View Full Version : Maintenance
- Lexus dealer service history terms?
- Offering Lexus service maintenance.
- carpet removal help
- Looking for skilled, honest suspension work Austin, Texas
- 2000 LX470 A/C Not Working - DTC 19, 37, 47
- Rear universal on 2004 RX 330
- Proper Torquing Techniques (as Suggested by Forum Members)
- Indie in richmond, va
- Just received my VxDiag VCX Nano
- Clunking Sound Problem
- runs good in cold weather stalls when hot
- SC430 no throttle response p2102
- Royal Purple in a 2015 IS 250
- Repairing Cracked Plastic Tanks
- Air Outlet Servomotor (mode) 2007 Lexus GS350 PLEASE HELP!!!
- Lower Ball Joints
- Fuse
- used lexus vehicle service agreement
- independent mechanic NYC
- 2002 LX470 Noise
- Premium vs 87 octane
- Does it need to change the cam belt?
- That Darned Shift Solenoid E Malfunction (P0770)!
- 2012 Lexus RX 350 rear deck lid works intermittently
- Flash codes,07 IS250
- Multiple lights on after wheel hub replace
- Need a louder horn for RX350 2009
- Oil doesn’t get dirty
- Basic Synthetic Oil Change includes Tire Balancing?
- price 60000 mile checkup 1999 es 300
- Car will not start.
- Key not detected.
- Original and oem parts
- code b1421 + b1212
- Has anyone recently changed their coolant/antifreeze? Need help
- Timing belt cam issue. Need help
- Lower control arm replacement - $2300?
- Anyone have experience with any service shops in Memphis, TN?
- Can Lexus Certify a Damaged Car
- Removing the cats on a 1999 RX300
- spark plugs
- an air filter is an air filter. right?
- RX330 Cluster fuel gauge light or bulb not working
- Gumout Multi-system tune-up
- HELP!!! Navigation Data Problem
- 2003 Lexus IS300 Front Wheel Noise
- 220d heater core problems
- Hvac
- Which size compressor should I get?
- lug nuts
- Head light
- CPO Rust?
- New Michelin Pilot Super Sport 4S for 2016 IS200T Fsport
- Interior protection
- Do oil additives/treatment/stabilizers really work?
- Rear brake rotors pitted
- NJ Lexus Mechanic Recommendation???
- Professional tuning shops in the Cincinnati area?
- Door panel replacement
- Check engine and battery light on in ON mode
- lexus lx450 1995
- Replacing starter on 2000 GS400
- Anyone seen this?
- 2006 Lexus GS300 trunk won't open
- Lexus RX 350 is skipping and found to have low compression.
- 2016 IS200T Oil change?
- How to tell if brake pads are worn?
- Toyota 90915-YZZG1 Oil Filter?
- I have a 2015 RX350..The power steering gets progressively more resistant to turning.
- replace battery
- Undercoating voiding warranty?
- Fluttering noise
- HELP- AC Issues in 2008 LX570
- 2002 ES300 shift into Drive, displays 4
- Just installed new pads and rotors on 07 LS460, now all warning lights on
- LS460 Steering
- 1UZ Wont start after being shut-off at operating temperature
- Transmission issues please help, no overdrive and skips 2nd gear
- Had low/0 oil, now oil is burnt and thick through out the engine
- 2013 LX 570 with USB / AUX door on console won't stay closed
- 2013 LX 570 with USB / AUX door on consolo wont stay closed
- Should I buy an extended warranty?
- 2004 RX330 Engine Light Codes
- 3D Printer (Metal, Plastic)
- NuLux leather
- 1998 SC Coupe 300 Evaporator Cleaning
- Replacing the Spark Plugs in your Lexus IS
- obd2 2jzge into a obd1 sc400 HELP
- '92 sc300 How important is this piece I broke off my starter
- 1997 sc300 front bumper?
- service pro full synthetic engine oil
- GS300 Runs bad after timing belt replace
- My 2000 es 300 leans to the left
- Need mechanic in NorCal
- Accidentally ran car with no engine coolant - now not starting
- will not start
- Props to Alchemist
- Prepaid maintenance CPO CAR Is it transferable
- diagnostic testing
- Bounce in the rear of 2004 LX 470
- Still have check engine light problems
- "Used" Parts Can Be a Bargain
- Lound noise when I accelerate
- Ac recharge question
- Exhaust System
- Car Service Center in Dubai
- WTB Toyota/Lexus Master Tech in NJ
- Help needed 93 LS 400 non responsive when I push the gas paddle
- Headlights CANBUS IDs
- Rs200 transmission
- B1421 solar sensor circuit (passenger side)
- Torquing Suspension Parts Under Load?
- 07 IS Headlight Assembly
- Lexus GS 350 Power steering light comes on while driving
- Maintenance/Service on '04 LS 430
- Possible to obtain R12 in Socal?
- ECM Wire Resistance Transmission.
- Toyota Lexus SST Transmission Line Pressure Test Tool Identification Please
- Used ECU Swapping and Programming to immobilizer
- Power steering symbol, Car wont move
- Transmission Line Pressure Checking Advice Please A960E A7601 A760E AB60E
- Urgent! How to remove rx400h rear bumper?
