- gs300 tranny
- Car audio wires for 93 lexus gs300
- problem with cluster like everybody knows.
- 94 Gs for Sale
- Replaced my 2jzge and now it won't start
- Moving Forward...TRANNY DEAD!
- car audio wire connector
- introduction
- 94 GS300 exhaust question
- New to this..1993 Lexus Gs300
- Knocking after new rod bearings?
- 1993 gs300 throttle body stuck to Y
- Brake Buzzing
- 95 lexus gs300 remote door receiver
- Next problem.... Codes 25 and 26
- Where do these plug in?
- 93 GS300 rough running, stumbles when accelerating after water sprayed on engine
- Do you prefer to drive with OD on or off?
- Is the Lexus Main O2S the same as oxygen sensor???
- Rough cold start problem, but idles fine once it's warm
- 1993 GS300 Fuse Box Diagram
- Subwwofers and amps
- Tein's
- AC temp control problems
- Oil leak help
- No sound out of the radio 94 GS300
- new stance, new kit, new pics
- JZS147 led tail lights conversion
- Weird Noises
- Wierd problem
- My first gen rolling with a gallardo **video**
- Finally got my gs!
- 22" Versante'
- Just bought 1995 Lexus GS300
- first lexus
- New first gen owner
- 19" Stance 5 spoke wheels
- Random Tune Up+Maintenance Questions (Help Needed ASAP)
- 93 gs300 wheel stud issue
- Window Switch Problem
- attempting to pull a code with a paper clip, chime in please
- Will 20" wheels fit on a stock Lexus '95?
- Cranking Issues
- Finally!!
- 2jzgte radiator upgrade?
- lowering help
- p0401 egr flow insufficient
- Drift Aristo back with some Aero and Interior
- 93 gs3
- Gs3
- neon lights
- 2008 Gs AWD 350 will not start
- help gs300 windows and sunroof dont work
- Radio amp/computer thing needed!
- taillight issue
- Neon lights
- Subwoofer
- Help! Stuck Between A Rock And A Hard Place (pics)
- Getting ready to upgrade my turbo...
- How many quarts of TRANS fluid?
- 94 GS300 new car (dash light help)
- R154 swap
- And the best looking GS is ?
- 4 problems solved with one fix
- headlights
- Lowered a tad bit more.
- Invisible Air filter
- In Need of 1st gen service manual
- Traction Control
- over heating Gs 300
- Don't care how cheap, FS doesn't belong here. Use the classifieds
- sounds like I have a pager vibrating in my console unit
- 1998 lexus gs300, fan blower not working
- Hid problems
- My First Car! 1994 Lexus GS300
- 2005 Lexus GS 300 brake light problems
- OBD scanner for GS1??? Check Engine Light Code?
- Arm rest console
- No Master Key!!
- The Search Is Over...
- New to the scene..
- New Lexus owner,Help!!!!!
- Random Pics of the Work Eurolines on Bags
- Standard Sub grille/cover removal... how?
- TRD SUPRA MOUNTS and bracket fitment issues.
- 1999 GS 300 Trottle Position Sensor
- Failure Code Pair 41 & 71
- leaky fluid
- GS Axle Ratios
- New Guy on the Block
- Help needed!!
- Major fuel rail leak, engine slowly dies out...
- New fuel pump? What do you suggest....
- bolts, nuts and studs for sway bar links?
- finally got my GS back!
- wanna order some new emblems
- Interchange Table?
- Just new photos from this morning
- SC guy needs help with a GS radio
- has anyone figured out the sc300 power seat pin out
- Goodbye GS
- 94 GS No spark will not start
- 94 GS300 Cluster on a 93
- First pictures
- My new GS
- Random Question: Anyone know if the condenser fan functions as a pusher or puller?
- Where to get a half cut/front cut?
- out of the game
- Battery Not charging
- Rim/Wheel Size for a flushed look?
- 17x10 on a 1st Gen?
- po446 code
- AC Question
- Couple of questions on my DD?
- My rear VIP tables!
- 94 gs300 hard to start then dies
- O2 sensor question
- Which A340E??
- Crazy ideas/if you had crazy money would you... (discussion)
- Proud New Owner Of A 93 GS300 with a 2JZGTE Swap
- OFFICIAL Imports Alliance attendance thread...
- Chewed through fender wiring harness
- Need ac help
- Powering gauge cluster outside of car.
- will these wheels meant for a nissan 350z...
- Which water pump is the right one?
