- NEED HELP: Stock media unit SC300
- For anyone with aftermarket subwoofers in their 2nd gen GS!
- AM Radio Recption - Aftermarket HU - RX330
- medialinq plus installed in rx350
- Help! SRS Light After A System Install!
- Dw-tech alarms
- Component speakers
- Anyone with experience with Pioneer TS-SWX251
- Drop in IB/Free air 10 for the sc300
- JUST IS's Audio System
- Pioneer Avic d2
- Anyone know how to make a custom background for Alpine IVA-W505
- Help me on 2/4 Ohms IB
- Questions on Sirius integration to new head unit
- ES300 CD Changer to Aux In
- 95 LS400..another Nakamichi prob...advice please??
- A/V Guru? I'm at a complete loss of power...capacitors or remote line of head unit?
- 04' GS430 and Bluetooth for Pandora
- Adding an AUX input to 95 ES 300
- In-Dash Double-DIN for my 1999 SC400
- Keyless entry locking, but not arming
- huge system just installed know it seems to cut out???
- Lower in-dash DVD screen in LS430 (not Beatsonic)
- Finally new system in ls430
- Vaistech Sl2ic vs ML+
- Shock sensor
- unable to adjust sub woofer level
- Flyaudio 2nd GEN
- Looking for a specific typ of sub
- Need help deciding what subs to get
- NEW SOUND SYSTEM PROBLEMS. Help please!
- How to control bass level?
- hole in subwoofer. Can it be repaired?
- Problem..possible amp issue (?) so I'm looking for help trouble shooting
- Cheap Double Din Setup? Ebay Nav?
- How can I display the radio/XM station on the map?
- Subwoofer Bass not leaving TRUNK
- adding aux, need some help
- 2009 Rx350 Aftermarket Double Din Install Questions
- 99 ls400 changer into 00 rx300
- Pioneer AppRadio
- Need help selecting a subwoofer. Infinite baffle questions.
- '92 SC 400 Power Antenna
- Sub cuts in and out
- What do I need to know b4 installing 2-WAY Alarm/Remote Starter?
- I hate my 07 IS350 tweeters. :[
- Blown Sub
- MP3 Player/charging while in use
- can i?
- 1993 LS400 - No Power to Pioneer Radio
- Speaker works but it doesn't work- NEED HELP!
- opinions on subs
- What should I do? Subwoofer question.
- trouble deciding on P4300 or P3300BT?
- Lexus Remote Security Help
- 99 GS400 Aftermarket HU Reception Problem
- Need Audio Install Help in Tampa
- Lexus IS350, installing sub/amp.. please look inside
- Official Smart start owners w/ push button start Q&A thread
- How do u disconnect the factory amp in a 2001 gs430 and still have the nav work?
- You can fully control portable mp3-players from your lexus audio system!!!
- GPS in a foreign country-PANAMA
- Cost to fix aux in whining?
- Pic of SmartAccess Card?
- Any iPhone navigation apps with video out?
- How do I wire a coaxial speaker to OEM tweeter
- first gen RX powered sub install problems w/ fast-9999
- CD player not working
- amp suggestions
- cs430 amplifier
- 2000 Rx 300 EFI Fuse keeps blowing.
- Sl2vi and audio screen on startup
- Upgrade on 2004 GS300 audio questions
- 2GS oem subwolfer not working like it used to?
- Big 3 on Isx50 question
- JDM Aristo VVTI ECU Pinout
- Do i need to replace my speakers??
- Big 1 instead of big 3
- CD Title and Tracks do not apper
- Question about speaker hook up with nav
- best ipod/iphone kit option for non-navi
- 2002 ES: Want double DIN Nav
- What is the real top battery these days?
- HBO Go App - is there a way to play on Lexus Nav screen, like YouTube will?
- Cluster Panel
- ES350 custom stereo
- Need help with aftermarket audio setup
- Do you get scared..
- 3GS Sound Recommendations
- GS400 Radio quit working?
- Which setup two 12" vs one
- Source effect on sound quality
- Advice on a quote I got
- Audio Installers in SOFLA
- anyone figured this out?
- Need some monitor/headrest help
- Total System upgrade
- NAV display always headed North!
- installing amp and sub to STOCK 1993 ls400
- Neeed help on my 2001 lexus GS300
- Whats the Specifications of Amp in Mark Levinson Premium Sound System for 2nd Gen GS?
- Reverse signal and VSS wire for 1993 LS400
- Trying to install aftermarket amp and sub
- john
- Dedicated Ignition circuit?
- Component speakers. Are they neccessary?
- 5-channel amp recommendations
- Need amp suggestions
- Question on my plans to do a little up to my nakamichi audio system
- Where to buy a Datasystem harness from?
- Backup camera
- Questions on my 03 GS300 aftermarket radio
- Help with installing second battery in the trunk
- rear deck issue with my sc300
- Sub amp delete now I have no radio power ? sc300
- What do you think about my set up?
- Kenwood dnx 9980hd INSTALL?
- Safe to run a battery without tray?
- anybody use bestbuy?
- SC300 Stereo install
- Putting Together New System: Advice Wanted
- Just installed new HU but making noise?
- How XM is hooked up to Navi?
