2008 Lexus GS350 Mark Levinson LOC help!
Old 11-13-16, 03:04 PM
aznaznazn
aznaznazn's Avatar
Default 2008 Lexus GS350 Mark Levinson LOC help!
Hi All,
I am trying to get aftermarket sub / amp install using a LOC to my OEM system. I went to a shop with all the proper gear needed.
After installation, the problem is that the sub will play for a little bit and then the LOC keeps frying out. I have been through 3 LOC's already. The worker initially wired to the sub channel and said that that was too much input so he then wired to the "rear Speaker channel" which of course still did not work.
He then suggested I should go with the AudioControl Lc2i.
Is he full of it? Or is he just wiring incorrectly? Should an LOC be able to work or do I need the audiocontrol?
Thanks,
Attached Thumbnails 2008 Lexus GS350 Mark Levinson LOC help!-resizea.jpg   2008 Lexus GS350 Mark Levinson LOC help!-resizeb.jpg
Old 11-14-16, 03:25 PM
aznaznazn
aznaznazn's Avatar
bumpinggg.
Old 12-01-16, 11:56 PM
Rozay604
Rozay604's Avatar
Get the audio control.
Old 12-02-16, 04:45 PM
Ratchey
Ratchey's Avatar
The thing sells for $4.50 on Ebay. How many do you need to blow out to see it is not a quality piece of equipment? It is rated at 59 watts max. That is total input for both channels and probably peak power. It is designed for a stock head unit with no external amp.
If you want it to work correctly, you need to spend some money and get equipment that can handle what you are trying to do.
Old 12-06-16, 10:09 AM
mjrudick
mjrudick's Avatar
Man, your time is worth far more than the cost of an AudioControl LC2i. Save yourself some time, frustration and hassle - get some quality gear.
c-low
01-29-13 12:27 PM
Jiggafong1
04-01-12 07:35 PM
Pnuge88
02-06-10 07:17 AM
CashOverAs
06-11-09 10:30 AM
GlockMan9c
03-05-07 12:01 PM
Quick Reply: 2008 Lexus GS350 Mark Levinson LOC help!
