View Full Version : Lighting
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18
  1. one side of hid does not ignite...
  2. HID replacement kit....personal preferences?
  3. hid shield
  4. High wattage ballast!!
  5. Fog light bulb recommendation
  6. Q: xenondepot.com install in SC
  7. Yellow Cap Foglights
  8. light indicator flashing...please help.
  9. banning hid? what do you think?
  10. Is this GB too good to be true????
  11. Is there such thing as a xenon-charged halogen bulb?
  12. whats needed for hid conversion on 98 ls400
  13. did i get rip off?
  14. Help finding yellow fogs for my '99 GS300
  15. When bulbs go bad
  16. Could someone post a picture of Philips 6000K replacement bulb packaging?
  17. Kudos to Steve @ XenonDepot !!!
  18. Where can I buy Philips 6000K HIDS ??
  19. Polarg M6
  20. 2gen GS Fog lights??
  21. Philips Hid Ballast mounting
  22. VERY very lo beams how do i fix
  23. Lights
  24. Evasive loose HID connection
  25. Evasive loose HID connection
  26. HID Conversion kits
  27. One piece headlights for 1st gen LS
  28. 95 es300 Hid installation
  29. tail light relay
  30. Upgrading to HID (involving Self-Leveling Motor)
  31. Colored Housings for HIDs?
  32. Colored Housings for HIDs?
  33. Strange Lighting Problem?
  34. Clearing Corners
  35. Removing moonroof / map light panel for one-of-a-kind / first ever on CL mod?
  36. 96LS warning light on cluster
  37. xenon depot 6500k hids
  38. 2004 ES330 HID Lights.
  39. New Lighting Mods Done
  40. Looking for single OEM HID bulb OR suggenstions on good place to buy 6000K online
  41. adjusting fog lights
  42. Headlight Aiming
  43. Fog light problem
  44. info on aftermarket HID SAFETY issue
  45. high-mounted stop light bulb replacement
  46. backlight light mod
  47. what about these 6000k hid bulbs
  48. led headlights.will lexus follow
  49. LS400 HID/Halogen
  50. LS430 Mirror Puddle Lamps
  51. Sylvania Silver star 9005ST
  52. What do you guys think of these?
  53. Ladies and Gents.....The GS Retro is done!!!!
  54. HID laws in Florida
  55. OEM HID auto leveling system
  56. HID question
  57. reaiming headlights on 94 ls400
  58. Projectors?? hook up?
  59. My own ECE Bosch (E46) Retro on my ES300
  60. New GS retrofit
  61. q45 projectors already installed from japan??
  62. HID High Beams
  63. retro help - removing headlight glass
  64. sc300/400 new body style fog lights
  65. Aftermarket HID vs. OEM Lexus HID's ???
  66. Need help adjusting Headlights UP w.HID
  67. ES300 bulb replacement
  68. HID bulb interchangable?
  69. Has anybody ever had Hi/Low HID kit installed (95 LS) ?
  70. 9006 to OEM HID ballast adapter?
  71. HID kit help
  72. Whoa HID Overload!!! HEhee
  73. GS430 Clear Corners
  74. Does any one have HID Fog?
  75. Holy smokes! Look at this GS retrofit!!!
  76. OEM HID Housing install to NON-HID GS
  77. M6 reverse light application
  78. GS400/GS430 HID Cut-off Line Picture!
  79. 2001 Lexus GS Aftermarket Lights
  80. anyone know how to read schematics???- (for drl mod)!!
  81. Looking for 92-96 ES300 Headlamp set
  82. Ballast mounting?
  83. Foglights on GS430
  84. Please help me on HID stuff. (for IS300)
  85. HID Swap on LS400
  86. 98 GS tail lights....help?
  87. Need verification help: Are these real E39's?
  88. HELLA Ballast compared with PHILIPS Ballast.
  89. es300 rear tail lights
  90. HID headlights
  91. relay? corroded and rusted on my aftermarket HID
  92. Yellow OEM foglights
  93. HID flickering
  94. HIDs?
  95. Fuses
  96. SC400 E39 retrofit Completed
  97. Yellow fogs
  98. what can I do?
  99. guys, need help on certain bulbs
  100. LED Replacement Bulbs
  101. I put in my hid's....bulb didnt fit, i made them fit (aha) BUT...
  102. H3 Fog Bulb Keeps Burning Out???
  103. Can you help please
  104. Help with Hids
  105. hid kit help
  106. 9006 hid on gs300
  107. 9006 HID on a GS300
  108. HID Headlights
  109. Why is it so hot
  110. 6000k burn in time?????
  111. Has anyone?
  112. anyone done the fog mod and had it work normal in auto mode???
  113. Piaa H3C
  114. GX 470 Headlight
  115. HID's in Taiwan
  116. who has sc300, with yellow fogs?
