SC300/400 ABS/TRAC/ECU computer removal
Didnt find a quick reference to get these out, here goes:
SC instructions: REmove bolster under glove compartment (where your toes would hit under dash) it just pulls down by 4 clips. Then you need to remove 4 screws: 2 under knee bolster (youll see them when you pull out toe board) and 2 in the glove compartment under little square covers. once these are removed, pull upper portion of glove box frame down and the whole thing will come off. Now you can see a duct running across the module mount bracket, remove 1 screw and pull duct off. REmove fan control ECU and then you can remove the TRAC/ABS computer with 2 screws and a pull down clip. ECU will be behind this either flat or sideways.
Pop open covers by bending tabs back and removing 4 screws to look at PCB, look for any leakage or swollen caps. Also check integrity of harness.
TriniLex
15
09-24-22 12:26 AM
