Lexus Diagnostic Codes
Can anyone tell me what these diagnostic codes mean:
I used the 'hidden' menu in my Navigation system.
Thanks,
Mark
Code:
2001 Lexus GS 300 Fr-DISPLAY: Code Subcode 01-D5 190-58-9 01-D5 360-58-9 01-D8 360-3C-1 01-D8 190-3C-1 01-DC 360-3F-3 01-DC 190-3F-3 DSP AMP: Code Subcode 01-D6 -01-D 01-E1 110-01-2 01-E1 -01-1 01-E3 -01-4 CDCH: Memory 01-62 G/W-ECU: OK AUDIO H/U: OK NAVI-ECU: OK
Thanks,
Mark
That's a list of all errors or warnings since the last time they were cleared (probably never). Unfortunately you can't see when they occured. Most likely they are from when the car was assembled. My list was about the same length.
For example:
01-D5 190-58-9
D5 = Component switched off (no communication)
190 = The radio
9 = the amount of times it has happened
I don't have all the codes yet. I'm waiting for a complete list.
If you go to the screen with the list and hold the "Code CLR" button for three seconds they will be cleared. Then you can check later and see if any new has popped up.
For example:
01-D5 190-58-9
190 = The radio
MarsB007,
Here is how you access the diag mode:
https://www.clublexus.com/vb/showthr...threadid=15151
Yes, it will show you how many satellites it is using. The most I've seen is eight which seems to be the max.
It looks like this: http://www.greendale.se/lexus/screen/101-0158_IMG.JPG
