Help with RCA output!!!
Hey guys....yeserday i tired to install 2 12's in my 92 sc400. well i thought i was finfished.
i hooked up ground,batt, and remote wires. i took out my stock 10's in the back and used those wires and conencted it to the RCA wires and it didn't wokr. can someone tell me what is the problem? am i hooking it up the right way??? i search the forums but found bits and peieces BTW this is being hooked to stock deck. I hoooked the rem. wire tothe radio fuse. can you guys help please???
i forgot what kind it is but the rca adapter has the ground wires, the gain controls and the ouput wires.sorry if this is not clear ...it's a speaker to rca adapter
Zombie Slayer
Originally Posted by /Aerostar\
Doesn't that wiring setup drop your impedence way down, effectively reducing the amp output alot?
Or, are you using after market amp as well to compensate?
Originally Posted by TMaxxTim
You need to route the LLC off of the speakers in the back, not off of the subwoofer wires.
i tried it but nothing works.....do you think i have the remote wire hooked up right? b/c i had a friend that hoooked up the rem. wire to the radio fuse. btw do i have to mess with the original factory amp???
yeah the amp power is on....then it boils down to hooking up the rca wires to the old fact. sub wires...i think the old amp blew or something. maybe thats why it isn't on
maybe your stock amp is messed up. if you tap in after the factory amp, then maybe thats your problem. you also are tapped in to something that is amplified (your factory amp) witch is running into your other amp(your aftermarket). from what i know that is not a good idea. eventually somthing will give