  117. Help Please!!!!
  118. Fog light mod on a gs
  119. HID cuts off sometimes... help..
  120. Healight has a foog look *Help*
  121. HID? Dumb Question
  122. Where can i buy philips 6000k dr2 bulbs
  123. Which Wedge bulbs are you guys using for your SC?
  124. Hacker in the HID forum! (hidforum.com)
  125. Which H3 Bulb will match Silverstar?
  126. HID housing power socket
  127. Small orange lights ( I dont know what they call them)
  128. Adjusting and aligning new headlights in SC
  129. Angel eyes turining differnet colors?
  130. Superflux leds?
  131. Mounting the Ballast in The 400
  132. Connecting the Ballst
  133. Reflectors or Projectors???
  134. whoever said the 9LEDs matched 6000Ks perfectly
  135. Whats The Best HID Bulb for the sc300??
  136. Which light buld should i buy?
  137. Which projector to use?
  138. xenon hid headlamps
  139. ES300 HID RetroFit Pictures/Questions
  140. Weird headlight assembly or not ?
  141. City lights, fogs, and rear lights won't turn on!
  142. Hid
  143. Has anyone bought from jus4bulbs@yahoo.com?????Hey
  144. burn in period for HIDs?
  145. Difference between D2S and D2R?
  146. Changing HID bulbs for 1998 LS400
  147. Removing the projextor
  148. Leveling Motors
  149. LED light bars for turn signals?
  150. Fog light problem... WTF!!!!
  151. Need help. I blew something!!
  152. Dash LEDs
  153. 1995 SC 300 H3 Fog replacement
  154. H4 Hi/Low kit for 95 LS. Any benefits ?
  155. Condensation Problem
  156. Piaa H3 Gt-X Vs Piaa Spark Blue
  157. Where Online
  158. searching for philips ultinon
  159. confused about this custom HID kit i bought.. help please
  160. need good hid's
  161. HID retrofit for 96 LS??
  162. xenon mods
  163. repairing 94 LS Deer Impact damage.
  164. Anyone know much about DDE Halo Lights?
  165. HID conversion
  166. Replacing the 2nd light on the main Headlight
  167. Installing Hella Supertones
  168. headlight bulbs
  169. Piaa Bulbs
  170. how do you adjust headlights
  171. ?
  172. projection headlamp conversion kits?
  173. 01 430 DRL questions
  174. Awesome HID Retrofit featuring a first gen 3000GT
  175. HID's 95 Sc300 Tutorial w/ Pics!
  176. Philips Bulb question
  177. Buying Replacement 6000k bulbs?...
  178. HID questions for ES300
  179. LED's for turn signals??
  180. HID bulb vs. HID kit
  181. Tiny light bulbs inside heated seat switch REPLACEABLE?
  182. sc300 map/dome light bulb part #s
  183. Reconnecting HeadLamps
  184. Clear Lenses
  185. same OEM HID bulb, different color?
  186. MY climate control backlight doesnt work.. wonder why?
  187. IS300 Projectors and HID retrofitted on SC300/400
  188. Headlight accents!! COOL LOOK ON YOUR CAR!
  189. how much effort to retrofit D2R bulbs into the stock GS halogen headlights
  190. 2004 Lexus LS430 LED Tail Lights
  191. JP Tail Turn Signal Testing + LED vs Incandescent Bulbs
  192. ANYONE tried replacing the LEDs in their Dash?
  193. RE: H.I.D. Installation -MANARAY HELP!!
  194. Headlights!!
  195. Bulb Out
  196. Problem: 4500K to 6000K bulbs
  197. Xenon Depot 8000K
  198. Headlights/Turn Signal
  199. UPDATED 2008 Wedge Bulb options (2GS & 3GS) comparison
  200. Daytime Running Lights Module
  201. Removing Headlights on GS300
  202. RX330 HIDs, too low?
  203. Done HID foglight on your GX??
  204. hid costs
  205. Catz HID replacement bulbs
  206. Rear Door Panel Lights Not Working?
  207. Rear Door Panel Lights Not Working?
  208. DRL and HID question
  209. Is there anyway to convert Hid bulb H4 ->9006?
  210. RX330 HID Matching
  211. hid bulb, it only take one shot to...
  212. GX's have projectors? Chance of Retro?
  213. clear fog lamps and new lights for rear spoiler
  214. projectors
  215. Hmmm..what's going on with my foglight? and more...
  216. Hmmm..what's wrong with my foglight?
  217. Hid Harness Missing *Help*
  218. 97 style wing needs brake light wiring?
  219. Puzzling Tail Lamp Problem
  220. 99 gs400 head light wiring
  221. LS400 tail light bulb housing rusted.....
  222. nice resource for bulb types
  223. Need help w/ light pods
  224. Problem with adaptive headlights
  225. factory HID problem
  226. Shifter Light?
  227. Help please
  228. Q45 Projector Mod???
  229. 94 LS 400 HID Install
  230. changing HID bulbs
  231. hid problem need help
  232. Lighting Upgrade with my SC4 and questions
  233. Did anyone swap out their stock HID to 6000k or higher? (GS)
  234. I need to find
  235. Can Anyone Help
  236. Post pics of your beam pattern
  237. FInal shots of my retro....E39 color modded for my 1995 ES300
  238. H7 6000K HID kit from XenonDepot
  239. Sc430 Hid
  240. E39 projector?
  241. My 6000K HID Bimmer 5 Series retros on an SC
  242. 2000 ES Headlamp Removal
  243. McCulloch HID'S
  244. Sc dome light bulb size?
  245. 9-LED lights for 1st gen GS?
  246. Please help me get back to stock
  247. Whooaaa look what came in the mail 9led 194
  248. projector fog light
  249. My new M5 projector retrofit on my 1995 Es300!
  250. What Kind Of Bulbs Are These??
