TV Convertor Box
go to: www.tvandnav2go.com
~ Cap
I recently asked about what people with portable TVs were to do, when I was recently at a digital TV booth at a local convention. They said a battery operated digital TV converter had recently been introduced.
But, in your case, I think all you need to find is a digital TV converter (there are many brands) that takes 9v or less from the plug-in power module (i.e., "wall wart"). Then, you just drop the car's 12-13.6v to the 9v or less, using a voltage regulator, and you should be all set.
My GX has a 110 Volt outlet, so I should be able to use a house converter, provided it doesn't draw too many Watts.
~ Cap
It shouldn't draw more than what your outlet can dish out. It's amps that you should be worried about more than watts. But like someone suggested, I would look into finding one that can run off of batteries and get a voltage regulator of sorts that would drop down the voltage in your car from 12-14 to whatever voltage your converter requires... This can be accomplished by wiring resistors in-line with your 12v line in your vehicle. Any car stereo shop should be able to do this. It will also be easier to do a more thorough and "factory-like" install because it can be hard-wired into your vehicle rather than being plugged into a socket. Hope this helps!! GL!
Cut-Throat
01-08-07 04:34 PM
