- Dashboard lights came on with a loss of power
- I think I need a new Radiator? Help?
- What kind of full synthetic 5w-30 oil should i use on Lexus GS 300 1993
- Firmer suspension options?
- 2002 GS300 How to read dipstick
- Damn it was time,
- Dash Lighting LED upgrade Video - and punch list all in one place.
- Old School Toyota Aristo Ad
- 1JZ in a JZS147
- Metal rattle behind gauge cluster area on my 1993 GS300
- Lexus GS Cracks Most Iconic Hip-Hop Cars List
- No Start
- Help please, water leaking only when running
- 93 gs300
- starting problems
- Help
- FS threads go in the classifieds only
- Gs530/600 build thread (slow)
- 2nd Gen parts that fit 1st gen gs300
- Progress on my 93 GS300
- Door lock rod clip?
- Check engine light after speed cut
- Stereo Harness
- auxiliary input on 93-97 oem Pioneer head unit
- transmission swap
- Removing resonators
- Stereo wiring harness
- lock solenoid damaged
- Adjusting distributor for 93, safe angle?
- I want to put in some headers
- Map censor
- map censors
- Replacing Cam Seals
- Electric Issues/Frame Damage/Interior
- ecu interchange questions
- Still getting Code 21/27(or 28)
- 95 touring edition
- tuning
- knock sensor
- deciding on new exhaust let's see some pics
- Electrical issues
- Slipping when accelerating
- Sad, Sad Day
- Starter goin bad???
- Amp Power Wires
- GS300 control arms fit the Aristo?
- Steel Braided Brake Lines
- 1st gen Gs300 please help
- Swapping Aristo TT trans into a GS300
- HOW TO: Idle speed control connector plug
- Need help identifying rims for insurance
- painted 94 gs grill and decals done today
- Climate Control LCD screen?
- widest rear tire ?
- vvt-i swap
- Seatbelts: how did you re-color or changed them?
- What do you hate the most about 1st Gen GS300's?
- transmission doing what?????
- Stereo wiring question
- front bumper removal
- Header Install with Pics
- Back again :)
- wire harness tuck
- aftermarket sway bar options for 1st gen GS300
- v160 r154 w58
- water leak- 93 GS300
- Why was i not aware of this?
- Will the IS300 center console fit 1st gen?
- question
- WTB and Fs go in classifieds only
- Strange Ticking?
- Suspension Blues
- All-Fit Lip Kit on 1GS/JZS147
- wheelse size
- New GS F
- 1998 GS400 Humming
- New GS300 Owner mod's mod's mod's and more mod's
- Tire size question
- Will I Rub? -stock ride height
- DIY Gauge Cluster LED Needle fix
- Just a random question
- Rear Wheel Hub
- Transmission
- Engine swap 1993 gs 300
- smelling gas need help
- Idle air hose
- help!!!
- Well $!&#%!
- None of my exterior static lights work help!
- Window Trim Removal Tutorial Video (Front and Rear)
- Need Help Please!!
- Loud clunk and squeaky brakes when in reverse...
- Swaying side to side
- My GS300
- What all do I need for the GTE engine swap?
- Misfiring problems
- 5-1/4 inch to 6-1/2 inch speaker mount cutout.
- wheel hubs
- Window trim
- D.I.Y-Flasher Relay Mod-L.E.D HYPER FLASH FIX
- New seat and wheel
- aero fitment
- transmission swap
- Bucket seat rails
- Aux input question for the electricaly inclined
- For sale and WTB (want to buy) posts are only allowed in the classifieds.
- Struts/Lowering Springs vs Coilovers
- Is300 seats into a 1st gen gs300
- It's raining in my car
- Aftermarket Headunit Installation Question?
- need assistance
- Anyone using LED turn signal bulbs?
- Aftermarket Rear door speakers
- Ksport bbk reviews?
- What are your 1GS/Aristo/JZS147 Plans for 2015
- New Build Threads area for 1GS members
- Did my alarm disable my car?
- Wildwood Supra Big Brake kit on JZS147?
- in need of good cover for my 94 GS300
- 98 gs400
- Seat Belt "Guide"
- Farewell to my 1994 GS 300
- Aristo body kit driving lights
- CL Find! Need help, car won't start
- TT brake conversion questions?
