PDA
View Full Version : GS - 1st Gen (1993-1997)
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. searched but just cant find, trac light problem
  2. Is it the ECU?
  3. 1st gen GS300 intake manifold plugged?
  4. Anyone fit a 10.5 +0 in the rears? Checked rimtuck allready-
  5. The gs no one will be interested in
  6. Help with Bleeding Aristo JZS147
  7. 1gs new owner
  8. Two windshield washers?
  9. Gs 400 l-tuned
  10. windshield wiper problem
  11. Window Regulator & Motor
  12. ECT button issues
  13. Locating yaw sensor
  14. Clanking noise when moving the steering wheel
  15. Tweeters
  16. stance gr+
  17. 2jzgte OEM boost/ PSI question
  18. IM BACK! VIP styled GS300 from the 808 state!
  19. Caster adjustment bolts Need part #
  20. Windows are not working.
  21. Seat Covers??
  22. Got my ggp Paint job
  23. Failed smog, what could be the problem?
  24. swap comlplete, sneak peak
  25. Almost Crashed Need Help
  26. GS400 Front Calipers Bolt on To GS300 ?
  27. leaking PS fluid.
  28. 1993 Lexus GS300 problem....
  29. Question about key ignition ring light. It won't shut off.
  30. IWTB driver window motor
  31. racing seat brackets
  32. 1993 gs300
  33. Severe vibration
  34. Trans question
  35. Which car is favorite between 1st generation GS300/Aristo & SC300/400?
  36. what is your MPG?
  37. The Gs baby boy!!!!
  38. Someone help!!!93 gs300 engine swap
  39. Lug Nut Studs keep breaking off..... help
  40. 5 GS300 at the Ontario junck yard pick a part
  41. what ive been up to
  42. Car wont start... WHYYYYY
  43. Tiptronic
  44. speaker adapters
  45. Need engine swap help
  46. 93 gs for sale
  47. Valve Cover Gasket Replacement
  48. 93 to 94 difference on a gs300
  49. HELP Need 96-97 GS300 ECU
  50. how durable are first generation GS300 oil pumps??
  51. Does any1 want a 93 lexus
  52. MN LEX owners?
  53. Oh man, I think the motor is going. Help!
  54. Cruise flashes on startup
  55. aristo differential lsd?
  56. 93 Gs300
  57. Hesitating to go
  58. Fixing Aristo foglight
  59. 93 gs300, its beat up, slowly fixing it
  60. FS and WTB go in the classifieds only please
  61. Damn. Two years and 50k miles will do a lot to a car. **Pics**
  62. WTB: GS300 Leather
  63. Voltage draw.
  64. Big noobie spark plug and gasket question
  65. no sounds in stereo 1994 GS
  66. 2jzgte turbo downpipe/ headres?
  67. Prepairing mission from Miami FL to Detroit MI
  68. Trans Tackle
  69. request suspention and brake list
  70. Wheel offset + tires help?
  71. Need size of pressure plate/torque converter bolts
  72. 1993 GS 300 Power Steering Problem
  73. How does everyones lowered car ride?
  74. Injector help
  75. Is anyone using a fan clutch with the 2jzgte swap?
  76. I can't tell how much gas my car has :(
  77. 95 gs 300
  78. Which o2 sensor for toyota aristo?
  79. High beam question
  80. The Official GS300 to Lexus Part Interchange thread
  81. matte black
  82. ALL knowlegable diagnosers PLEASe comment
  83. driveshaft issue
  84. if i was switching to single..
  85. questionable service records??
  86. Total lighting problems
  87. Power Seat Motor
  88. Hello Lexus Fam
  89. Broken Front Seat Motor
  90. help please-odd sized rear brake rotors
  91. Start your engines... Uh oh no piping
  92. The Noob needs help
  93. Question for those with df-210
  94. Headlight lenses
  95. How to hot wire aux cooling fan???
  96. new wheels waiting on my coil overs!!
  97. Key Locked in trunk of 93 GS300.
  98. ignition ?
  99. need a steering rack :(
  100. control arm #2 bushing finally done
  101. So, I decided to replace all my suspension parts
  102. HELP! AC = no power steering and low voltage
  103. Bridgestone tires
  104. Pics from Liberty BBQ today
  105. CD Changer doesnt come out after unbolting?
  106. 1996 GS300 -My family hauler
  107. Dead Sound, Head Unit Works, Need Advice asap
  108. where are all the creative minds?
  109. EMERGENCY my brakes dont work
  110. wheels
  111. Back/Rear Winshield - Special Request
  112. How do I replace the right side rack & pinion boot?
  113. Pictures of my whip!!
  114. SERPENTINE BELT REPLACEMENT NEED HELP....how difficult to do myself?
  115. Stereo update - new head unit, can I use stock amp?
  116. first introduction
  117. 2jzgte swap powered twins opinion!
  118. Another overheating thread
  119. anyone knows this bodykit?
  120. Tilt Steering Wheel Motors
  121. is300 diff in a gs?
