PDA
View Full Version : Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25
  1. Changing spark plugs- how often?
  2. LX 470 60,000 mile service $1,500?
  3. power seat problems???
  4. Optima or not
  5. repair manuals
  6. Toyota OEM oil filter=made in Thailand?
  7. Resetting ECU
  8. Steering Wheels
  9. Frustrated with Service
  10. Cold Weather Creaking 1993 LS400
  11. Trac light, emergercy brake light and seat heaters - help!
  12. Oil Filter
  13. Rallye Lexus Service Department
  14. Power Steering Rebuild?
  15. Need a new Air Intake Connector Hose for es3
  16. Replacement Fluids
  17. how much to flush tranny and cooling system?
  18. Gasoline
  19. 90K service on SC300. Whats included?
  20. Leaking Oil Pan
  21. Are C.P.O. Warranties Transferable?
  22. Fuel delivery issues
  23. How much did vandalism cost you?
  24. belt noise...
  25. 5000 Mile Oil Changes on '04
  26. sluggish at idle and >40 mph
  27. power steering pump making noise :(
  28. redline MT-90 oil
  29. Fuel Filter Change
  30. Engine stalling a bit...
  31. Do you need a name brand OIL FILTER if usiing Synthetic Oil at intervals?
  32. Rattling sound on rough roads
  33. how to do tranny flush.
  34. Maintenance
  35. Ls 400 loss of power
  36. Lexus Service Prices
  37. How Much You Spend On Maintenance?
  38. Need non-dealer mechanic in NYC area
  39. New ES 330 break in
  40. PCV Valve
  41. Trans Fluid TII or TIV
  42. Winshield washer bottle
  43. "Warbling" sound after engine turned off (ES)
  44. Engine Code 71
  45. Cleaned Throttle Body For The First Time
  46. Window - What the hell ?
  47. Any alternator same as SC 400's?
  48. Starting/Stalling problem
  49. radiator repair
  50. suspension link bushing
  51. ES300 brake pad service limits
  52. Pyroil PS Fluid?
  53. help on 30000 mile service
  54. oil filter replacement?
  55. bettery terminals replacement question
  56. Is 30K Check-up worth it?
  57. Stumbles at idle after highway runs?
  58. weather stripping issues.
  59. how to make engine smoother
  60. Flushing coolant question
  61. oil filter 90915-20004 discontinued?
  62. Oil Change
  63. help with rear brake
  64. Stock R-134a AC for SC300 - Which Years?
  65. Check Engine Light
  66. 1992 ES-where does air enter intake?
  67. Rear Main Seal Replacement - How Much $$$?
  68. Exhaust squeak on 02 IS
  69. AC light blinking in 2002 RX ???
  70. car shakes at 60-65mph
  71. Question on Strutt replacement
  72. Starter Replacement
  73. Best battery
  74. Worst that can happen if timing belt breaks on non-interference engine?
  75. Battery protector gel/spray/washer - do you use it?
  76. DEAD battery Additive
  77. Car stalled/just turned off at the stop light
  78. SC 300 Power antenna pops off.
  79. Front wheel bearing help
  80. Need Help. Car won't start.
  81. Rear main seal leaking...
  82. Motor/tranny mount questions
  83. Mobile 1 oil change - great write up
  84. Mysterious dashboard light
  85. Oil change question
  86. Fixing the wind noise on my RX300
  87. to clean the scratch
  88. warranty of '99 lx?
  89. AC questions.. and What the heck is this?
  90. switched over to synthetic oil
  91. warranty question
  92. car needs some TLC
  93. what kind of oil at the dealer?
  94. car warm-up in winter?
  95. Tranny Fluid Flush Quote
  96. Fog Lights missing
  97. How Much For 90K Service?
  98. Changing the oil
  99. Power Steering replaced still gets noise..HELP!
  100. Question on coolant
  101. Tranmission fluid
  102. Oil Filters Revisited - Depth type vs. Surface Type
  103. Engine stumbles, and then shuts off!!
  104. 99' Lexus ES300... Suspension/steering problem : ((
  105. My 2000 Lexus LX470 rides like a tank. WTF
  106. Balance on the Car
  107. 60K Service, U.S.$800.00 :-)
  108. Tuneddd Up
  109. air-fuel ratio lean code on OBD-1 diagnostic
  110. Any Maintenance Issues On 2000 ES300?
  111. Timing Belt DIY?
  112. Check Engine Light
  113. Bulb no.?
  114. Overdrive Signal
  115. Instrument Panel
  116. GS3/400 Main. Issues?
  117. leaking radiator
  118. Powersteering and Rack and pinion issues?
  119. SC400 Ground wire and grounding strap locations
  120. Test
  121. Best Source For O2 Sensors
  122. Radiator Problem
  123. Passenger seat heater not working
  124. Very Jerky Shift
  125. I have searched but can't find alternator specs
  126. Autobacs
  127. high rpms at low speeds
  128. SC400 Cap/Rotor change procedure
  129. Sparkplug wires
  130. 1UZ-FE V8 GS400 LS400 heater water valve? (Coolant change procedure)
  131. Car starting to shake. Need tune-up?
  132. oil change
  133. Tranny Flush
  134. thanks
  135. hey everybody from new member! q about a/c compressor
  136. Best rust treatment before wint. sets in
  137. wiper blades?
