DO NOT use CDs/DVDs with labels! - Page 2 - Club Lexus Forums
Thread Tools Search this Thread
Old 08-23-09, 05:34 PM   #16
engin_ear
Everything in Moderation
engin_ear's Avatar
Quote:
Originally Posted by Lexscme View Post
wat if u have a factory cd changer??
NOOOO stick-on CD labels!!!
engin_ear is offline   Reply With Quote
Old 01-15-10, 12:19 PM   #17
bestint
should be fine if its a cartridge changer but not the indash ones.
bestint is offline   Reply With Quote
Old 01-16-10, 11:27 PM   #18
engin_ear
engin_ear's Avatar
Quote:
Disagreed. If CD is left in loaded position and it is hot out, same problems can arise.
Old 05-03-10, 12:55 PM   #19
SKIIP
Default ^^^^
Once the CD is stuck...what should you do to get it back out and operating again (2002 UL)??
Please advise. I HAVEN'T LISTENED TO A CD IN MY CAR FOR ABOUT A YEAR AND A HALF NOW, BECAUSE OF THIS!
HELP!
SKIIP is offline   Reply With Quote
Old 05-04-10, 12:48 AM   #20
engin_ear
engin_ear's Avatar
HELP!
You're going to have to have the unit opened up by a technician and have the CD and offending label removed, along with any glue that has made itself onto any components (hopefully none). Unless you know how to do this yourself. Unit will likely have to be removed from dash.
Old 05-10-10, 05:26 PM   #21
krogermike
Default Nav system for 2001 ls 430
Any idea how to get an updated navigation system dvd without paying the dealer the 250.00 that they want?
krogermike is offline   Reply With Quote
Old 06-28-10, 03:34 PM   #22
subie2GX
subie2GX's Avatar
I had the same experience with my WRX but subaru replaced the unit under warranty.
As for getting an updated map, try finding one on CL, i found one for $75.00.
http://newyork.craigslist.org/mnh/pts/1811812292.html
subie2GX is offline   Reply With Quote
Old 12-13-10, 09:55 PM   #23
nervekiler
also steer clear or library cds. these often have labels glued to them.
look into litescribe (old technology from 2004) where you can print the label on the cd inside of the burner.
i do not see many problems with my customers, mostly just library cds around here in portland.
nervekiler is offline   Reply With Quote
Old 03-09-11, 11:00 AM   #24
jac430
jac430's Avatar
It is also clearly stated in the manual not to use labeled discs:
Jac
jac430 is offline   Reply With Quote
Old 04-14-11, 07:32 AM   #25
toantran99
My wife didn't listen to my advice about the cds with label, cost me about $1200 to replaced a 6 disc cd changer in our 2002 Acura TL-S
toantran99 is offline   Reply With Quote
Old 04-14-11, 07:40 AM   #26
jac430
jac430's Avatar
Quote:
Yes, our wives have a tendency to cost money....
But on the other hand we get a lot in return if everything works out well.
Jac
Old 04-17-11, 11:34 AM   #27
Doc H
Quote:
Originally Posted by ichi View Post
I agree about sticky labels, but i doubt this applies to inkjet printable CDs which are manufactured with the labels on them.
It does indeed apply. I removed the CDs from my 470 when I traded and the printable media had started to flake on all of them. Hadn't affected the performance of the CD player, but clearly the temperature changes had caused the media to separate. Lightscribe should be fine because the media is below the outer plastic layer, but easier just to use an iPod. Better safe than sorry....
Doc H is offline   Reply With Quote
Old 06-28-12, 01:01 AM   #28
Ayaney4
Lexus have rare issues like this,
Ayaney4 is offline   Reply With Quote
Old 07-09-12, 08:46 AM   #29
dengman
I do disc printing at work and lets just say the labelled stick ons arent used. I've had customers try to bring me discs from walmart and ask if I can print labels and stick them on.
I tell them the stick on label eventually will peel and might get stuck in the cd player.
Discs available locally tend to have a higher fail rate. 20discs bad out of 100 on one brand I've tested 5discs bad out of 100 on another. The discs I use have a 1 out of 1000 failure rate. Plus if it doesnt burn properly its my mistake no theirs. They want 100 discs you'll get 100discs not 80 because 20 didnt burn correctly.
I say no to labeled! Light scribe discs are the better consumer replacement for that issue! Love technology.
The question is will CDs ever get replaced and just be all electronic format for cars?
dengman is offline   Reply With Quote
Old 12-11-12, 11:33 PM   #30
amir911
Default rx350 audio,display not work
hi all , i have rx350 model 2010 year audio not work , lcd is bright but my screen no display
Please help me
amir911 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
How can I get my music to play through the CD Changer? ps4601 GS - 2nd Gen (1998-2005) 1 07-07-15 09:35 AM
IS250 CD Changer "ERROR 3" mikeho IS - 2nd Gen (2006-2013) 6 05-22-15 03:17 PM
CD changer magazine won't load Suzer RX - 1st Gen (1999-2003) 2 03-16-15 02:41 PM
CD Changer: Help: Newbie GeneE GX - 1st Gen (2004-2009) 8 07-17-11 04:48 PM
CD player failure Foxberry IS - 2nd Gen (2006-2013) 5 07-31-06 12:34 AM
Tags
cds, donotuselabels, dvd, dvds, labels, lexus, paper, play, recordable, warp, warped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
