HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working! - Page 32 - Club Lexus Forums
Old 12-15-14, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Thread Tools Search this Thread
Old 08-01-13, 10:21 AM   #466
RicoLSX
RicoLSX's Avatar
Thanks creating this thread!
I ordered my deck last week having only read the the thread on the how-to DIN install (hybrid Metra/factory mounts) so I ordered the Metra wiring harness as well only to plug it in Tuesday at close to midnight to find no power up of the deck
I did some googling and came across this thread Tuesday night, so yesterday I bought the all the items necessary and went at it. I was successful in getting all the speakers to work along with the sub and power antenna. I also used that optional ground off the chassis to wire up two ground cables to a relay for the e-brake bypass for my Pioneer X950BH.
Only warning I have is after 16+ years of baking in the sun the ABS plastic sub grill didn't like being pulled up on! It broke in quite a few places so I had bust out the good ol' duct tape to give it from structure again LOL.
RicoLSX is offline   Reply With Quote
Old 08-01-13, 10:47 AM   #467
raine
raine's Avatar
Followed everything to the t?
raine is offline   Reply With Quote
Old 08-02-13, 06:40 PM   #468
RicoLSX
RicoLSX's Avatar
Quote:
Sure did! I didn't use the home audio wiring though, I bought a 100' spool from Radio Shack (other option was a 50ft). I used the remote on for the pink wires (power antenna) so I ran the 18ga lead from the grey/red for the rear sub.
Old 08-06-13, 02:20 AM   #469
raine
raine's Avatar
cool deal man, glad it worked out!
Old 09-04-13, 12:51 PM   #470
DIrEctQL
Chicago Lexus Club Moderator
DIrEctQL's Avatar
So much drama over Metra harness. First off, it does work but ...
1. Ground the stereo to the body. Don't use the ground from the harness because you'll get noise.
2. There are two power antenna wires and two antenna connections (FM and AM). The stock radio flips one of the power antennas for FM and the other for AM. You'll most likely use FM with your aftermarket headunit so you'll use only the top power antenna wire in your harness.
Also, per Metra dash kit. You must use the metallic bracket, because it's used to hold the whole center console in place. Without it, the center console will get wobbly and make all kinds of creaking noises.
DIrEctQL is offline   Reply With Quote
Old 09-22-13, 04:17 AM   #471
hask
Thank you very much for this great post, I follow the instructions, every thing work fine, however one thing is remaining which is the antenna, the reception a bit not clear as the OEM pioneer radio, I connect A1 with A8, the antenna goes up and down but once I switch the radio off, I hear a spark sound from the speakers, I disconnect A1 from A8, the spark sound goes (still connecting A1), and the antenna goes up and down without spark sound . but is it the cause of low quality radio reception? or I should connect the "diversity antenna" ?? because I use only the big antenna connection.
Thanks
hask is offline   Reply With Quote
Old 09-24-13, 10:19 PM   #472
raine
raine's Avatar
Quote:
Thanks
IIRC I used a Y-adaptor I bought at an auto parts store that combined both antennas, not getting any of the issues you are having... maybe that'll solve your problem?
Old 10-07-13, 01:13 AM   #473
nxrunner
I have the pioneer sub amp out of asc300 / sc400. I can not figure out which is the power wire, ground, and low line inputs. Can you pleas complete thediagram you have listed on the firs page so I may use this amp in a different vehicle/setup. Thanks
nxrunner is offline   Reply With Quote
Old 10-13-13, 01:20 PM   #474
1CleanSC
1CleanSC's Avatar
Question, after I did the sub amp wiring (along with everything else using the METRA kit) my radio antenna rises even if I'm not using the radio. Can anyone provide any help with that? My head unit is the new Pioneer APPRADIO 3.
However, when it comes to completing the sub amp / radio antenna wiring there was no METRA harness used if you follow this thread. So this is why I'm confused and wondering if anyone can provide assistance with this problem. Thanks!
1CleanSC is offline   Reply With Quote
Old 10-13-13, 03:05 PM   #475
DIrEctQL
DIrEctQL's Avatar
After market stereos either have the antenna on wire or they don't. Pioneers don't which is why antenna is out whenever the radio is on. Can't do anything about it.
