- starter going...
- So I decided to...
- good mechanic
- Shark fin spoiler
- Seat warmer light
- Rim Help!
- JZS147 swap thread
- Rim Questions
- Need Some Opinions On My Gs3
- Suspension:- which is best
- Need new Exhaust for more clearence!
- Crazy GEN 1 for sale on EBAY with 1000+ HP
- Parts source links and Tranny AT to 6spMT swap
- Need help.....
- Looking for pics of ALL WHITE (SOLID) GS's. As many as possible.
- SRS warning light
- Thinking of getting a 1st gen....
- 1st Gen force induction Check in!
- 2jz swap no start!
- veilside body kit
- 2jz-gte swap
- Does Anyone Know....
- What maintenance should be done at 130k miles?
- Who has pics of.....
- Noise in rear suspension over bumps
- Changing my brake lights
- Car running too warm?
- I hate one tire fire!
- 2JZ Header....
- how many canadian guys on here waiting for aristos?
- anyone offer a 1st gen widebody??
- 9005 low beams
- First gen drifting?
- Replacing the wood grain...
- In need of a stock rim
- Anyone compared New OEM struts to KYB's?
- online store to get replacement parts?
- rev limit
- lookie what i got......very rare!!!
- CD Changer replacement for 93GS300 ?
- Options please!! New Grill
- Auction prices on Lexus GS300 1993
- Head Light Restoration Finaly!
- Another noob with a problem.....
- Good Engine Oil
- okay, so I am thinking of a project vehicle.
- 1993 1jzgte chaser oil filter
- You can eat off this 1GS engine bay it is so clean
- got backed into this morning
- Improvement in charging system
- Lets talk wipers!
- Aristo swap questions...
- Supra rear brakes...
- Issues w/ my 94'gs300
- What suspension for the gen 1?
- 1st Gen Getting Weak!
- pictures of my 1st gen bagged
- My front drivers side tire is rubbing... why?
- Keep traction control off
- Head Lights & A Tune Up!
- wheel size fitment
- 2JZGE performance help
- Vibration- every 3 seconds!
- Does anybody have...
- RSR springs barter in So Cal.
- Aristo JZS147 2JZGTE engine mounts
- 1jz into gs300?
- pictures of my Touring Edition 95 gs300
- older gs300 reliability questions
- Aristo transmission swap ?
- 2JZGTE swapped 1st GEN
- Meet me and my GS
- I finally got my Wheels!!!!
- Help: Greddy FMIC for Aristo.
- Park lights not working
- Lexus GS300 JDM engine
- TT supra motor mounts on GS300
- Looking for a way to raise the car a little
- Mk1 Gs300/Aristo pictures Needed
- Radio wire Diagram HELP!!
- 2jzge questions.. i'm new to imports
- Lowering with a body kit
- Ok im officially an idiot
- Headliner help needed.
- gs 300 93-97 passenger front fender
- Pedal Fell Off - Need a pic
- making the car quiet
- how much
- Rear bumper protector...
- lookie what i found -JDM
- GS300 - 1994 - Installing New Audio System
- 1st GEn Classifed
- 2jz swap
- problem with radio
- Catalytic Converter Issue!!!
- Dyno'd again today
- Exhaust Help!
- MAF cleaned, car now stalls...
- Will someone please Photoshop these rims onto this 1st Gen GS.
- where can i get brand new emblems at
- turbo timer
- Headlight Help
- Transmission Trouble..Help.
- Motor swaps with exhaust!
- Where to get a Exhuast?
- Sooooo. i sold my Aristo.
- Rims
- Wet Sanding
- Leaving the 1st gen posse
- gs300 parts
- squeak from HELL!!!
- Should I put these or not????????
- lights out on speedometer needle, tach too
- Sticking gas pedal
- Something is weird when running the car cold
- Fogged up Windshield
- Where to grab shocks?
- VERY WIERD TRIE PROBLEM ...advice??
- Brake Rotors
- Need some help with some wires!!!
- Will this harness work?
- Need Help and Advise
- What are your thoughts.....
- Blown rear main seal
- Aristo Dyno chart 12psi
- Can someone please tell me the widest tire you can put on a stock rim?
- exhaust from 1st gen to 2nd gen
- Question for you tire/fitment/suspension gs300 pros out there - ASA AR1's 18"
- Will my wheels fit
- restoration
- eclipse navagation
- Headlight adjustment ?
