Opinions needed on kicker ZXSUM8 vs JL CL441dsp Cleansweep?
Appearently, not every summing interface works well w the GS OEM nav unit. Can anyone comments on these 2 here:
Which is better & works better when using an aftermarket Amp?
Support needed, Thanks!
i still retain my oem nav using aftermarket amps (except on the nav the OEM ML amp is still in the trunk) i think they tapped the wires but im not sure....
Im just trying to see if there is any difference between the two. Besides, kicker is less expensive than JL. if there isnt any differences btwn the 2, i might go w the kicker.
thanks for you input
i am using the OEM NAV with aftermarket gear. im not exactly using a setup like you have...another member and myself are using the alpine VPA hub to adapt everything.
Cool, thx!
i went overboard on my audio so all the things i have arent needed (even though im currently redoing it and going to add a second RE audio XXX sub and rework the trunk and probably the armrest)
you can check it out here....
although the title says its done, its still not lol
https://www.clublexus.com/forums/gs-...-its-done.html
its called a Alpine VPA-B222 Vehicle Hub Pro
Too bad i live so far away.. i'd luv to see that build. My last question to you. Basically, If i get tht piece will i need any other components & it will give me access to add my ipod & also will convert the signal etc..?
I am in the same boat right now.. I just did a custom install in my gs300 06.. 2 type r 10 inch subs, with 2 kenwood 9104 d amps.. the problem is the bass is rolling off after above 42 or so volume on the head unit. After doing research.. I picked up an Audiocontrol LC7 as it has summing built in.. also aux port for ipod and has a bass control ****.... I hope i made the right decision.. any input... I dont mean to thread jack either.. just wanting to make sure I am doing the right thing!
ScKcBc
02-20-11 09:39 PM
