problem 2000 rx300. No volume on radio.
Old 06-01-07, 03:14 PM
mtagent
mtagent's Avatar
Default problem 2000 rx300. No volume on radio.
Hello all,
I have the lexus premium sound system and a few days ago the volume just stopped working. Also, when I depress the button for bass, mid and treble the setting is frozen at "0". any thoughts? I have a feeling it is the amp but would love some feedback before i go trolling for a stock replacement. Outside of this, all looks fine on the display.
Thanks in advance.
M
Old 11-25-11, 06:56 PM
Keaberts
Keaberts's Avatar
Default having same problem..
I am also having the same problem with my RX300.. its a 2000 and has the factory base Pioneer system... I have no sound from radio, cd, or tape... bass, treble, fade, and mid are all stuck at 0.... from what i am finding online it seems to be the amp under the rear seat/cargo area? can anyone confirm this for me?
Old 12-09-11, 11:37 PM
Shibumi1
Shibumi1's Avatar
sounds like the amp in both situations...id chk the audio amp fuse first... then start exploring other options....
Old 12-10-11, 07:24 AM
hypervish
hypervish's Avatar
yes, the amp is under the rear seat. this should help you find it: https://www.clublexus.com/forums/rx-...he-amp-at.html
Old 12-10-11, 09:21 AM
irishcharm
irishcharm's Avatar
check fuse for radio and amp......if all is well.....shut off car and pull both. then remove battery terminal (excessive? yes I know)
wait a few minutes then plug all back in....still no power? grab a multimeter and test out the power/switched on the amp. if there is power, problem = amp
thomaszr
RX - 1st Gen (1999-2003)
14
04-17-17 06:46 PM
Pandaman
02-03-11 07:57 PM
robsvdp
01-29-10 11:14 AM
Quick Reply: problem 2000 rx300. No volume on radio.
