Vais ml+ lx570
Vais ml+ lx570
Hi,
i current have the SL2i-UP on my lx570 and i was thinking to upgrade to ML+ , what do u guys think , and i was wondering if some one has installed in before in lx570.
Thanks bye
Thanks bye
I totaly agree that its a big jump from what i have , the only thing that warry me is installation as i am living in Dubia and i do not blaive that any one here has an idia about it, Plus that Vais does not provide any generic installation guide for lexus.
exclusive matchup
but you have installed the sl2i-up before right? the installation is more or less the same, you still have to access the back of the radio and the navigation unit, which means pretty much the exact steps (different harnesses). of course you will need to find a spot to hide the ml+ unit but the lx570 is pretty big and got space behind / below glove box.
or, fly me out there?
i have done a few upgrades from sl2i-up to ml+, everyone has been impressed
u can get rich here in dubai cuz not many ppl do that kind of installation,
i did not have problem installing the SL2i and i would imagine the same thing for the ML+ , do u have any pics or the wiring diagram.
exclusive matchup
if you did the sl2i-up install yourself, then the ml+ is pretty much the same thing, except now you have another set of cable going to the back of the navigation screen as well. unfortunately i don't have pics myself, just in my brain.
with the sl2i-up, you either have the 12-pin or the 20-pin going to the back of radio. with the ml+, it's the 12-pin. then you have another set of high speed digital video (blue plugs) that goes to the back of navigation. then the rest should be trivial.
just make sure you get the original apple component video cable. aftermarket doesn't work.
also, i assume you have the 08-09? 2010+ is a whole different story
Thanks.
i was wondering if that going to interfer with the rear entertanment system, cuz in our regeon the standard package comes with a front and rear dvd system.
exclusive matchup
good question, i can only say for US spec cars
http://www.vaistech.com/manuals/ML%2...pp%20Guide.pdf
i don't think here in the US the rses has an effect
I guess it will work fine and if not it does really matter cuz i hardly use the rear system any way,
i was wondering if the seperet HDD that i can order is an extra piece that i have to look for a space to put or does it come impeded in the ML+ ,
I do not see a big usage for the HDD exept to copy something from a friend , what do u guys think
i ordered ml+ few days ago , i should be getting it any time , i will start looking for a professional to install it or i might installed by myself ,
guidance would be appreciated
exclusive matchup
the 2013 is a completely new generation of system, so maybe they are working on it
