How To: Build and Hardwire an Auxillary Input to OEM Stereo
Old 11-15-07, 02:25 AM
  #151
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
Originally Posted by RTGS400
I do have a spare set of 4 relays that are already soldered together if anyone wants to save some time Shoot me a PM.
to help the sale il add that i made that set
Old 11-17-07, 11:03 AM
  #152
isdjmark
isdjmark's Avatar
how come i dont see the trigger part? Help Please
Old 11-18-07, 09:36 PM
  #153
GSLEXXX
GSLEXXX's Avatar
hi puredrifter. Would the pin diagram be the same for the 03 gs300 Mark L. as the 01 gs300 Mark L. that was described earlier in the thread? thank you.
Old 11-20-07, 08:18 PM
  #154
isdjmark
isdjmark's Avatar
K got this to work on a 02 Gs430 with ML/Nav but have some issues:
1.I have a Zune, same thing right?, and hhok it up via headphones to the rca jack but the signal goes goes in even on radio mode.
2. The CD Changer is bleeding into the Aux.
3. I think i have a ground issue b/c when i hit the gas it makes a winding sound.
4. The signal is not that loud i mean its good but i want it louder and advice.
Also i didnt see the trigger part of the tutorial so maybe i did sumtin wrong with that. But i thought it jsut common sense that triger one goes to neg and the other goes to pos.
Any help would be nice. Thank you.
Old 11-21-07, 02:56 AM
  #155
PureDrifter
BahHumBug
Forum Moderator
the only way this would happen is that you didnt intercept the correct wires.
post up which wires/colors/pins u cut (and where ur cutting) and il tell you what the problem is.
the grounding issue and SQ issue is related to cutting into the wrong wires.
Old 11-21-07, 11:42 AM
  #156
isdjmark
isdjmark's Avatar
Originally Posted by PureDrifter
01 GS3 w/o ML
only plug behind changer OR the only 8pin connector behind the amplifier, should be orange
R- =pin 6 white
L- =pin 7 Green
R+ =pin 1 Black
L+ =pin 2 Red
with ML is same colors/pins but the amp connector is the only 12pin instead of 8pin
nav/non nav doesnt matter.
I taped these wires on my factory amp located under my nav.
Old 11-21-07, 09:58 PM
  #157
GSLEXXX
GSLEXXX's Avatar
Which cables would be the Sub output and would i be able to connect these to a high level input on another amp without frying the mark L amp? Does a separate amp power the stock sub? Or the other option I have is, which I would also need guidance in finding these, output of R+,R-,L+,L-. While doing this aux port might as well kill two birds with one stone and hook up a kicker cvr12 and a amp. Mark L sub picks up the higher tone bass very well, while the very low tones not so much. I think a 12" kicker and the mark L sub will work pretty nice together.
Thanks for the response isdjmark by the way. Found the amp ^_^
Old 11-22-07, 12:18 AM
  #158
PureDrifter
BahHumBug
Forum Moderator
those seem to be the right wires but the amp on the 2GS as far as i know wasnt in the dash.....
Old 11-22-07, 12:28 AM
  #159
GSLEXXX
GSLEXXX's Avatar
he means under the nav unit in the trunk not the nav monitor.
Old 11-22-07, 02:08 AM
  #160
PureDrifter
BahHumBug
Forum Moderator
ahh, icic.
snap some pics of the wiring u cut, make sure u didnt loosen any of the pins in the harness.
this mod has already been confirmed on navi equipped 2GS so there is something in the wiring that hasnt been done right.
Old 11-24-07, 10:51 PM
  #161
GSLEXXX
GSLEXXX's Avatar
http://cgi.ebay.com/ebaymotors/5-PAC...QQcmdZViewItem are these the correct relays?
Old 11-25-07, 12:22 AM
  #162
PureDrifter
BahHumBug
Forum Moderator
yep, similar to waht i used.
isdjdmark: the issues you described to me are consistent with what happened to me when i miswired the setup the very first time i installed it. BE 100% sure that you are reading the pins correctly on the harness you are cutting, the same/similar colors may be present more than once.
Old 11-25-07, 12:37 AM
  #163
GSLEXXX
GSLEXXX's Avatar
kk i'll order them today. how difficult is it to get to the back of a cd changer in the 2gs? figured I'll tap into the connection from there since I'm making the aux cable come out of the ashtray.
Old 11-25-07, 04:14 AM
  #164
PureDrifter
BahHumBug
Forum Moderator
i honestly have no idea, i havent personally worked on a 2GS. i have had confirmation that this method works on the 2GS and on a NAV equipped 2LS.
Old 11-25-07, 05:03 PM
  #165
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
The changer is super easy to remove. Take the glove box out, which is two 10mm bolts and a couple phillips screws. And then its a couple more 10mm bolts to remove the changer. Thats where i tapped into the wiring to install my ipod Works like a charm.
Quick Reply: How To: Build and Hardwire an Auxillary Input to OEM Stereo