- Issues with LT. Someone HELP Please
- Winter Time - heater checkups
- DIY Shock Revalve: PARTS 1-3
- Air Intake help
- Fix: peridically freezing speedometer & Fuel gauge reading below actual fuel level fi
- What now?...
- How hot does your GS300 run?
- my first gen
- Audio?
- Single Din or Double Din Radio
- thermostat housing water bypass leaking
- Used Parts?
- Like new (almost)
- tail lights don't work Need the help of a gs300 owner
- Headlights & taillights only work when switch to auto
- Where can I get a EGR Modulator?
- have to pull fuse to take out the key
- Key
- Yet another problem!
- Connector part numbers
- Spark Plugs?
- Tie rod in
- RPM drops, then returns to normal when coasting
- Factory amp through new headunit
- Gas mileage
- Black Headlamp Housing?
- 93" gs300 help
- my car starts but shuts off after a few mins
- Quick Performance boosters?
- Door handle swap
- technical drawing???
- Should I put money into my 95 GS300
- Door wont stay shut
- Code 78 1994 Lexus GS300
- Almost blew the engine! LOL
- Issue with weird/normal RPM behavior
- BC Racing rear strut dyno graph (for 8kg/mm spring)- GS300 1st gen (jzs147)
- JZS147 Video Thread
- Tires/Rims
- Quick Question
- need some help with measurements
- ABS delete on 1994
- Over heating issue
- Spark Plug Replacement
- RPM's Drop with electrical load. Stalls when A/C is on.
- HELP oil distick issue! i dont want to dry my pistons
- Coming back to the Lexus??
- code 25 plz help
- brake line questions
- Gs300 no engine
- Well guys
- Does Anyone Have an Aftermarket BOV on the 2JZ swap?
- power steering pump making noise while turning the steering wheel
- Ecu-Aftermarket Options
- Anyone need spare parts to the astray?
- Scrapping my '95 GS300-anything worth saving?
- Alternator problem: no battery lamp, new alternator burnt?
- 1st Gen GS Cluster Bulb Sizes
- First gen shifter boot
- Center console removal
- Power Steering Problem
- 93 GS300 Tranny Flush question
- Instrument cluster backlight on with parking lights or key only?
- Houndawg's / Bp's sound thread
- Headlight / Fog light HID's.
- Aristo 2JZGTE Swap Completed!
- Engines/harness
- Ball joint replacement issue
- 1st Generation GS
- Question about Seats for a GS300
- tired of searching
- Window Problems
- Need help!!!!!
- please help cracked tranny
- CatalyticConverter
- Accord none mugen lip!!!
- Performance Exhaust Advice?
- ECU to BODY harness plug pinout??? Anyone??? Hello???
- HKS Hipermax LS+ vs RS... Whats the difference?
- Transmission Problems
- Really need some help (Gauge LED change)
- common oil drip issues?
- JDM A340e Aristo TT Shift Solenoid Valves
- Facing a reoccurring problem
- '93 GS300 Sunroof Fix
- Requesting info. for my Aristo 2JZGTE swap
- 1993 gs300 headlight issues
- Timing belt
- Are there any write-ups on replacing a steering rack?
- Where do I start (audio)?
- What should I do?
- Going Awol for awhile to fix the turbo is300
- 93 GS300 compatible transmissions
- 2JZGTE V160 Swap now Speedometer doesn't work.
- Confused new owner
- Build
- 1996 gs300 2jz motor
- Bubbling-Boiling in reservoir tank questions
- Car knowledge share
- Gear Shift Setup / Cleanup / Brushed you say
- Favor if someone could take a quick picture
- Trans Fluid
- FS and WTB threads go in the classifieds
- Anyone Have Functioning Factory Keyless Entry
- Let's get a meet and greet going
- boost controller true twin
- Generation years
- K&N Filter on '95 GS
- Hid kits
- need help
- Redoing Front Grill
- 94 Lexus Gs300
- teins
- What kind of oil and filter do you use?
- New 02 Lexus GS300 Owner, Need Help
- GS 300 dies
- 1997-2000 JZS161 swap into 1st gen
- Need your input guys
- Suggestions?? New to the 1GS
- 1995 new owner new problems
- Blinking light
- Seat Wiring (hotwire seat control)
- shift console question. 5ect-i
- Selling ist gen 1993 gs300, low mileage