Old 10-13-13, 10:40 PM   #476
1CleanSC
1CleanSC's Avatar
Damn, that really sucks. I might just disconnect the wire so that it never goes up. The radio antenna makes that car look awful when it's up in my opinion.
Old 10-14-13, 05:55 AM   #477
DIrEctQL
DIrEctQL's Avatar
You could install a low profile antenna and install it somewhere off sight. That's what I'm in the process of doing.
Old 10-14-13, 06:31 PM   #478
sc4hunnit
I have a Nakamichi system and I did a bunch of wire running, speaker swapping and then some. As far as wiring up my new unit (pioneer 4500BT) I used the Metra harness with the RCA's on it. Whilst using the factory Nakamichi system, all speakers played, when I then switched the head unit and used that Metra harness, the sound was nowhere near the factory setup. There was also a very annoying pooping sound when I'd turn on/off the radio/car. My solution for that was a double ground. I used the ground from the harness and I then grounded that ground to the chassis. No more popping noise.
Weeks go by and I canít stand the crappy sound so I hooked up a Memphis 600w 4 channel amp. I used the connector from the Nakamichi amplifier to figure out what speaker was which by using the write up on the first page for the pioneer amp. It's not exact but its close and I figured it out. After getting all the wires hooked up to the new Memphis amplifier, there was sound. It was good and clear.... for like a half hour... The amp would get INSANELY HOT within 5 minutes of low volume music. I then realized that one of my tweeters were simply toast. Toasted to the point where I could see the plastic bubbling from the speakers leads! I proceeded to then disconnect both tweeters. The amp was still getting hot! I couldn't understand! I then hard wired the front speakers; (by using the factory plug outside of the speaker pod.) the amp was still getting hot. I then separated the speaker pod. Inside of there is the capacitor for the tweeter. The strange thing is though, the input wires go into the tweeter first it seems and then to your driver. I removed that crossover, installed a set of component tweeters, got rid of the 4" and mounted a 5.25" inch speaker inside. Totally different sound afterwards! And as far as the amplifier, nice and cool! Next to be replaced are the rear speakers.
I was also able to use the factory subwoofer as well. I did that with a Kenwood Excelon 5ch amp. The gain did have to be set low but it worked and sounded way better than it did using the Metra harness on the factory Nakamichi amp.
I hope this might help anyone.
sc4hunnit is offline   Reply With Quote
Old 10-19-13, 11:46 AM   #479
raine
raine's Avatar
Good to see you have something working, though you went way beyond just a head unit install
Old 10-20-13, 11:41 PM   #480
sc4lex00
Default help pls
Quote:
Originally Posted by FurySC400 View Post
Now that I think of it, I could be wrong about the original amp not powering the F&R speakers along with the subwoofer. Perhaps you are actually right, and this one amp powered F&R and the subwoofers in 1992 SCs, rather than having a separate amp for the subwoofer as in later SCs.
hi furySc400 im new here and i did my research, i might have miss it, but can u help me out pls
i have the same set up all my speaker and headunit (i have a boss double din deck) is working fine at the moment except the sub. im not sure how to connect it to get ti working
i have the 93 sc400
thanks
sc4lex00 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
95 SC400 - How I got Nak sub to work with aftermarket HU... pogoism9 Lexus Audio, Video, Security & Electronics 2 03-19-17 08:26 PM
How to Install an Aftermarket Radio in 1998 Lexus es300 AWehland88 Lexus Audio, Video, Security & Electronics 19 11-14-16 08:34 AM
1997 ES300 Aftermarket stereo installation - powers on, no sound jaredmac11 ES - 1st to 4th Gen (1990-2006) 14 11-18-15 11:51 AM
'98 ES300 Aftermarket Head Unit and Factory Speakers/Amp? WILLYumD Lexus Audio, Video, Security & Electronics 2 09-30-15 06:28 PM
Aftermarket HU on 1999 Nakamichi system/bypassing stock amp kponti Lexus Audio, Video, Security & Electronics 4 03-09-12 08:07 AM
Tags
1996, aftermarket, amp, amplifier, connect, head, install, kenwood, lexus, remove, sc300, sc400, subwoofer, unit, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
  • Ask a Question
    Get answers from community experts
What's your question?
Send
