Viper 690XV into 93 Lexus SC400
Hi,
I have Viper 690XV alarm only system waiting to be put in my car.
I want to install it myself however, I am confused where all the wires go.
I do have wiring information for 93 SC400.
However, Viper 690XV wiring information is kind of confusing to me.
Orange - (-)500mA Armed output (starter??)
White - Light Flash output (seems to be straight forward)
White/Blue - (-)200mA Channel 3 Programmable output (no need?)
Black/White - (-)200mA Domelight Supervision output (Where??)
Green - (-) Door Trigger input, Zone 3 (power unlock(-))
Blue - (-) Instant Trigger input, zone 1 (??? where?)
Violet - (+) Door Trigger input, zone 3 (power unlock (+))
Black - Ground
Yellow - Switched Ignition input, zone 5 (connect to Ignition wire)
Brown - Siren (+) (horn (+) or siren +)
Red - Constant Power Input
Red/White - (-) 200mA Channel 2 Output (?? which wire??)
Please anyone tell me which wire goes where exactly...its only alarm system and I am used to splicing wires but alarm is kind of new to me..
The car wiring information is on
http://www.the12volt.com/installbay/...tail/1298.html
The car requires double pulse to unlock the doors..so how do I wire this up so it gets double pulse?
Please let me know which wire will go where exactly?
Thanks
Steve
Black - Ground
Thanks
Steve
Hi,
Orange - (-)500mA Armed output (starter??) not needed
White - Light Flash output (seems to be straight forward)you should be able to switch the fuse on the unit to change the polarity to + as the sc's need to see a positive pulse
White/Blue - (-)200mA Channel 3 Programmable output (no need?)not needed
Black/White - (-)200mA Domelight Supervision output (Where??)not needed
Green - (-) Door Trigger input, Zone 3 (power unlock(-))this is door trigger not door unlock, there is a seperate harness for locks,
Blue - (-) Instant Trigger input, zone 1 (??? where?)for trunk trigger
Violet - (+) Door Trigger input, zone 3 (power unlock (+))not needed
Black - Ground
Brown - Siren (+) (horn (+) or siren +)just siren not horn
Red/White - (-) 200mA Channel 2 Output (?? which wire??)used to hook a relay up to it for trunk pop, cant remember off hand if the sc needed a relay or if you could just tap into it,
Thanks
Steve
Black - Ground
Thanks
Steve
Hi,
Black - Ground
Thanks
Steve
Black - Ground
Thanks
Steve
Orange - (-)500mA Armed output Cut and tapeWhite - Light Flash output parking light (-)
White/Blue - (-)200mA Channel 3 Programmable output Cut and tape
Black/White - (-)200mA Domelight Supervision output Cut and tape
Green - (-) Door Trigger input, Zone 3 door trigger (-)
Blue - (-) Instant Trigger input, zone 1 power unlock(-)
Violet - (+) Door Trigger input, zone 3 Cut and tape
Black - Ground
Red/White - (-) 200mA Channel 2 Output Cut and tape
Does this seem ok?? BTW car is 93.
Thanks
Steve
owali
12-27-06 07:33 PM
poorguy
SC- 1st Gen (1992-2000)
07-18-03 06:24 AM
