How To: Build and Hardwire an Auxillary Input to OEM Stereo
Old 04-25-12, 11:17 PM
  #691
Sicarius12
Sicarius12's Avatar
I've read through the thread but haven't found reference of what amp relay to use.
3, 5, 15 or 30?
Thanks.
Old 04-30-12, 01:48 PM
  #692
PureDrifter
BahHumBug
PureDrifter's Avatar
i believe I used 15 or 25amp relays, as they are handling unamplified sound high amperage shouldn't be needed.
Old 05-16-12, 02:55 PM
  #693
ravig292
ravig292's Avatar
PD, will these work?
http://www.ebay.com/itm/5-12V-BOSCH-...item45fb695cdf
Old 06-02-12, 03:43 PM
  #694
PureDrifter
BahHumBug
yes those should work fine.
Old 06-04-12, 04:40 PM
  #695
nordoyan
nordoyan's Avatar
PD, do you think the ECT switch can work as the SPST switch?
Old 06-05-12, 05:22 AM
  #696
PureDrifter
BahHumBug
possibly but the ECT switch (in the LS at least) isn't an SPST, it's a SPDT or SPCO switch.
if it has >2 positions, it won't work. (ECT in the LS is PWR, OFF, SNOW, so it won't work)
Old 06-06-12, 08:37 PM
  #697
rescued
rescued's Avatar
Default 98 GS400 with Nak (no nav)
I have a 98 GS400 with Nak (no nav) and I'm just not seeing the pin outs that people are describing. I have a 12 pin on the glove 6 disk changer (first pic), but no white, black, green, red in pins 9,10,11,12. And there is no 12 pin connector on the head unit (biggest are 2 -10 pins) [second pic]. Am I missing something here?
Attached Thumbnails How To: Build and Hardwire an Auxillary Input to OEM Stereo-cd-changer.jpg   How To: Build and Hardwire an Auxillary Input to OEM Stereo-head-unit.jpg
Old 06-13-12, 06:28 AM
  #698
77i9
77i9's Avatar
@Rescued - just follow the harness(in ur first pic) to a silver box to the right of the cd changer. Then follow the output harness of the silver box to a male female connector in front of the box. That connector has the black, white, red, and green wires that you need to connect to. You can splice to either side of the connectors. I have a 98 GS 400 and I ran into the same problem thinking that I need to hook up to the harness coming out of the cd changer. Just pm me if you have more questions.
Old 06-22-12, 05:03 PM
  #699
Kris9884
Kris9884's Avatar
Hell yea, this will officially be my first mod. I cant stand the radio and whats a cd?
Old 06-26-12, 12:27 PM
  #700
S14DST
S14DST's Avatar
Hey!
I have 1993 SC400 with Nakamichi headunit, 12cd changer and stock amp in trunk!
Can anyone can tell me which wires should I use to make this work?
I've read to page 14 and didn't found anything and google doesn't have anything too!
Could someone help? As I've already bought all necessary parts to do this
Old 07-02-12, 05:30 AM
  #701
S14DST
S14DST's Avatar
Originally Posted by S14DST
Hey!
I found that someone used
Black R+
Blue L+
White R-
Red L-
Everything works fine, except I think signal is going straight to head without amplifier, as I have very quiet sound and absolutely no bass!
Could someone tell me how to wire correctly?
I used this diagram http://www.lextreme.com/Lexradiowcd.pdf
Old 08-05-12, 01:08 AM
  #702
S14DST
S14DST's Avatar
Black R+
Blue L+
White R-
Red L-
Bump!
Nobody had this kind of issue?
Maybe head unit should be turned all the way up or something else that I'm missing?
As all the wires are correct i.e the same color and connector
Old 08-07-12, 08:59 PM
  #703
moffutt
moffutt's Avatar
That looks like the same diagram I used on my 95 sc400 and it works great. I didn't put in the relays I just wired the aux straight into the head unit and cut out the cd changer.
Old 08-09-12, 11:00 AM
  #704
S14DST
S14DST's Avatar
Yeah I tried to wire it straight in too (there is a DIY for that mod too)
Maybe sound was a tiny bit louder, but still very quiet and tiny amount of bass, compared to what my cd changer gives out... I just don't get why it doesn't works for me... maybe my laptop had to have volume turned up to 100% or something like that?
But when I had relays connected I tried with my iPod and even with max volume it was very quiet and minimum bass
At the moment I'm using cd's but I actually hate them
Old 08-12-12, 12:45 PM
  #705
PureDrifter
BahHumBug
sounds like you mucked up a ground wire or have polarities reversed on one side or more.
Quick Reply: How To: Build and Hardwire an Auxillary Input to OEM Stereo
