View Full Version : Maintenance
- Where is the oil leak coming from?
- sc400 speed delimiting
- BG Fuel System Induction Service..what is it?
- New Canister Oil Filter Element Kit Part Numbers
- '96 LS400 - testing oxygen sensors?
- 12 or 16 Quarts for SC400 Tranny Flush?
- Need help on finding Lexus Brand Oxygen Sensor...
- Rear rotating clunk
- What do people use for rubber protection?
- 5k Maint Question?
- 1993 Lexus es300 compatible with Camry parts?
- Price/Reality check on SC400 caps/rotors
- Help, alarm reset.........
- Wires, plugs, cap and rotor. Tranny fluid and rear diff fluid
- Mobil 1 Synthentic Oil
- Black Pearl Emblem Package Recommendations...
- AWD Smog Check 2 - Cali - AWD Dyno?
- Window regulator or switch?
- Power Steering Pump + Service kit
- Car does not start after rain.
- E-brake light comes on
- One for Phoenix, Tammy, Others...
- Bar's Leaks Products Any Good?
- Oil Filters – New Look Inside!
- Will the battery die?
- Transmission suggestions
- Implications of driving with no power steering
- Road side assistance
- What sort of maintenance schedule should I keep?
- Wiper replacement
- strut change
- Temp or Permanent Type IV in stearing pump
- Help me choose an oil
- good price on a oil filter.
- Is It Worth Adding This To You IS?........
- what's your take on this??
- Car whistling
- Simple advise on preventative maintenance!
- Lexus recommended service site
- fuel filter question?
- Just got tranny flush and.....
- CEL plug for SC300??
- Any recommended Lexus mechanics in the Indianapolis area?
- Anyone with SC3 maint. CD's?
- LS400 cooling fans not engaging...
- Engine Block Coolant Draincock
- When should I get the oil changed
- Paint Fading on Center Caps, need help.
- Flush Vs. Drain And Fill
- Your advise on what is correct?
- SC 300 maintence CD's.
- Lifetime Alignment Service
- shortcircuit around the power steering fluid reservoir
- what toyota years and models will substitute for a 90 ES250...
- SC400 timing belt parts and price list - best place to buy?
- overheating problems when car is driven hard
- What is the correct ballpark range for R134 recharge?
- Will theAir Intake manifold gasket work again?
- My sc400 has 175k ... change tranny fluid?
- Oils Filters??? What Brand do you use?
- tune ups/major services
- wheel bearing
- Change oil before Lexus complimentary 5K mile service?
- What Air Compressor *NOT* to buy
- Syntec Blend for IS250
- Is the 4.3 liter V8 engine a non-interference engine?
- i need new struts....labor
- gs 400 how to Bleed Braks
- dampness
- 2jz swap
- Any recommended Lexus mechanics in South Denver?
- Lubing front end
- travelling for a week
- O2 sensor wire melted.. replace and now running rough
- a/c blower
- Simple question for the car Guru's
- Accessory (serpetine) belt change
- Exhaust issue on ES
- Picture of LS430 drain plug
- Certified cars Maintance question
- Maintenance question
- AFS light on 05 LS Keeps turning on and off rapidly...
- Need to change 2005 Lexus LS 430 Brakes
- SC300 Cam and Crank pulley remover tips?
- Car won't start...98GS 300. NEED HELP!
- alignment issues
- Saving $$$ on maintance cost at dealer
- '96 LS400, rear O2s... where do they plug in?
- Mobil1 ATF as power steering fluid??
- '92 SC300 Emission test fail
- my "check battery" light flashes on then off intermittently
- oxygen sensor LX 470 (2002)
- How to flush radiatorHi
- 100k mile service!!!
- Timing gear removal; tips to loosen?
- PCV Valve questions
- Rear Main Seal 03 Is300
- Oil & Fluids Question
- Radiator Coolant problems on ES 300?
- Dealership Overfilled Engine Oil
- Optima Red or Yellow Top?
- Scangauge II
- Transmission: Vent from tranny fluid pan
- Air Conditioning Problem - 1996 SC300
- O2 sensor in Exhaust malfunction - what are the detrimental effects of not replacing.
- Service History
- Windshield replacement
- Power trunk quit..now fixed!!
- Jiffy Lube or Not????
- electrical issue
- ES300 P/S goes "boing"!!
- srt intake
- Why are my ES300 Cabin filters missing???
- Has anyone ever replaced ... (engine fan oil and power steering oil)
- Confirmation on tranny/differential drain on 97 ES 300
- How important is installing the A/C Filter?
- Maintenence Questions.......
- LS400 stalling problem solved!
