Any pics of a double DIN install on a '02 Sportdesign?
The reason I ask is the 2002 Sportdesign black on black center stack is not black-it's actually more of a brushed aluminum and every double DIN mount I've seen/searched for the GS is black. I'm wondering if anyone has just gone ahead and put the black mount on with the brushed aluminum climate controls and if it looks ok or if it looks like crap. Pics or opinions are appreciated..thanks...
Big Mack
That's not a bad look at All Yvie, actually looks very good-since I have all black interior, I don't have any wood trim on the steering wheel on the '02-I'm thinking I'll just keep the climate controls in brushed aluminum with the black double DIN. Shouldn't look too odd with the rest of the dash and interior being black. I'm even thinking of putting the climate controls on the bottom of the faceplate and moving the new Head Unit to the top of the center console-I never use anything but Auto and up and down temp button anyways. If I don't like I can use the 3M, thanks for the suggestion...you did a good job it looks seamless
Thanks for the compliment.
Actually it looks seamless because it is seamless. The console was done in one piece (well, two if you count the cupholder door). I took apart the climate control faceplate and the radio faceplate. It's much easier to work on that way. The end result will be much better.
The Di-Noc is really easy to work with. Be sure to use a hairdryer or heatgun to heat up the Di-Noc.
O. L. T.
SC- 1st Gen (1992-2000)
03-08-12 09:34 PM
