Factory Nav touchscreen as USB or PS/2 pointing device - Club Lexus Forums
Thread Tools Search this Thread
Old 08-23-06, 09:38 AM   #1
prex
Default Factory Nav touchscreen as USB or PS/2 pointing device
Hi - I've done my homework and am pretty sure I know the answer isn't the one I want, but was wondering if anyone knows of a device that allows you to use the factory navigation (in my case 2003 SC430) touchscreen as a USB or PS/2 pointing device. I'm well aware of RGB converters that let you use the video, but haven't found anything that will let you get at the touchscreen.
Any pointers would be greatly appreciated.
Thanks,
-b
prex is offline   Reply With Quote
Old 08-23-06, 05:43 PM   #2
Tranman
Tranman's Avatar
I've been doing research too...and here's the most promising
There is a product called CAN-view that is made for Toyota Prius to allow for extra functions and viewing of data from the Hybrid system. The unit can output touch screen coordinates (through a serial port) from the stock Toyota touch screen (which should be the same as the Lexus one) because it interfaces through the Navigation computer connector.
This person has installed a Mac in his Prius and able to control it via the stock touchscreen using the CAN-view unit. http://www.kusnetz.net/prius/
Check http://www.hybridinterfaces.ca for CAN-view.
The creator of CAN-view says that if the Prius communication system is the same as the Lexus, then it should work...and we can use the touch screen coordinates coming out of the serial port of the CAN-view...I'm almost willing to bet that it should work since the Navigation computer and connectors looks almost exactly the same.
I don't have the money to try this out at the moment...but maybe it's worth your while to check it out if you really want this to work.
Tranman is offline   Reply With Quote
Old 06-15-14, 10:30 AM   #3
szolnoki
Hi,
Have you found a solution already?
Thanks,
-b
szolnoki is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
GROM Audio USB2P-Toy Review HerkFE LS - 3rd Gen (2001-2006) 9 06-16-14 02:38 PM
A Clean Carputer.... New2me07 GS - 3rd Gen (2006-2011) 1 02-02-13 10:47 PM
Nav touchscreen failure + no sound = coincidence? DYUADV IS - 2nd Gen (2006-2013) 1 09-01-12 10:08 AM
Who has had dealer replace complete NAV unit out of warranty? s6 4rings IS - 2nd Gen (2006-2013) 2 08-14-12 04:09 AM
Tags
canview, clublexus, computer, coordinates, is250, lexus, nav, navigation, prius, read, sc, screen, touch, touchscreen, usb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
  • Ask a Question
    Get answers from community experts
What's your question?
Send