  138. Bushings
  139. Cost: Brakes
  140. reset oil after maintaince
  141. Wheel Bearing Replacement
  142. what do they do for 30k miles service...GS 430
  143. how much for 45k maintence at dealer?
  144. ATF Fluid
  145. ATF Brand
  146. 97 LS400 tune-up Parts list
  147. Interesting "Long Life Coolant" tidbit.
  148. 40k/ 45k Maintenance...is there anything needed to be done?
  149. Accessory / Alternator / Power Steering belt change?
  150. Transmission problems with GS'?
  151. Best Battery, Options
  152. Problem with my power steering....
  153. Re-manufatured alternator
  154. Heated seat problem
  155. Window Problem: Opens By Itself?!
  156. SC 300 A.M. hissing sound on startup
  157. window "buzz"
  158. ABS, TRAC and battery lights are coming on....
  159. 40mph bad throttle surge...
  160. Price of Wheel Alignment at Lexus?
  161. Different types of Repair Manuals?
  162. pass side wood trim loose
  163. How much for a oil change at lexus
  164. No one has found the answer yet (cold start and pedal problem)
  165. Brake rotors and pads...?
  166. Rear main seal in phoenix, az
  167. Which Rear Differential Fluid for GS400?
  168. SC Specific Maintence Question..Could not find any answers in Maintence forum..
  169. Timing Belt?
  170. did my battery die?
  171. ES 300 Timing Belt Change
  172. hard to start my sc400
  173. Sc300 coolant drain plug
  174. Can interior wood be retrofitted?
  175. Rear vents very weak
  176. Trouble Code P0132 O2 Sensor voltage too high.
  177. AC Light Flashing
  178. Required Maint.
  179. weird problem with my GS
  180. Oil on MAF
  181. Maintenance minimum vs recommended
  182. 155,000 Miles and Oil build-up
  183. Help, where are the spark plugs loacted?
  184. No Synthetic Oil For Car Over 75K ?????
  185. STP - Gas Treatments
  186. Intermittent A/C cooling on R12 1993 SC300
  187. Replacing light bulbs in cluster
  188. Clicking in engine of 2000 lx470 with 53000 miles????
  189. brake problem with LS400. need help.
  190. stupid battery problems
  191. change air filter on gs300
  192. Powersteering problem
  193. Changing Transmission Fluid
  194. 50K oil change for an RX300, what should I expect?
  195. OEM Maintenance Parts
  196. HVAC filter
  197. Change Spark Plugs
  198. Those who have repaired their steering pretensioner
  199. Do we have to get our GS4 oil changed at the Dealership? Or can we go anywhere
  200. Dashboard brake light goes on - 2002 GS300
  201. smokey haze in tint
  202. Timing belts
  203. automatic shift knob
  204. I would like opinions on air filters and such.
  205. Maintenance parts and other questions
  206. what kind of service is done at 100k miles
  207. no gauge lights when car is on
  208. Switching from regular oil to synthetic Help?
  209. Ignition problem during cold start.
  210. New Heater Core
  211. Bad cv boot at 90K?
  212. bezel removal on 99 GS
  213. Engine miss at high speed
  214. stuck and frustrated - not the TPS!
  215. RPM is not workin
  216. Rear suspension clunking
  217. wHEN LEXUS WARRANTY IS 70000 MILES POWERTRAIN WHAT DOES IT COVER & NOT COVER?
  218. 75K mile service...what is done?
  219. Climate control only cold at "max cold"
  220. Please HELP
  221. 60K Service
  222. Fan belt
  223. moonroof closes then opens???
  224. SC400 hesitates from a stop
  225. Moonroof
  226. Need Drive-shaft LSD Help
  227. radiator hose replacement 90 LS
  228. Helpful tip for removing oil filter on sc300
  229. Change of Thermostat
  230. Rear Pads
  231. A/C help needed (yeah, I know there's a gazillion posts)
  232. Strut Mounts, Boots, Insulators
  233. Anyone Used the Oil Extractor?
  234. LX 470 Timing belt failure???
  235. help... pass side rear window
  236. Floor jack recco's?
  237. Oil change PROBLE"M........ HELP !?!?!?!!?!
  238. Help with intake removal to change plugs and distributor
  239. How much is it to get the car inspected at the local Lexus Dealership?
  240. Can anybody get me a service report for this jt6ht00w4y0109028
  241. Differential fluid plug removal
  242. Oil Filter to use?
  243. Oxygen Sensors '95 LS
  244. Need a toyota part number for an air filter.....
  245. Code 29 on a 92 sc400
  246. Transmission Flush/Change?
  247. Fuse Box Question
  248. Pwr antenna is broken
  249. Will 60K svc at non Dealer void /CPO Warranty
  250. GS400 overheating solved
