Proposed Audio Modifications: Please Critique
Well I'm taking the next step of my audio project and looking into a in dash monitor/cd player, in dash eq, and cd changer.
I was looking at alpine for the in dash monitor, but I didn't like they're aesthetics.
Here's what I propose:
Pioneer AVH-P6400CD
Display
Screen Size/Aspect Ratio 6.5 inch/16.9
AGLR (Anti-Glare, Low Reflection Coated Screen)
Motorized Display Angle Adjustment
Dimmer Control Auto
Independent Back-Up Camera Input Automatic Switching Capability
5 Selectable Viewing Modes
Receiver Features
MOSFET50 (50W x 4 Channel Power)
Hi-Volt Preouts 3 pair (Front/Rear & Sub or Non fader) (4V)
EQ Switches 5 Factory, 2 User Presets (EEQ Performance Chip)
Equalizer 3-Band Parametric
Super tuner IIl
IP-Bus System Control
XM Satellite Ready
RGB Input (26 Pin) for optional Navigation System (AVIC 80DVD)
A/V - Bus Input For use with TV Tuner GEX-P6400TV
Composite A/V Input yes
Composite A/V Output yes
Detachable Face Security
CD Playback CD/CD/CD-R/RW
SFEQ Performance Chip Front/Rear Bass and Treble
Then adding to customibility the Pioneer DEQ-9200
Now, THIS is fine tuning. The DEQ-9200 DSP audio processor is a powerful tool for customizing how you want music to sound in your vehicle. It features a DSP audio processor with Auto EQ for a huge variety of sound preferences, and Legato Link conversion for the purest sound possible. A multi-color EL display, extra-capacity battery, and detachable face security (with case provided) are additional features.
Features
3-Band Parametric Equalizer
6 Factory Presets (Flat/Rock/Pop/Vocal/Jazz/Soft)
4 User Presets
Nuance Control
Auto-EQ - Auto Frequency Response Calibration System
3 Curves Available (Dynamic/Natural/Mild)
Omni-Direction
Then a Pioneer CD Changer.
I would use my xbox for DVD input and gaming for now.
How does this sound audio guru's?
edit:
Also, where can I find a quality dash kit for my 98 GS and a radio harness?
Pioneer AVH-P6400CD
Display
Dimmer Control Auto
Receiver Features
Super tuner IIl
XM Satellite Ready
Features
4 User Presets
Nuance Control
Omni-Direction
edit:
Moderator - Electronics Forum
First thing I ask everybody...what are your system goals?
The wiring harness (if you have a pioneer system/stock) that can be used is an '87 and up Toyota harness. You'll have to rewire a couple of pins to make it work, but the shell connectors are the same.
Faceplate can be purchased at autotoys.com if I remember correctly. I do believe it's a Metra part, but I forgot the number. Someone on the board has it cheaper. "Doublewhoosh", one of the members, sells these - that's if the old brain cells remember it right.
Legato Link is just a marketing term...doesn't result in the "purest" possible sound, though it does make it sound warmer, despite the marketing hype. I have a Pioneer Premier PDR99 (home) which has the Legato Link and it's not bad, but not nearly as good as my SACD Sony SCD-1. The SCD-1 is a 5,000 dollar player - incredible sound. Modified, it sounds better than a Linn CD12 or the Krell KPS25, both of which are 20,000 dollar units.
3 band parametric...that's not enough bands! I'd recommend at least 6 band parametric or a 31 band "standard" 1/3rd octave eq. Parametrics are more powerful and flexible, but with only 3 bands, you're bound to run out.
Percy
Percy
Best EQ that I've seen so far is in the Alpine F#1 Status, but that's part of a larger package. Very expensive at 8 grand. Phoenix Gold makes a 30 band 1/3rd octave eq that's pretty good, but my favorite so far has got to be the McIntosh MEQ452 with the MEN450 power supply. 6 band parametrics and you can get lost in the tuning! For some reason, the older Alpine parametrics sounded questionable due to the internal parts / processing they were using. Very muddy. There's lots of eq's out there...!
Percy
Percy
If you want the best, alpine is it. The alpine eq is very very good. I dont have it but my friend has it in his car. all i got to say is wow.
now, what didnt u like about the alpine in dash? i have the iva-d900 and i think it looks good in the dash...
If i had unlimited money, alpine is what I would choose. I want just a in-dash cd player with no built in dvd because i have an xbox to use as a dvd player. Alpines products with these specifications are quite ugly. Pioneer is the best looking and sounds good.
Also, I looked at autotoys and i need a dash kit that will fit both the equalizer and the headunit one above the other, and it seems all of the ones on autotoys have a pocket, is there someplace I can get a double dash plate?
Update, found a newer better pioneer eq:
Pioneer DEQ-7600
If you like to customize your music- even specific songs- the DEQ-7600 is a great add-on. A 15-band EQ- with 5 factory/3 user presets- tailors your music, while the Hi-Bit Legato Link digital processor provides truly superior sound reproduction. Other features include electronic dual-amp balancing, a multi-color display, and a remote sensor for an add-on remote controller.
Features
Electronic 15-Band Digital Graphic Equalizer (F/R Common)
5 Factory Presets (Rock, Pops, Jazz, Vocal, Hip Hop)
3 User Presets
Nuance Control
Frequency Adjustment: (31.5, 50, 80, 125, 200, 315, 500, 800, 1.3k, 2k, 3.2k, 5k, 8k, 12.5k, 20kHz)
Gain +/- 12dB
5-Mode Digital Sound Field Control (SFC) (Studio, Jazz, Club, Concert, Stadium)
Listening Position Selector (4 Mode: Front Left/Front Right/Front/All)
Hi-Bit Legato Link™ Digital Processing provides 20-Bit accuracy for superior sound quality and detail
RCA Input
RCA Outputs (x3 Pair) (Front/Rear + Subwoofer)
Sub-Out Crossover (50, 80, 125Hz, -18dB/oct.)
Multicolor EL Display
15-Band Spectrum Analyzer (5-mode, 6-mode with subwoofer added)
Remote Control Sensor for Optional Remote
Super Capacity 3-Day Backup for DSP Memory
Dimensions (WxHxD): 7" x 2" x 5-1/4
Pioneer DEQ-7600
Features
3 User Presets
Nuance Control
Gain +/- 12dB
RCA Input
Jim
Thats nice but it has a built in dvd player. Anyone know where I can get a dash kit with two openings?
eclipse is coming out with 3 double-din head units and kenwood is coming out with 1. I'm pretty sure other brands will have one coming out also.
http://www.eclipse-web.com/index.html
http://www.crutchfield.com/S-61EerbB...p?i=113DDX7015
The reason I can't have a built in DVD player is beacause my dad wont let me. I will be using my xbox to get around him by mounting it in the trunk. When are those eclipse units coming out?
edit: I'm thinking about just forgetting the pioneer for now and waiting for those eclipse units to come out, does anyone have any idea when they will be coming out?
I used eclipse(s) units for a while and love the reliability. Not as flashy as other model, but it does the job.
Which part of Texas are you from? I had mine installed in Austin.
