pics of single din head unit installed in sc300/400
Old 04-25-07, 08:01 PM
FSUnoles
FSUnoles's Avatar
Default pics of single din head unit installed in sc300/400
im getting ready to install a single din hu and was wondering what your guys cars look like so i can get an idea.
Old 04-26-07, 03:01 PM
rich001
rich001's Avatar
Here are some pics of a single DIN video unit installed in a SC400. The trim ring and lower pocket were custom installed. The iPod cable was run to the center console.
Old 04-26-07, 07:26 PM
MJHSC400
MJHSC400's Avatar
That looks good-- I think I've seen your car on cardomain--
Nice work--
Old 04-27-07, 04:06 PM
justenzo
justenzo's Avatar
did u use a pre-existing kit and modify it? if so what kit was it... btw nice work.. looks great..
Old 04-28-07, 02:53 AM
rich001
rich001's Avatar
I used a Metra 88-00-8000 Toyota Pocket, which has pre-existing mounting holes on both sides, as well as a double DIN trim ring. The double DIN trim ring is made of 1/4" MDF; I use templates to route out the outside as well as the inside. High build primer and then Satin black paint. Stereo and pocket are mounted to the factory brackets, centered and flushed back so the trim panel lines up with the upper AC panel and the lower ashtray.
Building the templates takes time, but I can now duplicate them.
Old 04-28-07, 01:42 PM
tom44vip
tom44vip's Avatar
what'd you use to saw the 1/4" mdf? would a jigsaw work?
Old 04-28-07, 11:19 PM
VinnyQH
VinnyQH's Avatar
Old 09-19-14, 05:20 PM
t2d2
t2d2's Avatar
Old thread bump, so I don't expect that anyone who posted to it 7 years ago will necessarily respond. Does anyone have a guess as to what pocket VinnyQH used in the previous post? That has a nice look to it, unlike the Metra pockets that don't match any other texture in the car (see rich001's pics in post #2) and are too cheaply made to hold their shape, if the one I have lying around from a spare parts acquisition is any indication.
The challenge is finding a pocket narrow enough to fit the lower half of the SC's opening. A typical 7" pocket is a bit too wide if it has mounts designed into the sides of its front panel, like most I've looked at do. The Metra ones are also 7" but the mounts are not flush on the sides.
istundra
11-19-12 04:07 AM
JAXLS460
02-09-06 09:26 AM
mhsu408
01-14-06 01:20 AM
rexus31
05-15-02 04:38 PM
Quick Reply: pics of single din head unit installed in sc300/400
