View Full Version : Lighting
Pages :
12]
13
14
15
16
17
18
19
20
21
22
- Best Visibilty? Halogen to HID in '05 GS.
- Silverstar bulbs arent as white as i thought???
- is there a different between HID head light hosting and NON HID
- 98gs400 liscense plate lights
- HID Kit Installed today on 00 LX470
- Question about Stock Bulb to aftermarket w/fogs
- Change clock display color
- the LED conversion you guys laughed at
- $7 Mod, Preview PICS! LED bulbs
- Is350 Bulbs ?
- 93 Gs 300 Hid Kit/retrofit
- Need 1156 LED Information, Guru's please post.
- signal lights
- Big'ol huge honkin' 10 mm FESTOON
- Polarg M4 or M6's?
- Question for you electrical people: Voltage drop?
- Changing the vertical angle of SC300 Headlights
- HID Kit ????????
- IS250 - New fogs and low beams
- HID Driving Lights.... HID backup lights.. anyone?
- Upgrading HID
- Which HID kits draws power directly from the battery?
- 96 ES300's bulbs
- daytime running lights
- Question for those of you with aftermarket HID kits
- led's for footwell
- Tail light of RX300 ?
- Backup lights for 01 gs4
- HID kit problem... ballast?
- HID driver side wont work!
- Sylvania....do they make turn signals for our SC430?
- hid question
- Disabling Auto-level headlights in GS400
- One HID whiter than the other
- Where to buy HID bulbs '98 LS400
- fitment on 1st gen Ls
- GS Brake lights
- Need new ballasts
- Projector Positioning & light output
- sc amber fog lights
- Headlight/Foglight install help needed!
- HID Help !?!?
- GX, fogs on w/o headlamps on
- Is there still an HID kit ban for US Sellers?
- 01 GS430 daylight running light bulbs?
- Group Buy On Hit Kit?
- brighter trunk lights?
- Problem with HID's
- driving light upgrade
- help with headlight beam adjustment
- Corner Light Conversion
- HID leveling on IS300
- Festoon LED bulb intermittent problem
- Interior. dash. acc lights out
- aftermarket fog lights SC
- will this bulb work as the rear turn signal on a 06 IS???
- White bulb
- if u bought the xenon depot kit please help
- how to take off the 1998 GS 400 head light
- Any problem in running an 85w bulb on stock fog light wiring?
- How do you get to the DRL bulbs on the IS 250/350?
- Instrument Cluster White backlight
- HID conversion
- Lexus GS/ Honda S2000 Retrofit Remixed!!
- thinking of doing tsx hid retrofit also tsx yellow fogs
- im not sure why it wont light up
- d2s question
- Map Light Switch
- TSX VS TL projectors
- Wrong bulb?!
- 98-05 GS interior light fitment
- GS light question
- 00 ES300 HID conversion
- 93 Ls 400 Light Trouble
- How to clean??
- Maxima 03 Hid ...question
- Something I saw today
- 99 GS300 Headlight help
- wtb rear tailight assembly
- WANLI tires?
- LED - T1 1/4 to replace NW1/NW2 Incandescent
- get 4300k or 6000k
- Replace 1997 ES300 headlight bulbs
- HiD experts chime in I need some help
- Headlight Auto Levelling Dash Warning Light..How to diable it?
- Spoiler LED Replacement for 1999 SC300
- Help! light for a 06 GS 430
- D4S Bulbs
- Blue bulbs?
- Good craftsmanship
- Yellow Fog Lights '98 LS400
- Price/Quality comparison wrt Pre-Fab retrofits
- HID high beams?
- HID help
- LOOK LOOK, LOOK what I finaly FOUND
- daytime running lights/high beam bulbs to match HIDs on GS400?
- Found these: Blitz hid kits
- HID What Brand?
- E39 Xenon Projector - before and after year 2000
- 12v Power Supply to Test Ballasts.. .Cheap
- help on color match out put
- HELP...just rcvd my HID kit....is it necessary to use to the optional relay????
- HID conversion
- Which Hid Bulbs?
- Just got my GS.....have some simple lighting questions...
- Question about OEM HID headlights
- any 92 LS400 hid kits?
- Brighter HID's
- Good place to buy bulbs?
- refinish headlight lenses? what sander
- Tail light FOG light!!!!
- What exactly do I need to get HIDs
- Denso/Koito Ballast pin-out
- HID Yellow Fog
- HID question....is 6000K blue or just super white???
- Yellow 1156 signal bulbs in chrome
- How many HID headlight leveling sensors on RX 330?
- hid 3000k on fogs...
- HID help.
- bulbs for yellow fog lamps
- PIAA Lows and Parking
- Bulbs for Clear Fogs to Match Factory HID
- Upgrade US Spec HID with JP Spec
- 2001 ES300 Xenon or HID
- best BRIGHT YELLOW 9006 to use in fogs on my GS4?
