View Full Version : Maintenance
- Ground wire on passenger side engine unconnected
- Car won't stay running (2010 lexus gs350 awd)
- Any Lexus Techs or Air Conditioning Specialists that can help?
- Snap on scan damaging Occupant Module Lexus
- Oil leak help!
- 2003 es300. Are cam seals normally replaced with timing belt and water pump?
- 2007 RX350 code P0017
- water pump, proof of replacement?
- Lexus 2007 GX470 engine/fender mud/splash panels
- license plate screw hole blowout
- Paint, 2007 GX470
- Mini floor jack? just for tire rotation
- sun roof track
- 2jz-GE oil Viscosity/Brand/Capacity
- Houston Lexus shop or mechanic recommendation
- Can this tool do any damage to the brake system?
- Transmission problem
- Small pieces of broken plastic in my oil pan
- Preemptive
- Just ordered my first impact wrench. Overkill? Decent Price?
- 128000 miles and no transmission oil change
- 2014 es350 transmission swap
- Headlight Condensation
- Part hanging from rear of car
- 2006 IS250 Brake/starting issue
- LS430 rear sway upgrade
- Lexus Enform Nav Screen ReCycling/Reboot
- Cabin Air Filter for 1992 ES300
- Long Term Costs after 60k 4GS350 vs LS460
- Amazing oil levels on dipstick
- What is this part? Please help
- Test Strips For Coolant and Brakes
- Front Suspension Squeak
- Acc
- Replacing RCF brake pads.
- NX200t 2015 overheated after Radiator Flush
- Brake Actuator rebuild C1241 c1391 codes ABS VSC warning lights
- Denso long life plugs insulator printing variance?
- Sunday 5pm. No where to get some Toyota WS ATF fluid, right?
- Rear view mirror fell off windshield and took a chunk of glass with it
- Go-to site for OE/OEM parts
- How to read service records?
- Leak From Rack and Pinion
- Parking Sensors
- OEM bearings - control arm, idler, tensioner
- Finally Registered...
- Car battery dead after 7 days
- Pin Out diagram for ecu 175200 -3184 12V A/T
- Best Dealer for SERVICE in TAMPA, Florida?
- Valve covers different colors???
- VSC and OFF track and engine light
- Engine Shutoff at Idle
- Crankshaft oil seal
- Trac Off Light-again
- Certified Lexus Mechanics
- 07 lexus IS WONT STAY RUNNING STARTS UP THEN CUTS OFF
- Lexus 5k MI & 10k MI maintenance
- Hose problem
- Stiff throttle after cleaning
- Code P3105 troubleshooting -Battery ECU Communication Circuit Malfunction
- Can I find a solution to this problem?
- Help plz-oil loss
- WS Transmission Fluid Exchange recommendations USA vs Japan
- Lexus Online Parts Illustrations
- RX400H 44k miles hybrid battery question
- 1996 es300 - body panel ID help needed
- 91 ls400
- Recommended OCI for low mileage cars
- Lexus IS350 overheating
- ThinkCar & ThinkDiag
- 3 Pack Valvoline Advanced Full Synthetic SAE 0W20 5 quart $33.39
- Intermittent power issue
- Need help 2000 RX300 timing belt ?
- Code 125 for inspection
- 2013 Lexus 350 won't start after maintenance light reset?
- Tire rotation
- Lexus vs Toyota Brake Fluid Change Interval
- 60K Mile Transmission Service
- Brake Maintenance
- Keeping Carbon Build-Up in Check - Fuel System Cleaner
- Battery Question
- Should You Spring for a Lexus Extended Warranty?
- 2014 lx 570
- Headrest question
- Battery
- Negative Longterm Fuel Trims!? 1MZFE
- Cluster wont turn on. And car wont turn over.
- Toyota and Lexus have different WS fluid change intervals for the same transmission.
- P2577 obdii code
- 2018 IS300 cabin air filter
- Help O2 sensor wires broken
- RX 330 steering issue
- "Check Power Steering System" (2013 GS350 F Sport RWD)
- Starter 2007 GS 350
- 2002 IS300 diff locked up on me
- ATF plug alternative?
- ATF in 1992 soarer 2.5 TT
- Otside Mirror Broken Stop
- broken electrical connector locking tab solution
- OEM Pads
- 2011 IS250C convertible repair
- Steering wheel horn stopped working
- 2007 ls460 - AFS light
- My Rx 330 Dashboard are cracking. Pls response help
- I cant figure out whats wrong with my Lexus please help
- Hybrid system ?
- A650E transmission is not the same for all models
- 2GR-FSE - engine whistle, antifreeze "dip" at head gasket, rare cold start misfires
- Cracked Subframe
- Cross referencing toyota bolt
- RX350 under-hood air baffles
- LS 460 Engine power issue
- 2010 is 250c p0420 problem
- I got a Flat Tire in a Loaner from the Dealer - Can I Just Replace The Tire Myself?
- High Pitch Noise and Tire Gauge Measurer
- Car will not start after "fixing" issue
- Brake pads change on 2014 IS (Gen3) Base
- Engine oil low light on
- AC & heat dual zone problems
- Tgmo 0w16 two different lable?
- 2007 IS250 AWD Front Strut Bottom Bolt Torque
- Help needed finding bulb online
- Are melting dashboards ever okay?