- P/S pump for ES300 (2nd Gen.)
- recommended gas for ES250
- losing coolant
- 60k sevice..
- rx300 cel help
- car races up and down when ac on
- IS300 Windshild washer problems
- timing belt change
- Expert needed: A/C and Fuel economy
- Looking for some HELP!
- Cold AC plz
- tourque master spark plugs
- question about window regulator motor
- 2003 Gx 470
- McGard Wheel Lock Key??
- My AC always changes to outside air
- need a mechanic in brooklyn
- What to do if Tranny is leaking from Bellhousing?
- Check Engine Light & Track Off light on
- wont start - sc400 1992 w/ 191K miles
- What is this part called? Anyone ever had this problem?
- Weird! Trunk shocks didn't work now it does?
- Can I keep the car on jackstands for a couple of days?
- Monthly Maintanance on a SC400
- Aspiring to become a Lexus technician; any advice?
- ticking in back motor on drivers side
- LS 400 Engine Stalling
- 2006 2GR-FE Engine Oil/Filter Change How-To
- Electric Impact Wrench
- Went to Midas for them to look at my SC...
- Why is it so hot in my car?
- How do I contact a Lexus "Trainer"?
- Fuel Pump ECU which PIC?
- Emissions Test in Virginia
- Scanner needed
- lowered car specific maintenance
- Would someone verify a Toyota part# for an A/C drier?or show me where to look?
- Winsheild Wiper Adjustment
- what a crappy night.
- All About Oil, Additives, and Oil Filters Superthread
- Lexus 300 SC Speedometer problem
- What kind of battery for my Key??
- Just dropped transmission oil pan
- How to fix a stripped bolt?
- Becareful were you bring your Lexus
- Help Needed Florida Peeps - A/C Question
- Warm start problem refuses to be solved
- Lexus 90k Service for 99 GS 300
- Looking for good mechanic in Lancaster PA area
- Power Steering Fluid Changing Alternatives
- spark plug installation, car won't turn on now.
- cabin filter
- Head gasket replacement
- abusing the ebrake
- timing belt just curious have some ??
- Belt maintenance diagram
- Engine overheating
- Oil change flap
- Any Castrol Syntec experts-german vs USA stuff !
- Where's the oil plug
- Proper Time to Change Oil?
- problem please help
- Where to Get Oil Change - Ft. Lauderdale
- Maybe someone can help me here
- Maf Sensor?
- Neighbors New ES350 Transmission Failed
- Various LS400 issues: #1 lose power when I hit brakes
- Death by Rear Hub Assembly?? Or am I Crazy?
- Royal Purple oil
- Service Manual
- Having starter problems?
- Car is driving sloppy
- Clanking Sound From Rear
- Need Some Help!!!!
- 90915-2004 Oil Filter
- Drain plug washer
- Tranny fluid drain...my PITA experience
- replacing these parts. need tutorial
- changing all fluids
- Lemon
- 1995 SC300 - hot exhaust gas
- Air intake latches
- Lexus Dealer vs. Outside Maintenence - Timing Belt
- spark plug guestion for IS
- Speedometer Bouncing X_X
- AC stoped working - has freon - suggestions?
- A/C issues
- a/c question
- 1992 LS400 A/C system
- oil additives?
- Oxygen sensor
- Toyota oil change
- MY 2001 GS300 making weird clicking noise from front wheels at low speed.
- in cabin a/c air filter...
- Strange A/C problem: A/C does not function if car is in direct sunlight
- All you cleaning gurus, please help.
- head job...
- Help on LS430
- windshield washer failure
- left turn signal problem
- Toyota Dealer service?
- Fuel pump 91 LS
- Oil change question...
- Anyone try a MAGNETIC OIL DRAIN PLUG?
- SC coolant loss, head gasket?
- Noob need brake and rotor advice.
- Interchangable parts???
- smokeing on start up
- Anyone else putting in 89 due to gas prices?
- Car won't start
- Battery gassing problem.....................
- so cal service contact - glendale?
- proper warm up
- shake
- 95 with r-134 ac
- iridium plugs - NGK or DENSO?
- Weird sporadic shift hesitation in '97 LS4???
- wont restart straight away
- How many miles past 90K did you go before changing the timing belt?
- ****HeLP*** Anyone know where can i get steering rack bushings???
- Engine codes
- Major Tuneup or Fix Leaking A/C?
- Rubber Preserver/protectant
- NAV reset for maintenance.
- A/C stop workin in 95 degree weather (HELP!!)
- Distilled vs Purified Water
- 92 SC400 Washer fluid not working
- Best place to buy..
- How many miles for changing differential fluid?
- Transmission shifting too late
