ XenonDepot !!!
- Where can I buy Philips 6000K HIDS ??
- Polarg M6
- 2gen GS Fog lights??
- Philips Hid Ballast mounting
- VERY very lo beams how do i fix
- Lights
- Evasive loose HID connection
- HID Conversion kits
- One piece headlights for 1st gen LS
- 95 es300 Hid installation
- tail light relay
- Upgrading to HID (involving Self-Leveling Motor)
- Colored Housings for HIDs?
- Strange Lighting Problem?
- Clearing Corners
- Removing moonroof / map light panel for one-of-a-kind / first ever on CL mod?
- 96LS warning light on cluster
- xenon depot 6500k hids
- 2004 ES330 HID Lights.
- New Lighting Mods Done
- Looking for single OEM HID bulb OR suggenstions on good place to buy 6000K online
- adjusting fog lights
- Headlight Aiming