- 2014 Lexus LX 570 | Unidentifiable Engine Noise
- 2001 IS300 Front Suspension issues Im Lost!
- Rear bumper part replacement
- SC400 performance gains. tips/tricks.
- 2004 IS300 speed issue
- Do you tip dealership baristas?
- Car having problems signals lights not working fans and charging system not working
- First DIY oil change
- Parts from Dubai
- High Mile Vehicle Oil Changes ?
- Reaching End of Maintenance Manual
- Cpo maintenance schedule?
- Location of toyota service center in los angeles
- Probably over thinking this but....
- No Crank No start when car is hot
- 94-LS400-Tranny-hiccups
- 2013 Door Lock Actuator - Help
- Please help car has no electrical power
- Car has no electrical power... is it alternator or electrical issue
- Warranty on Lexus parts/labor?
- 2jz rough idle when warm
- Monthly Budget for long term maintenance ES300h
- A lot of codes on new car!
- What Fluids in your ATF and Power Steering?
- North Dallas/Dallas TIS Lexus Diagnostic Customised Settings Health Check SPECIAL
- Buying an used CT200h, Lexus prepaid service
- Looking for A Repair Shop in Los Angeles
- Good Independent shop vs Lexus dealership for major repair
- Recommended Repair Shops for 60K Service (In Orange County)
- Car Dies While in Motion
- Fixing Dented Leather?
- Labor rates at Lexus dealer
- seeking lexus repair help indianapolis area
- clucking noise
- RX 350 starts, shuts off, power steering indicator
- Replaced fusible link, now full on error message
- Body reconditioning in service history
- Dealer or independent shop for general service for 2006 IS 250?
- 06 RX330 running hot
- Best dealer for buying an extended warranty?
- Growling water pump pulley/bearing? 2008 ES 350
- ES will not shift into 'drive'
- mystery box 18 is back @detailers domain
- Troubleshoot Help - Starting System
- Lexus 2003 lx470
- How do I remove the review mirror from 2006 GS 300.
- Indie Shop In San Diego
- 22 mm crank bolt recommendations
- Brake noise
- Diagnostic software
- Newbe in need of some help climate not working
- Can somone please help me identify this part?
- Stupid ? Re windshield wiper inserts
- Lexus is220/250 washer pump
- Do I need a left or right variable timing Solenoid for Bank 2?
- L/Certified but carfax shows accident damage?
- 5000mi oil changes even with synthetic?
- Not sure what's wrong with my Lexus...
- 2007 IS350 ABS, VSC off, P/S, and BRAKE lights on
- Ls400 oil leak
- 45k Service IS250
- Electrical system question
- Several maintenance questions LS430 ?
- 2003 RX300 Rear Axle Replacement
- What happens if you removed the timing belt before setting cylinder to compression?
- 01 is300 misfire, throttle bogging, and random shutdowns
- Random question - best way to fix exterior rubber trim?
- Door Automatically locks with Key Fob inside! HELP!
- Need help on what is wrong with my 1995 ls400
- 2014 IS250 pulling even after alignment
- oil service required
- Need maintenance advice on 2008 LS460 with 45k Miles
- Service maintenance
- clicking sound, transfer case coupler?
- burned exhaust valve poor man's fix?
- alignment problems
- Motor mounts replaced
- Lexus 2005-2013 General Information and Maintenance Schedule
- New Certified 2016 Lexus GX 460 Owner- Tires
- PrePaid Service Maintenance
- Rear suspension work on a 1992 LS400
- Dealer won't provide service records?
- Big Red Oil Products Question
- Free Store Credit to get rx350 Serviced at Stokes in Santa Monica, if anyone wants it
- Back Window Wont Go Down
- How many have changed the oil viscosity in rx 350 from 0-20 to something else
- L/Certified Vehicle service agreement
- Please Remind Me......
- Seat heater/blower not working
- installing grease zerks
- Spark plug analysis
- 99" LS400 master window switch problem
- uh oh....or....ok?
- Underbody water wash for LS 460 L
- independent service
- Maintance on 2015 lexus gs350
- Tire plugging tips?
- ODB2 reader for 3rd Gen GS450h?
- DIY: How to Jack Up Your Car
- Cel, vsc, p0354
- Check VSC
- lexus front seat headrest measurements needed
- 2002 Lexus IS300 timing belt and water pump
- Paint info needed.
- type of engine air filter
- Front strut and ball joint replacement
- online manual recommendation
- DIY: Understanding Your Lexus Warning Lights
- IS250 Parking sensor problem
- Reco needed - independent mechanic near Washington, DC
- brake components OEM or high quality aftermarket
- Lexus Hood Ornament
- yaw sensor location 2000 lx 470
- VSC light as described below
- error code c1241
- Replacement keys reprogrammed
- Purchasing is300 2001 with a 300k on it.
- Help! 2005 ES330. Loose wire, where does it go??
- US Vet
- New owner oil change
- es 350 vvti cam gear rattle diagnostics
- shin etsu silicone grease
- 1989 Celsior 4L v8. Same as Lexus?
- Need help w/EGR system VSV part #
- Anyone need a good mechanic?? SoCal
- p0171 just will not go away. whats wrong? i can't see it.