- xm receiver and antennae
- Remote Start Help/Suggestions on 2008 IS350
- Can yoou turn on the back-up camera while going forward
- Alarm install. Cant find parking lights wire?
- Battery drain, 2001 rx300
- Sc400 Naka Head Unit swap HELP!
- 1st Generation SC speaker upgrade
- pillar speaker pods in gs
- 2gs w/Nav System Upgrade
- Poor Radio Reception with AVIC Z120bt
- Sirius Tuner to Head Unit Interface Question
- Pioneer double din Appradio Headunit
- Fusebox Crimp
- SC300 Audio system advices
- Warrantech
- My tablet carputer project
- LS430 2002 upgraded to 2005 Nav region issue?
- Clifford G5 Arm/Disarm
- How to figure out fuse size (amperage)
- LS460 ML Reference Sound & MS-8
- Kicker amp silk-screening anyone?
- Shopping for a Levinson amp 86280-0W250
- IS250 and 12W6V2 with KS500
- Lexus LS430 Subwoofer Upgrade
- Lost power to factory radio
- 2003 sc430 antenna
- 93 SC400. Speakers needed
- Car Keeps Dying After Audio Install!! HELP.
- Programming the NAV
- broken main power window lock switch 95 sc400
- easiest way to access and remove blown factory sub in 08 LS460 with reg back seat?
- Replacing the door speakers on '03 ML. Do I need to use crossovers?
- Speaker Sizes for the ML System
- subwoofer foam surrounding tore
- Car phone for 93 ES300
- Urgent : Help - No Audio
- Stereo advice needed...thanks!
- After-market subs not working. blown fuse?
- How to get More sound into my SC300
- CT200h Audio Replacement Suggestions
- Amp fuse blows when i change sub. Why?
- Installing a Parrot Bluetooth/Music Kit
- Please Help: Playable video file types
- Upgrade to 2002 SC430
- Soundstream
- I need to replace front speakes
- Navigation
- Will disconnecting some of the ML speakers cause a problem?
- audio question
- Subs cuts off with mids up high
- is250 trap door
- converting mp3 to dvd-a???
- Aftermarket HU to stock CD changer?
- SL2IC install question
- After market subs ok to run with stock deck?
- vent tab broken is250
- Lexus Instrument Cluster's They look good
- 2002 SC430 door speakers
- RPM gone crazy
- My custom Audio build thread with pics
- Lexus factory bluetooth - remote turn-on wire?
- Custom dash installed ii din
- Help with ported box size JLW6V2
- 2008 is 250 xm question
- subwoofer problem
- Pictures / Set-Up request. 2GS Free-Air IB SUB in stock rear deck location
- front left speaker
- Upgrade Mark Levinson thru summing external amps
- pc help
- Backup camera question...
- Need Color Codes for Speakers Wiring
- metra kit vs carson kit
- CD Player Not Working (won't recognize CDs in changer)
- Daylight Savings time setting 06 IS 350
- X-Horse Mini-VCI & Windows 7
- ML Amp difference 2004RX330 vs 2004 GS
- Amp Problem/Question
- Rear camera for IS250 and flyaudio multimedia
- AE subwoofer as OEM replacement on 2GS?
- powering up the car at indoor shows
- Audio system expert please advise me
- aftermarket deck, stock amp/speakers 05 IS 300
- 94 SC400 - CD PLAYER STUCK/ Not working.
- Low auxiliary volume.
- Double din install SC400 Nak. Help!
- question about ddin conversion
- What are you guy's thoughts on 2 single boxes?
- Mini - desktop (ITX Micro ATX) in a LS430?
- Alpine VS Kicker? Please help me decide on a replacment sub amp
- Solution for Navigation screen of death
- Bad speaker?
- SC 400 antenna
- Anyone hooked up an ED nine.1 and 2-12W6v2
- 2010 RX350 subwoofer installation help
- Need Help: 07 IS250 VSS wire location???
- What's a Oldschool KICKER C12a STILLWATER worth?
- Gen 1 HDD update for 1999 Lexus LS 400
- Sub 2001 is 300
- Audio cutting in and out
- 2006 IS350 (nonMl, nonNav) complete audio system upgrade, with pictures
- 99 GS4 no sound NAK sys Help PLZ
- Pioneer AVIC-U220 - input?
- Looking to put in a sub in the 3gs gs300
- Potential windows up hack for keyfob
- IPOD Connection for 2004 LS430
- Stock Head Unit 95 SC400
- NAVTOOL, Backup camera
- Is my factory amp dying slowly?
- Main Amp question
- Will these fit in my GS?
- 98+ ECU replacement
- sc400 weak speakers on tape?
- bluetooth private conversation while driving
- installing subs and head unit in 98 gs400..need help!
- 1996 sc400 clock
- 1997 Lexus es300 audio !help!
- So im putting my 13.5" w7 in my SC....
- CD Changer Jammed.
- What is this : INGENIX AVN ?? car pc?
- Custom system Build. PICTURES!!!!
- Mark Levinson
- Question for the Audio Heads
- 98 GS400 Nakamichi issues
- Too much bass that causes rattling?
- Radio removal
- Sirius Problem
- Installed new speakers, now car wont start