- No crank,/ car acts like battery is dead but it's not:(!
- check engine light on code P0128 help
- 6 spd supra rear end in a 1St gen. Is it possible ??
- 2jzge na-t question
- GS Odometer Correction
- need help with cluster :(
- custom fogs on a gen1?
- dirty motor
- Diagnosis: Strange Front Engine Noise (Vid)
- is300 seats all hooked up! 1 problem though
- Fuel Economy
- Fuse for Windows and Tilt Steering
- talk about a busy 3 day weekend ahead for me
- A way to id which lifters go where?
- Stress from the GS
- 1993 GS300 w/ 81k original miles
- Want to do LS400 BBS
- love my lexus but she (my lexus) is giving me problems
- 1993 gs300 control arm bolt attaching to subframe part number ?
- Headers
- Well, I found out why my rear windows don't work...
- how mamy quarts for trans fluid?
- Windows off track need some help
- gs300 timing issue
- think my transmission is shot?
- Just got 94 GS300, many questions
- radio/wiring issue
- TPS sensor
- TPS sensor
- Creaking noise front passenger side 98 GS300
- Headlight problem !!!
- Guess I Will Finally Check In
- What wires to use for turbo timer? I've searched and searched
- dubs or 20'' rims....why do most run 19"?
- Wat tire size for stretch/flush look?
- Photoshoot GS3 IS3 LS430
- ls400 air suspension? on g.s.????
- Carpet
- 95 GS lexus300/aristo window vents
- this bodykit
- 2JZTE Intercooler
- Stripped head stud! HELP!
- 95 gs300 auto to manual ecu pinout!!!!!!!!!!!!!
- Diff.
- Sway bar QUESTION!
- Deleting Egr system????
- help removing front and rear bumpers
- re: r154 extension pics
- camber problems!
- Good sound after market mufflers for first gen gs?!
- Replaced radiator and now ABS light is on.
- What is the best/worst compliment you got about your gs?
- Air runners
- wheel size.
- oil from intake
- How do you remove rear door panel?
- So, I am still alive BUT...
- Programing 95 GS300 Key Issue
- My Contribution to the 1st Gen Fam.
- steering wheels
- Bmw m series wheels 18inch
- Ground wire kit?
- time to work on the exhaust need advice
- Pros and cons of egr delete?
- Idles smooth then has spasms randomly, wth?
- Questions about stock twins
- Gen1 Gs300 is a ghost town!?!?!??!??!?
- 1jz swap in first gen gs
- aftermarket headers?
- My Gs300! Excited much?! Yes....
- Just a quick pic of the daily driver.
- Aristo in MI: Ghost Protocol
- Intercool options for GTE swap?
- JDM GTE swap starts when engine is cold, NEVER starts when warm
- New Kid on the block
- will gen1 sc exhausts fit gen1 gs?
- Window Trim
- Lowering my lex
- My introduction
- fuel consumption "trouble"
- New to ClubLexus, but my 2nd GS300
- NA-T, please chime in
- So I'm in a bind (must read)..
- New to the Lexus family hopefully this weekend.
- Front end body parts
- Wind visors installation guide ?
- steering rack and suspension questions.
- Reverse Camera Wiring
- Roof rack on a 1gs?
- Heres my GS300
- DIY: Cuban Wire Harness Relocation! ('93 GS300)
- Very loud whistling, engine chokes
- What spoiler is this?
- trouble with manual swap !
- Different colored GS's, post pictures!
- Hoodless JZS147
- Carwon't crank after i shut it off
- Nakamichi or Pioneer?
- Factory amp and cd changer
- Yet another problem, what now?
- Serpentine/accesories belt when removing AC ?
- what tuning device do you use??
- oem vs aftermarket
- ECU help
- gs300 trans question
- DIY ***Official Aristo to TT Camshaft uninstall/install
- ugh! i HATE liars!
- dash board lights wont work
- 1st Generation check in
- Need advice
- camshaft caps causing low oil pressure??
- Gs300 foglight overlays
- Serpentine Belt and Tensioner Question
- fuel pump upgrade
- 1994 Lexus Gs300 Fan Casing Question???
- will mk4 tt supra mid pipe fit the 1st gen gs with TT swap?
- NA-T Sportcross
- W58 swap, orientation needed!
- pictures after i got the air runners
- 1996 GS300 motor mounts
- DIY ***Official LS400 Brake conversion with pictures***
- CAUTION.....LS400 caliper grinding