  122. New member looking for exhaust
  123. Aristo Twins RESCUE.
  124. PCV hose? Seafoam & Oil change question
  125. Trac Light w/no Check Engine
  126. 93 gs300 blood diamond
  127. rear sway
  128. aristo swap ???
  129. Muffler
  130. New world for GS first Gen for coilovers
  131. Braking system question **Pics**
  132. JZS147 swap/ Electric fan control.
  133. Where can I get rain guards
  134. stainless steel exhaust owners!
  135. Spare keys??
  136. thermostat is installed correctly car still overheats
  137. lexus cd changer cartridge, I need a new one
  138. 2jzgte first start up help?
  139. w58 swap?
  140. Will a sr20 nissan intake manifold fit on a 2jzge?
  141. supercharger kit
  142. Hi, i got a question about the apexi vsafc
  143. Pictures with new Vogtland Springs
  144. Importing a Aristo from Jp to the USA
  145. Help!! Dying Of Smoke Inhalation
  146. TPS Location
  147. Alarm
  148. left rear interior lights
  149. I need a body guy
  150. Charging system issues help
  151. Need Help: Wheel Coil setup advice on purchase
  152. www.theretrofitsource.com
  153. 1993 Lex GS300 3" cat back?
  154. GTTE on GE
  155. headlight projector assy. question!!!
  156. fog lights without headlights on
  157. Which water pump do I have?
  158. 2jzgte owners out there, Help?
  159. HID reverse lights
  160. car wont start in the rain?
  161. My GS300
  162. Blew a Headgasket - time for new car
  163. Transmission Question
  164. STUPID MOTOR! Will a motor from a '99 fit in a 93 without modification?
  165. My Aristo in body of Gs
  166. New engine
  167. My first 93 first gen gs
  168. DIY: Aristo bumper install
  169. Need help big time
  170. Will these Supra TT Megan Traction rods fit our chassis?
  171. ATF's A340E
  172. Vogtland Springs going in Friday - Quick Question first...
  173. how much are they worth?
  174. JZS147 to UZS143?
  175. Looking To Buy 95 Gs 300
  176. broke transmission cooler line
  177. AFM Short ram air intake??????
  178. New here photos og my 1st gen
  179. My 1st Gen
  180. Our photoshoot! (2-1GSs)
  181. Photoshoot pics! mine and another members 1GSs
  182. 95 gs 300
  183. 1st Time Tire Buyer!!! Needs Help!!!!
  184. I Can't Get My Old Spark Plugs Out
  185. Needs a picture of the front of the car with your hood open
  186. Entertainment reading for you
  187. Squeling and low idle RPM...Does anyone have any advice on how to fix this??!!
  188. Check your blower motor for nuts!
  189. 2jz aristo swap help
  190. Which Model is this WALD wheel?
  191. newbie
  192. Manual
  193. bc coilovers
  194. 2005 GS300 Failed emission readiness test
  195. Header...
  196. help! running rich!
  197. I couldnt find this RARE lip for sale so Im making it
  198. Chaser4lif Gs300(2jzgte) Into,Yerro!!
  199. New from canada eh
  200. 2 Door JZS147 #weird
  201. 94 GS300: Introduction/Progress pictures
  202. Gas Tank
  203. ? offset
  204. Losing coolant
  205. How to change license light bulbs?
  206. JDM folding mirrors?????
  207. my 1996 gs300 will crank but wont run
  208. GS300 cluster/1UZ motor compatability
  209. Legit?
  210. Vin code plate ?
  211. My official picture and update thread....
  212. Help me decide on these 2 rims - pics included
  213. What happened to my old GS
  214. Can the Amber reflector be removed from headlights? (usdm)
  215. New audio system install help (south florida)
  216. Buying 1993 lexus gs 300 window visors !
  217. IS300 LSD in the GS300?
  218. Question about window regulator speed
  219. help please
  220. Help Please
  221. +25 all around ISx50 wheels?
  222. ae angel eye
  223. a/c problems pls help!!
  224. hi im new here is my 1st gen GS
  225. Custom 4" exhaust issues, ideas?
  226. iPod Grievance!!!
  227. Telescoping Wheel Problem...
  228. Should I do spacers?
  229. Leather Seat Replacement
  230. Obsidian Jade Lexus....I Have A Request
  231. I heard when you hit the100mhp that the car lowers itself for better handedly.
  232. GS300 window visors/wind deflectors
  233. Hot vaseline oil pump prime!!!!!
  234. OBD Scanner
  235. two tone with white on top - what colors?
  236. Finally bought a GS :) I have 2 questions?
  237. cant get my car to turn over HELP PLEASE!!!!!!
  238. 94 GS300 Pwr steering pump
  239. 1993 gets 9 mpg, is this normal?
  240. Anyone have pics of this spoiler?
  241. air cylinder problem
  242. Hot Wheels
  243. 1GS exhuast clearance
  244. pics
  245. This or that?
  246. Help please
  247. Clearing heads nd taillights
  248. lookin for left outer tie rod
  249. Code 25 fuel lean
  250. need help takin out my starter
