Last edit by: IB Advertising
Browse all: Interior
- How do I Install Aftermarket Amplifier power wire
Step by step instructions for do-it-yourself repairs
HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working!
#436
The blue wire with a white stripe has been spliced into with speaker wire, and run to the amp as a turn on signal. It works. I have power running from the battery through the firewall. The ground is working and I found it under the rear seat. The RCA's are also plugged in correctly on both ends. Then I have the speaker wire from the amp to the sub which is also being run correctly on both ends. The amp turns on and I know for the fact the speaker is in working condition. Maybe the RCA's are old? I know the last time they worked was about 4 years ago...Not sure if that could be it though. I'll take pictures of the amp in about an hour or so so you can see what I'm working with exactly.
#437
Damn....attempted to install my deck today and it's looking like a failure. Not sure why I thought it would go smoothly with the Nakamichi. I hate days off where I get nothing accomplished, PC Richards told me $45 to install it so I'm going to go there in a couple hours and just pay to get it done. I used to be good at this stuff, but this Nakamichi system has so many wires going into it I don't even know what to do.
#438
#439
I wired a double din radio and it powers on but no sound at all...the speakers seem to be wired correctly. When I turn the volume all the way up and turn the power off I hear a pop from the speakers. Any thoughts on what the problem is???
#441
#443
#449