- Just a heads up to people using Polarg M6's
- Need projector shrouds
- 80w bulbs in foglight GS4
- Moisture
- Independent Foglight Mod
- 3000k HIDS in my 98 GS fogs.. opinions requested..
- Jag-SC HID retrofit
- HID question for a 2006 LX470
- Aiming Headlights on GS400
- 9003 same as HB4?
- Can I retrofit w/o a relay?
- SC400 HID conversion done, one bugger.
- Xenon Bulbs for 1999 ES 300...non-HID
- Questions wiring foglamps
- opinions on ground lights
- Led's for gs
- super white LED for gagues
- Most Important Questions Regarding Xenon lights!
- How replace a side marker light?
- trade tsx projectors for audi tt projectors?
- Bulbs to make clear sidemarkers match HID yellow fogs?
- New HID in ES300
- 1998 SC400 Fog Lights Bulb Replacement
- CHEAP DIY SC300/400 HID Projector Mod
- Phillips NightGuide: 3-in-1 safety technology Bulbs
- 9006 harness connecter
- D2S Problem
- LS430 fog lights (2004 and up?)
- Hid
- Look what I found - PIAA HID 6600K bulbs!!!
- will i be able to clean out my fogged up headlight?
- Color shift
- LS 430 projector question
- Aftermarket HID in a 2000 ES300
- Help locating relay
- Day-Time Driving light...?
- halo lights
- GS 400 Fog Lights?
- Help!! Electrically Challenged!!!
- The new GEN of HID ballasts and bulbs.
- Piaa Gt-x Plasma? Good?
- anyone live close to memphis?
- HID in non-HID housings
- Anyone have instructions for putting in a phillips kit?
- Ok.... now whats up with my light output? it sucks!!!
- are these bulbs safe for my 97 ES?!
- BEST BRAND BULBS no ricer blue WHITE with light tint of blue~
- wheres the Ballast hole
- i need new healight lenses, where to buy
- will 9006 fit into a 9005 socket at all?
- Where to buy LED circuit boards and bulbs?
- 1st Generation retofits
- How truly bright is a Phillips 6000k kit?
- headlight aiming for 97 SC400
- 98-05 Gs Hid Yellow Fogs? Help..legit?
- Retrofited and not lighting up help!
- Breaker Breaker One Nine
- Smackdown
- GS3 versus Q45 HIDs
- 9006 6500k Xtreme HID Conversion Kit
- Sc 430 Park Light Replacement
- light bulbs-sc400 - 1994
- Signal lights specification/model?
- Curious about headlights
- 98 GS 300 Bulb Size
- 2003 RX300, all lights are 9006?
- HID Retrofitter
- Retrofit sc400
- GS HID fog light fuse questions????
- Help Contacting Xenon Depot
- bumper light installation
- HID Problem, please help.
- Owners input on HID bulb conversion
- Thanks for all the help
- HID INstall Help
- Dust Cover Problems on an IS???
- 98-00 SC400 Foglight Problem
- Newbie help with Sc 300 headlight housing removal
- Blue/ White Rear Licence Plate Lighs?
- Want to replace Driving Lights on 02 GS430
- test test(rx330)
- Greeting
- Rx330 : Afs Off Light Blinking?
- Clear bumper lights w. Polarg bulbs
- Customer with 2001 ES300 wants HID conversion..
- Dumb question
- Footwell Lighting
- Rx300 hid, do I have them?
- Highbeaming makes my fogs go off...?
- Cluster
- Polarg 9006 Miracle White
- Illuminated door scuff plates
- yellow fogs???
- Yellow Bulbs
- LED festoon replacment for 2040 bulb
- Had a Question about Headlights
- HID kit for ES300 .....
- are 98ls bixenon?
- Suggestions on secondary light replacement
- Doing an HID retrofit
- Bulb replacements?
- HID Conversion kit? Purple looking at the bulb, white on the ground which kit?
- Clear LS400 headlight! Looks like its the 1-2 gen
- HID burnt out. Why upgrade to 6000K??
- Clear Bumper Lights...
- Bulb changing instructions
- Headlights and Fogs on LS 400
- Remove overhead lights
- New IS and GS Info
- 99 gs400 bulbs blown, good replacement?
- Taking Apart Foglight Housing?
- Bulb Info?
- Dash Lights Question
- headlight mod.
- HID Kits For An IS250??
- E46 Hid
- CLear Bumper Lights.....
- Sc Foglights Aftermarket?
- An older 2005 Altima retrofit I did over the summer with LS430 Projectors
- Angel Eyes, LEDS, and Tails..... A rolling UFO
- 1156 bulbs
- hid kit question...
- Need help on bulb plug connectors
- IS puddle lamps
- White halogens to replace factory bulbs
