Insane vibration!!
Old 04-24-15, 11:17 AM
waleedj3is
waleedj3is's Avatar
Default Insane vibration!!
So, last night my effort to save my car failed, as i hit the curb at 80 kph trying to save it from a SUV driver who was about to hit me from the side. Although it was nothing major, just a scrape. I stopped at a fuel pump immediately to check my car, there was no damage just scratches on the rim, so i drove back home and there was no problem. However, today morning i started my baby up and as i drove it's shaking so bad. it's the wheel vibrating the whole car. the steering wheel is wobbling. Does anyone know what could be the problem over here?
Old 04-24-15, 11:21 AM
drbazing
drbazing's Avatar
Check your suspension including your alignment.
Old 04-24-15, 11:25 AM
4TehNguyen
4TehNguyen's Avatar
bent wheel, possible bent suspension
Old 04-24-15, 11:59 AM
anthonys2r
anthonys2r's Avatar
Definitely something under the car. Like mentioned above, suspension is suspect. Loose bolts, brackets, maybe even cracked welds too. Can't tell for sure until you lift it up
Old 04-24-15, 12:41 PM
waleedj3is
waleedj3is's Avatar
I don't see any signs of major damage though. Thanks a lot for your advice guys. Taking it tomorrow to the dealer.
Old 04-24-15, 12:54 PM
250Fsprt
250Fsprt's Avatar
That's why everyone should have a dash cam. You could have used it to make a claim and have the SUV driver pay for it. Most likely its your Axel.
Old 04-24-15, 01:33 PM
Jlin89
Jlin89's Avatar
will need a new wheel for sure, it's not obvious by looking at it, but i'm pretty sure it's bent to hell. Happened to my old car before but it was caused by weather. Slid into the curb and bent the hub, brake rotors and wheel.
Old 04-24-15, 07:22 PM
computerwi
computerwi's Avatar
Or it might be something as simple as a wheel balance. Just a few grams of metal shaved off from the rim during curb rash can cause severe vibration at high speeds. Is the vibration evident at all speeds?
Old 04-25-15, 12:26 AM
waleedj3is
waleedj3is's Avatar
It is noticeable at all speeds. When I drive the car it feels like its wobbling. I just dropped the car to the dealer. Hopefully they can figure out whats the issue.
Old 04-25-15, 04:04 AM
toyotatom
toyotatom's Avatar
Kind of odd you drove it home with no problems and the next morning there is a problem. Anything broken would have caused an issue right away I would think. Hope it turns out ok for you
Old 04-25-15, 10:17 AM
waleedj3is
waleedj3is's Avatar
Update: Just received a call from the dealer. Apparently it was a leaked shock absorber that was causing all this trouble. Thankfully, it is covered under warranty so it will be replaced by tomorrow.
Old 04-25-15, 08:33 PM
faisal11ir
faisal11ir's Avatar
Ouch so sorry to hear that, great thing they will cover the shock absorber leakage and won't relate it to accident.
Old 04-27-15, 08:53 AM
waleedj3is
waleedj3is's Avatar
Update #2: Turns out the vibration was caused by a faulty driver's side rear tire. Getting it replaced now. As for the shock absorbers, both the front absorbers had minor leaks (Don't know how). The parts will arrive within a week or 2. The dealer said its safe to drive the car until then.
Here's my car on a spacer if anyone's interested
drgrant
06-19-18 06:00 PM
nks979
IS F (2008-2014)
13
01-13-17 11:02 AM
BearsLexus
RX - 1st Gen (1999-2003)
15
08-27-14 10:53 PM
THoon
08-25-07 10:11 AM
plex
Suspension and Brakes
08-19-07 03:29 AM
Quick Reply: Insane vibration!!