- Aristo Powah new dyno #s
- JTuned.com's coverage on LexAristo @ VIP AutoFashion
- gs300 trouble spots? Charging System + Radio Lockout code?
- license plate light bulbs?
- Gauge lighting!!!!!!!
- Aristo Powah! drifting pics
- Trying to find STOCK coil springs GS3
- getting keys made
- Its here Junction Produce full aero for my JZS147
- Rear window Seals STRATING TO GO, HELP
- Performance Chips
- my Aristo in action :)
- Exhaust opinion
- coilovers?
- pretentioner (Steering Rack)
- Brake light on dash problem
- How do I know if my headgasket or valve cover is leaking?
- First mods and pics of my 92 Aristo :)
- white gs white rims anybody?
- Please Help!
- OEM Lug caps faded
- i want new wheels
- Veilside kit on JZS147 Aristo/GS300
- ECU Diagram?
- Considering trading my SC300 for a GS300, good idea or not??
- "All seals Go"
- removing headliner
- 1st gen GS with wood sterring wheel?
- about turbo manifold all the same
- DYNO updates
- wont start!!!!!
- There's got to be a short or bad ground
- Greedy Profec B II Dimensions?
- HID's
- Hi Guys new looking for some direction...
- Aristo JDM Auto TT speed sensor diff than USDM???
- Sooooooooooo close now!!
- "TRAC" light comes on and off often??? HELP!!!
- Is this 93 gs a good deal?
- HELP! Clear fluid leaking from the front of the car!
- I scored this interesting grill...
- Procedure for timing adjustment
- gte head gasket
- new pics, new look...
- japan vs. U.S.
- Where is the ECU located?
- srs system failing
- k..im hitting Fuel cut like a mother...
- what is the wattage on the stock amp
- How many ladies on the forum R rolling with 1st gens?
- Rear passenger window will not roll from same door
- Tein Cs
- tein cs
- So I just priced the cost of new rear window trim...
- Should I get these RIMS, 18" CHROME
- How Much
- Any 1st Gen GS300 in Nyc?
- What is wattage on stock amp, Want install JL subs and an Amp
- gen2 foglights.....
- having problems with my ac and clock
- ORLANDO MEET...Any 1st Gen's gonna be there?
- Help Please..
- For those that have cloudy headlight covers
- Center Caps
- New To The Forums!!!
- Does anyone else have this problem?
- cluster gauge lighting.....??
- 93 GS300 with 2jzgte and auto TT Tranny question
- good ol' window regulator out
- Main O2S sensor fix? code 21, need help!
- Who's replaced leather seats???
- EREBUNI Rear??
- who has switched to aristo headlights?
- update on my gs....
- !993 GS300 Ignition/starter/battery problem
- Service Manual
- Offset questions
- Swapping VVTI GTE into 1st gen. Need help
- Air purifier filter
- transmission problems
- Sub And Amp
- 93 GS300 Key Programming Instructions
- gs with 18" mesh wheels
- ARISTO Chrome Grille
- Body Kit!
- Opinions: What to do
- number of 1st gens sold in USA
- New car, need a bit of help
- 2JZGTE GS300 Owners....how many besides me?
- lets add some new guys
- Progress on the First Gen GS Turbo
- Progress on Paul's (PNPGS300) Turbo conversion
- Whats the advantage of a Front strut bar
- What do you think of these rims for my gs?
- Eeeeeeek! I Got A Prob!!!
- 1st Gen NA-T???
- found some weird wiring in my fuse box
- where can i get this
- VERY TEMPTED TO DO: 1JZ w/ manual swap
- Opinions should i or should i not?
- HELP!Wheel alignment or steering column problem??
- you GTE guys will like this...
- Where can i get first Gen parts
- New pics with Tanabe DF210 lowered springs
- Window stuck, and making noise
- Clunking when sharp left turn...
- Steering Wheel Shaking After 100,000 Miles???
- Opinions Please
- Source for Brake Pads and Rotors?
- Slammin Q's
- BBK/Parts!
- 2 1st gen's
- How do you replace the timing belt?
- Lexus Tires
- another quickie: how much will u pay for a used supra TT brake conversion?
- new wheels
- Cabin air filter info
- Where to get a "Chilton's" type mechanic's book for my Lex?
