Rugular gas or Premium?? For Cruising
Old 06-04-15, 04:06 PM
patrickkv2
patrickkv2's Avatar
Default Rugular gas or Premium?? For Cruising
If I want to drive normally and not drive that fast, can I just get regular gas?? I heard you should get premium gas ONLY if you using the performance alot.
Old 06-04-15, 04:21 PM
HanaleiISF
HanaleiISF's Avatar
Sometimes I wonder if people shouldn't be driving the 3IS in the first place if there is a debate on the merits of minute fuel savings. But to answer your question, I believe other have posted that when you use regular gas performance goes down as well as gas mileage, so the savings are muted.
Old 06-04-15, 04:23 PM
LexSense
LexSense's Avatar
Engine detonation/misfires can occur at any given moment regardless of speed or how hard you are pushing the car.
The higher octane you use, the less chance of that happening.
While you could use regular gas, you'd probably get worse gas mileage due to the engine timing retarding itself to accommodate the lower octane when it detects such occurrences.
Definitely go with premium if you don't want a retarded engine lol!
Last edited by LexSense; 06-04-15 at 04:31 PM. Reason: Added more stress to using premium!
Old 06-04-15, 08:54 PM
evident
evident's Avatar
just use premium. filled my car with 87 once by accident and it drove like crap and got worse fuel economy by 1 to 2 mpg.
so it's not even a cost benefit to do. if you cant swing the cost of premium vs regular gas , maybe you should get a v6 accord. they are pretty fast , get good fuel economy and can run regular
Old 06-04-15, 09:59 PM
SOLEJDM
SOLEJDM's Avatar
You gotta pay to play.
Old 06-04-15, 10:49 PM
tea
tea's Avatar
if you wanna use regular, go ahead and use regular. It's your car, who cares what Toyota engineers recommend right?
Old 06-04-15, 11:50 PM
LexusFirst
LexusFirst's Avatar
The user manual has stated the reason for using premium gas.
I am not Trying to insult you. However, if you are worry about the cost of gas, you probably get the wrong car. A Toyota would be a better choice. I don't see how gas price is a concern for Lexus owners.
Old 06-05-15, 02:39 AM
CtSFox
CtSFox's Avatar
If you use regular gas, you increase the probability of developing a carbon buildup problem in your IS 250
Old 06-05-15, 04:09 AM
Loe
Loe's Avatar
if you are simply cruising, regular is fine. In fact, since lower octane is easier to ignite, you may actually find an increase in mpg as it has to work less hard. However, you will see a decrease in performance/acceleration once the ECU pulls ignition advance; because of this, you will more than likely compensate by giving it more throttle, which will trigger the ECU to dump more fuel to meet your demands.
Old 06-05-15, 07:07 AM
dnasians
dnasians's Avatar
Higher octane MUST be used to prevent pre det.Your engine will be pinging/knocking like crazy to try to protect itself. Saving a few bucks here and there will not be enough to cover the knock damage.
If you wanted to save on gas, you shouldn't have gotten a V6.
Old 06-05-15, 07:53 AM
shirosan
shirosan's Avatar
OP, I agree with what others are saying in this forum. It ultimately comes down to protecting your engine in the long run. YES, the ECU will retard the timing to adjust for knock and misfires, which results in poor performance and gas mileage. You may save some money but you are now playing a game of "risk."
If you did use a lower octane I would recommend using an octane booster to meet at minimum 91 octane (even though I believe the car should have 93). That's your best course of action or just keep paying for the high octane like the manual asks.
One good this is that these (current) cars are naturally aspirated (NA) so your chances of damaging your engine with lower octane will be much lower than putting 87 octane in an Evo or WRX lmao.
Old 06-05-15, 11:22 AM
A2BLexus
A2BLexus's Avatar
I hear that diesel is cheaper than gas. Just go with that.
Just kidding.
Premium or nothing.
Old 06-05-15, 11:28 AM
azmojo
azmojo's Avatar
Modern engine computers can compensate for crappy or lower quality gas. But your engine and the computer is designed for premium. This is not a scam to get you to spend more on gas.
Old 06-05-15, 12:13 PM
EJ255t
EJ255t's Avatar
why would you put regular gas in a lexus??? just why???
you don't save that much in MPG, you might actually end up paying more when something goes wrong because you wanted to use cheaper gas.
STICK WITH PREMIUM!!
Old 06-05-15, 01:12 PM
ModInJapan
Lexus Enthusiasts
ModInJapan's Avatar
Lexus recommends we use premium gas and we should to protect our engine and to allow it to perform at its best potential. You want to give your car performance gas so it performs like a performance car!
-Josh
Quick Reply: Rugular gas or Premium?? For Cruising