- Several Shock (Strut) Questions
- Transmission Wire Valve Body Harness Checking IS250 Shift Problems.
- DTC question
- strange sound
- Lexus 1uzfe conversion problems
- Strange sound from engine compartment
- New Recall for many Lexus models
- Spark plugs
- VVTi Replacement Sticker Shock
- Lexus offical email adress for claims
- runs for 5 minutes then shuts off.
- Die hard battery experience
- Whining sound coming from engine bay.
- Lexus 430 vs Lexus LS 460?
- 1998 Lexus ls400
- Low Oil Pressure
- Oil change question
- Lexus third least expensive to maintain
- Why does my gs300 die
- Good place to take my car in Dallas area
- Lexus GS350 2007 blower motor fan making loud noise
- BG Oil Additive added?
- Crank No Start...NEED HELP/THOUGHTS/SUGGESTIONS
- Misfire on ES 350
- GX460 Scuff Plates
- '07 RX350 throwing codes, please help
- 2009 IS250 clicking sound?
- How do i reset my ecm
- air filter problem in SC430
- Ultimate oil undercoating guide (DIY Waxoyl)
- 95 es300 no start condition
- Replacing MPH to KPH speedometer lexus GS400 2001
- Hybrid regenerative braking and brake pad life
- Hybrid battery charging, conditioning, repairing, etc....
- Knock sensor change out gone bad!
- 1jz non vvti misfire
- Start circuit issues
- '04 IS300 OBDII Code 980 -- Cause?
- sc400 92 code 13
- Help please with these codes!!
- GS300 Timing Belt
- Orange County CA
- P0175 code, hitting a wall!!!
- Water repellant windshield?
- Battery/Charging Diagnosis Question
- Brakes locking up
- Alternator died
- NGK vs DENSO PLUGS?
- When using Nu Finish, what to do with Plastic Protected Hood and Fenders
- squeaky clutch pedal
- P0430 Catalyst System Efficiency Below Threshold Bank 2
- Multiple Malfunctions all at once
- '04 IS300 P0172 code, which O2 sensor?
- Oil filter caused some headache, looking for advice
- Idling car for an hour a day
- OBDII Scanner Experience??
- GS450h 2006 48k
- vsc check burning after replacing wheel hub.
- Cabin and Intake Filter Brand
- Steering wheel hard to turn right
- CV Axle IS250
- What's the best way to clean metal shavings out of the intercooler
- '04 IS300 MAF Sensor code
- AAA: Not All Gasoline Created Equal
- 06 GS 300 Starter
- Oils: conventional vs synthetic video
- Oil sludge, timing chain noise
- dipstick help for 1jz front sump
- 4GSF Sport - 5k service oil change
- My 03 is300 having problems with throttle
- GS350 Display Screen Trouble
- Cable for Techstream
- Vehicle, diff and tyre specs?
- 93 SC400 TB cleaning woes/tutorial
- Toyota Techstream OBD3
- Where to get ISF workshop manual
- Advice Needed Air Suspension converted to shocks on 06 LX470
- 2001 ES300 PCV replace
- Anyone selling sc400 AT trans
- Chassis Codes
- 1997 ES300 Windshield washer pump
- Anywhere for Canadian Lexus owners to look up service history?
- Cooling system problem/s - 1994 GS300
- rear brakes wont disengage with new pads
- 2003 ES eating struts
- My IS 250 is dead, battery dead, can't open car
- P1656 lexus rx300
- New Car Buy - Pre-purchase Maintenance
- PLS HELP Diagnosing noise
- Help. Coolant leaking like a faucet on 90 LS400
- 06 IS350 transmission pan leak
- How Often Drain and Refill Transmission?
- transitioning from another brand to Lexus Master tech?
- Repairing Starfire Pearl
- Driveabilty problem! Help
- Analysis needed
- AA80E questions
- 90 LS 400 need help identyfyigproblem
- Code po174
- GS300 - wiring harness replacement?
- Air Con motor always on problem
- Sealing Transmission Bottom Pan
- Lexus isf 2011
- Help with 1Uzfe Non VVT dash wiring
- NEED HELP!!!!!! Recent engine rebuild !!!!
- stripped wheel stud
- How-To Tuesday: Getting Your Stuck Shifter Into Gear
- RX 300, 2000 model gear box
- Where is the Crankshaft Sensor 00 GS400?
- Car key fix?
- installing a high beam assist mirror rx450
- Is this rust on the underbody?
- 2000 es300
- Fixed steering wheel vibration that resulted after tire rotation/tire change
- Both Doors are Broke -No Way In...HELP
- obd scanner with blue tooth? any GOOD ones?
- Blew alternator fuse in fuse block - how to repair/replace
- looking for a good independent shop in the jersey area
- How-To Tuesday: Maximizing Your Mileage
- Anyone know (2013) ES350 Front and Rear OEM Brake Part numbers
- TPMS Recode
- GS450H Traction battery
- Need tire gurus
- That Top Bolt in the Black Cover ATF Fill Hole
- Unkown problem on my Lexus IS200 SE
- Need help from the pros
- What is this called?
