Old 12-15-14, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working!
Old 10-20-13, 11:53 PM
  #481
sc4lex00
sc4lex00's Avatar
Originally Posted by raine
It doesn't work with the Nak system, the Nak setup is wired differently. Some of the speaker wire stuff might work (like the harness colors) but in the 3 years that this thread has been up, no one who actually tried got it to work with the Nak setup. Sorry
i have the naks system, i did this wiring and everything works great, only thing is im having trouble is the sub im not sure where or which plug is the G harness, once i figure it out ill let u guys know. if anyone can help me out with the sub issue pls thanks
Old 10-24-13, 02:59 PM
  #482
Dougspeed
Dougspeed's Avatar
I think that this was really the only issue with the Nak system, the subwoofer and THAT is what no one has been able to resolve yet.
Old 10-27-13, 03:04 PM
  #483
sc4lex00
sc4lex00's Avatar
I think the best way is just to go aftermarket amps and sub
Old 10-28-13, 06:45 AM
  #484
sc4hunnit
sc4hunnit's Avatar
You can use the factory sub.
Old 10-28-13, 08:10 PM
  #485
sc4lex00
sc4lex00's Avatar
How do u it? For the naks system?
Old 11-21-13, 05:17 AM
  #486
MGa
MGa's Avatar
IS THIS THREAD FOR YOU?
For reference, this thread is for SC300/SC400 owners who wish to:
1. Replace their factory head unit with an aftermarket one.
2. DO use your factory speakers.
3. DO use your factory subwoofer.
4. DO use your factory amplifiers (main amp and sub amp)
4. Do NOT want to install a separate amp for the main speakers.
5. Do NOT install a separate amp for the subwoofer.
It's great to see these DIY guides and all the effort put in.
I would change the position
4. DO use your factory amplifiers (main amp and sub amp) into 4. DO use your factory sub amplifier, since this tutorial bypasses the main amp.
Keep up the good work!
Old 11-21-13, 09:11 AM
  #487
raine
raine's Avatar
That's been like that forever and II guess no one even noticed until now LOL
fixed
Old 12-06-13, 01:46 PM
  #488
mnewxcv
mnewxcv's Avatar
well ive been working on this today to install my new head unit. very valuable thread and I thank you OP. here are a couple things ive found.
1. I preferred to run my speaker wires through the center console along the transmission tunnel to the back seat rather than tear up the passenger side trim. snaking it under the carpet was a little tricky, but I didnt have to remove any additional parts that werent coming out anyways.
2. when I got to the trunk and took out the cd changer, I found this:
wheres the oem amp?!
oh wait, found it
Old 12-07-13, 12:07 AM
  #489
raine
raine's Avatar
You could run the speaker wires down the tunnel (nothing wrong with that)... when I wrote the HT I did plan on the passenger side parts coming off since I was wiring other stuff too at the same time (EDFC, etc.) and I wanted to be able to get to those wires if there were any issues without having to pull the passenger seat/center console out
Old 02-26-14, 08:22 PM
  #490
SC300T1
SC300T1's Avatar
I'm batman
Came across this thread on a random google search for a diagram, read the thread and hoped I had a pioneer unit which i did! You are a goddamn super hero Raine.
Old 02-26-14, 09:07 PM
  #491
raine
raine's Avatar
Old 03-03-14, 06:34 PM
  #492
ISFFUN
ISFFUN's Avatar
First off, thank you for the guide.
I did this on my 97 SC w/ 12 disc changer and got everything working the first time.
However-
I don't understand the importance (in my case) of section I regarding the subwoofer amp and antenna.
My Pioneer DEH-80PRS keeps the antenna up whenever it's on no matter the source (as far as I know,I could be wrong). The subwoofer also works on all inputs.
So why do I need to bother with section I and splicing those wires? I ran the RCA cable from Radio Shack into the +/- on harness D and I get a solid sub signal and the antenna works. I kinda wish the antenna would go down when the headunit is on Aux/BT/USB but I can deal with it.
Old 03-03-14, 08:47 PM
  #493
raine
raine's Avatar
However- I don't understand the importance (in my case) of section I regarding the subwoofer amp and antenna.
well...
...I kinda wish the antenna would go down when the headunit is on...
Old 03-03-14, 09:55 PM
  #494
ISFFUN
ISFFUN's Avatar
I follow your logic, but there's no communication between the head unit and the factory amp. It's just a line out that's on for all sources. It (the aftermarket headunit) doesn't turn the amp (blue/white wire) power off when I go to CD. It doesn't have a blue antenna wire AND a blue/white remote power- only a remote power.
Old 03-03-14, 10:30 PM
  #495
raine
raine's Avatar
Ah I see what you're saying... I guess it may be a combo of wires A1 and A8 at the head unit harness) AND the splice trick at the sub amp combined that makes the antenna function as it's supposed to (up when radio, down when anything else) - provided, as you said, that the aftermarket head unit has a dedicated antenna wire.
Anyhow, if you can deal with the antenna up all the time, no worries on your end.
Quick Reply: HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working!
